[技术问答] NV32F100x工程stdlib库文件strtoul函数编译警告解决
1502|1
 楼主| yklstudent 发表于 2016-7-15 15:09 | 显示全部楼层 |阅读模式
纳瓦特官网提高库包文件编译提示警告信息,查看函数原型发现存在问题,待官网确认
uint32
strtoul (char *str, char **ptr, int base)
    unsigned long rvalue;
    int c, err, neg;
    char *endp;
    char *startp;
    rvalue = 0;  err = 0;  neg = 0;
    /* Check for invalid arguments */
    if ((str == NULL) || (base < 0) || (base == 1) || (base > 36))
        if (ptr != NULL)
            *ptr = str;
        return 0;
    /* Skip leading white spaces */
    for (startp = str; isspace(*startp); ++startp)
    /* Check for notations */
    switch (startp[0])
        case '0':
            if ((startp[1] == 'x') || (startp[1] == 'X'))
                if ((base == 0) || (base == 16))
                    base = 16;
                    startp = &startp[2];
            break;
        case '-':
            neg = 1;
            startp = &startp[1];
            break;
        default:
            break;
    if (base == 0)
        base = 10;
    /* Check for invalid chars in str */
    for ( endp = startp; (c = *endp) != '\0'; ++endp)
        /* Check for 0..9,Aa-Zz */
        if (!isalnum(c))
            err = 1;
            break;
        /* Convert char to num in 0..36 */
        if (isdigit(c))
            c = c - '0';
        else
            if (isupper(c))
                c = c - 'A' + 10;
            else
                c = c - 'a' + 10;
        /* check c against base */
        if (c >= base)
            err = 1;
            break;
        if (neg)
            rvalue = (rvalue * base) - c;
        else
            rvalue = (rvalue * base) + c;
    /* Upon exit, endp points to the character at which valid info */
    /* STOPS.  No chars including and beyond endp are used.        */
    if (ptr != NULL)
        *ptr = endp;
    if (err)
        if (ptr != NULL)
            *ptr = str;
        return 0;
    else
        return rvalue;
以上红字部分,原来是没有的,后来编译提示警告信息,更改了过来;
希望官网确认下我指出的是否是明显的BUG问题。
lchen_wx 发表于 2016-7-15 20:45 | 显示全部楼层
多谢提醒,已经update
