[DCDC] 为什么BUCK控制器也有最大电流这一项?
3188|8
 楼主| jimsboy 发表于 2016-7-15 10:14 | 显示全部楼层 |阅读模式
我在TI网上选DC-DC芯片时发现,内置MOS管的降压芯片有一项参数为最大输出电流,这个很好理解,里边的MOS管一定的功率限制。但是那些BUCK控制器,需要外接MOS的那种,电流又不走它身上走,为什么也有最大电流限制呢?超过它给定的电流会给芯片带来什么不可控吗?
麻烦了解的兄弟给点帮助。谢谢
123654789 发表于 2016-7-15 10:31 | 显示全部楼层
那么就请你说说具体是那个控制器啊
 楼主| jimsboy 发表于 2016-7-15 11:03 | 显示全部楼层
所有的。
这两天想搞个太阳能电板来玩玩,那就需要将电存起来。我需要一个支持恒流恒压的芯片来自己搭一个充电器,尝试MPPT控制。
我看中了LM25085这个芯片。
它的最大占空比100%。支持恒流恒压。但我看手册上写着最大电流10A。这个电流有点小。我预计的是20A的电流。我就在想,既然电流不走它身上走过,什么要限制最大电流呢?
这个最大电流在手册里好像没有提及,但在技术参数页面里有
123654789 发表于 2016-7-15 11:55 | 显示全部楼层
以下这些英文来自LM25085的手册啊
简单地讲,
PFET比同类NFET,的内阻大一些,
受PFET内阻的影响,受LM25085门极驱动的能力限制。
所以外挂PFET的最大电流限制在10A
The LM25085 is a PFET buck (step-down) DC-DC controller
using the constant on-time (COT) control principle. The input
operating voltage range of the LM25085 is 4.5V to 42V. The
use of a PFET in a buck regulator greatly simplifies the gate
drive requirements and allows for 100% duty cycle operation
to extend the regulation range when operating at low input
voltage. However, PFET transistors typically have higher on-
         然而 与相同NFET想比较, PFET有着更加高的导通电阻 和 门充电。
resistance and gate charge when compared to similarly rated
NFET transistors. Consideration of available PFETs, input
                  考虑到可以获取的 PFET,输入电压,和 LM25085的门极驱动能力
voltage range, gate drive capability of the LM25085, and ther-
mal resistances indicate an upper limit of 10A for the load
  所以就限制10A的上限
current for LM25085 applications. Constant on-time control is
implemented using an on-time one-shot that is triggered by
the feedback signal. During the off-time, when the PFET (Q1)
is off, the load current is supplied by the inductor and the out-
put capacitor. As the output voltage falls, the voltage at the
feedback comparator input (FB) falls below the regulation
threshold. When this occurs Q1 is turned on for the one-shot
period which is determined by the input voltage (VIN) and the
RT resistor. During the on-time the increasing inductor current
increases the voltage at FB above the feedback comparator
threshold. For a buck regulator the basic relationship between
the on-time, off-time, input voltage and output voltage is:
评分
参与人数 1威望 +5 收起 理由
lfjwfm + 5 很给力!
查看全部评分
123654789 发表于 2016-7-15 12:04 | 显示全部楼层
就是这样理解.
外接PFET的电流越大。就需要LM25085具有更加大的门极驱动能力。
但是,现在LM25085的门极驱动能力有限。所以外接PFET的电流被限定在10A。
戈卫东 发表于 2016-7-15 22:30 | 显示全部楼层
因为电流越大的MOS管,它的QG值也越大。
戈卫东 发表于 2016-7-15 22:31 | 显示全部楼层
你如果有Qg值很小而电流又足够的MOS管用大电流是没有问题的。
ldch88 发表于 2016-7-15 23:41 | 显示全部楼层
最近我也准备用LM25085这个芯片,不知道哪里能够买到?
 楼主| jimsboy 发表于 2016-7-16 19:10 | 显示全部楼层
感谢各位的回复。
看来还是门极驱动能力的关系。
顺便回楼上,我在TB买的,还不知道真假。现在在TI上申请样片太难了。
