把图上了,帮忙看看代码行不
library IEEE;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
--实体
entity da1_test is
port (
clk:in STD_LOGIC ; --系统主时钟
da1_clk:out std_logic; --给DA的时钟
da1_d:out std_logic_vector(13 downto 0) --给DA的数据
end da1_test;
architecture topdesign_arch of da1_test is
signal count_clk:std_logic_vector(13 downto 0);
begin
da1_clk <=clk; --给DA的时钟
--da_clk <=not count_clk(0); --给DA的时钟
process(clk)
begin
if clk'event and clk='1' then
count_clk<=count_clk+1;
da1_d<=count_clk(13 downto 0);
end if ;
end process;
end topdesign_arch;
