[STM32F1] Keil仿真波形有,示波器上不出波形用的买的开发板
1728|6
 楼主| ZHOU@JIE 发表于 2016-7-31 12:47 | 显示全部楼层 |阅读模式
示波器不出波形。。。。。。。。。。。。。
  1. void TIM1_GPIO_Configuration(void)
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
  5.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
  6.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  7.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
  8.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  9.         GPIO_Init(GPIOE,&GPIO_InitStructure);
  10. }
  11. void TIM1_MODE_Configuration(void)
  12. {
  13.         TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
  14.         TIM_OCInitTypeDef TIM_OCInitStructure;
  15.         TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  16.         TIM_TimeBaseInitStructure.TIM_Period=999;
  17.         TIM_TimeBaseInitStructure.TIM_Prescaler=71;
  18.         TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;                //
  19.         TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
  20.         TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
  21.         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
  22.
  23.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
  24.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  25.         TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
  26.         TIM_OCInitStructure.TIM_Pulse=0;
  27.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
  28.         TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
  29.         TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
  30.         TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
  31.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  32.         TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
  33.
  34.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  35.         TIM_OCInitStructure.TIM_Pulse=0;
  36.         TIM_OC2Init(TIM1,&TIM_OCInitStructure);
  37.         TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
  38.
  39.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  40.         TIM_OCInitStructure.TIM_Pulse=0;
  41.         TIM_OC3Init(TIM1,&TIM_OCInitStructure);
  42.         TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
  43.
  44. //        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  45. //        TIM_OCInitStructure.TIM_Pulse=125;
  46. //        TIM_OC4Init(TIM1,&TIM_OCInitStructure);
  47. //        TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
  48.         TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;
  49.         TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Disable;
  50.         TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
  51.         TIM_BDTRInitStructure.TIM_DeadTime = 0x00;
  52.         TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
  53.         TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
  54.         TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  55.         TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
  56.
  57.         TIM_ARRPreloadConfig(TIM1,ENABLE);
  58.         TIM_Cmd(TIM1,ENABLE);
  59.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  60. }
  61. void TIM2_NVIC_Configuration()
  62. {
  63.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  64.   NVIC_InitTypeDef NVIC_InitStructure;
  65.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  66.   TIM_TimeBaseStructure.TIM_Period=999;
  67.   TIM_TimeBaseStructure.TIM_Prescaler=35;
  68.   TIM_TimeBaseStructure.TIM_ClockDivision=0;
  69.   TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  70.   TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  71.
  72.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  73.   NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn;
  74.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
  75.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
  76.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  77.         NVIC_Init(&NVIC_InitStructure);
  78.   TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
  79.   TIM_Cmd(TIM2, ENABLE);
  80. }
  81. void TIM2_IRQHandler (void)
  82. {
  83.         if (TIM_GetITStatus(TIM2, TIM_IT_Update)!=RESET)
  84.         {
  85.                 TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  86.                 TIM1->CCR1 = Duty[i];
  87.                         i++;
  88.                 if(i==256)
  89.                         i=0;
  90.         }
  91.
  92. }
mmuuss586 发表于 2016-7-31 15:27 | 显示全部楼层
这个都是0啊,换个值看看;
还有示波器量的脚位对不对
 楼主| ZHOU@JIE 发表于 2016-7-31 16:16 | 显示全部楼层
这个都是0啊,换个值看看;
初始化的时候给的0,在中断里面都是中断一次赋值一次的。
Bjorn 发表于 2016-7-31 20:23 | 显示全部楼层
示波器量的地方对不对呢
quray1985 发表于 2016-8-1 09:44 来自手机 | 显示全部楼层
不知道你的io口是怎么设置的
 楼主| ZHOU@JIE 发表于 2016-8-1 14:14 | 显示全部楼层
不知道你的io口是怎么设置的
STM32F103VET6 TIM1重映射到PE引脚的
 楼主| ZHOU@JIE 发表于 2016-8-1 14:15 | 显示全部楼层
示波器量的地方对不对呢
直接测量的PE8脚
