[技术求助]
280初始化代码
595|5
dengdc| | 2016-8-3 22:20 | 只看该作者
你是PLC的应用吗?很好的方案,标准的SPI接口,程序网上可以找到。
heweibig| | 2016-8-3 22:21 | 只看该作者
PGA280 + ADS1259 has been designed to work together to create one easy solution for high resolution/high voltage industrial applications.
2 Channel, fast, MUX PGA front end for multi channel control with Single Cycle settling ADC for enhanced throughput in MUX
Fully differential +/-15V PGA signal swing for seamless ADS input
ADS1259 clock output to synchronize the PGA280 input chopping to preserve the low noise performance.
Low 1/f noise of PGA for 24 bit high resolution and sensitivity of ADC
High PGA CMRR + ADC Digital filter for 16, 50, 60, or 400Hz rejection
shimx| | 2016-8-3 22:23 | 只看该作者
有个下载的链接,GPIO模拟SPI,
http://wenku.baidu.com/view/3aec66d349649b6648d74768.html
jiahy|  楼主 | 2016-8-3 22:25 | 只看该作者
谢谢,找到原因了,在连续操作PGA280时,不能一直将CS引脚置低电平。
airwill| | 2016-8-4 08:56 | 只看该作者
很好的经验, 路过, 记住了
