[51单片机] C语言语法分析
1287|2
 楼主| 火山LF 发表于 2016-7-12 14:56 | 显示全部楼层 |阅读模式
SPLASH_HEADER SplashHeader;  // 这是一个结构体类型
read_dpp3430_i2c(DPP3430_DEV_ADDR, READ_SPLASH_SCREEN_HEADER, &Param, 1, (uint08 *)&SplashHeader, sizeof (SplashHeader));  // 这是一个函数调用
请问(uint08 *)&SplashHeader是什么意思?sizeof (SplashHeader)是什么意思?
结构体内部为:
typedef struct
    uint16  Image_width;    /**< width of image in pixels */
    uint16  Image_height;   /**< height of image in pixels */
    uint32  Byte_count;     /**< number of bytes starting at "data" */
    uint08  Pixel_format;   /**< format of pixel data */
                            /**< 0 = 24-bit unpacked: 0x00RRGGBB Not supported by DDP2230/DDPDDP243x*/
                            /**< 1 = 24-bit packed:   RGB 8-8-8 */
                            /**< 2 = 16-bit:          RGB 5-6-5   DDP3020 only */
                            /**< 3 = 16-bit:          YCrCb 4:2:2 DDP2230/DDPDDP243x only */
    uint08  Compression;    /**< compression of image */
                            /**< SPLASH_FORCE_UNCOMPRESSED  = uncompressed */
                            /**< SPLASH_FORCE_RLE           = RLE compressed */
                            /**< SPLASH_USER_DEFINED        = User Defined Compression */
                            /**< SPLASH_FORCE_RLE_2PIXEL    = RLE compressed 2Pixel */
    uint08  ByteOrder;      /**< 0 - pixel is 00RRGGBB - DDP3020 */
                            /**< 1 - pixel is 00GGRRBB - DDP2230/DDPDDP243x */
    uint08  ChromaOrder;    /**< Indicates chroma order of pixel data (DDP2230/DDPDDP243x only) */
                            /**< 0 - Cr is first pixel (0xYYRR) */
                            /**< 1 - Cb is first pixel (0xYYBB) */
} SPLASH_HEADER;
JerryWu75 发表于 2016-7-12 15:58 | 显示全部楼层
将SplashHeader的地址作为(uint8 *)的指针传递给read_dpp3430_i2c函数
zgy8864 发表于 2016-7-12 21:36 | 显示全部楼层
sizeof (SplashHeader)的意思就是得到SplashHeader占用的字节数。
