[STM32F1]
Keil仿真波形有,示波器上不出波形用的买的开发板
1619|6
ZHOU@JIE|  楼主 | 2016-7-31 12:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
示波器不出波形。。。。。。。。。。。。。
void TIM1_GPIO_Configuration(void)
        GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOE,&GPIO_InitStructure);
void TIM1_MODE_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        TIM_TimeBaseInitStructure.TIM_Period=999;
        TIM_TimeBaseInitStructure.TIM_Prescaler=71;
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;                //
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse=0;
        TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
        TIM_OC1Init(TIM1,&TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC2Init(TIM1,&TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_OC3Init(TIM1,&TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
//        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
//        TIM_OCInitStructure.TIM_Pulse=125;
//        TIM_OC4Init(TIM1,&TIM_OCInitStructure);
//        TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;
        TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Disable;
        TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
        TIM_BDTRInitStructure.TIM_DeadTime = 0x00;
        TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
        TIM_ARRPreloadConfig(TIM1,ENABLE);
        TIM_Cmd(TIM1,ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
void TIM2_NVIC_Configuration()
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  TIM_TimeBaseStructure.TIM_Period=999;
  TIM_TimeBaseStructure.TIM_Prescaler=35;
  TIM_TimeBaseStructure.TIM_ClockDivision=0;
  TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
  TIM_Cmd(TIM2, ENABLE);
void TIM2_IRQHandler (void)
        if (TIM_GetITStatus(TIM2, TIM_IT_Update)!=RESET)
                TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
                TIM1->CCR1 = Duty[i];
                        i++;
                if(i==256)
                        i=0;
mmuuss586| | 2016-7-31 15:27 | 只看该作者
这个都是0啊,换个值看看;
还有示波器量的脚位对不对
ZHOU@JIE|  楼主 | 2016-7-31 16:16 | 只看该作者
这个都是0啊,换个值看看;
初始化的时候给的0,在中断里面都是中断一次赋值一次的。
Bjorn| | 2016-7-31 20:23 | 只看该作者
示波器量的地方对不对呢
quray1985| | 2016-8-1 09:44 | 只看该作者
不知道你的io口是怎么设置的
ZHOU@JIE|  楼主 | 2016-8-1 14:14 | 只看该作者
quray1985 发表于 2016-8-1 09:44
不知道你的io口是怎么设置的
STM32F103VET6 TIM1重映射到PE引脚的
ZHOU@JIE|  楼主 | 2016-8-1 14:15 | 只看该作者
Bjorn 发表于 2016-7-31 20:23
示波器量的地方对不对呢
直接测量的PE8脚
