[STM32F3] STM32F303RE官方开发板ADC+DMA异常
1362|0
 楼主| wzrde21 发表于 2016-8-9 21:44 | 显示全部楼层 |阅读模式
现象为ADC1DualConvertedValue【0】与ADC1DualConvertedValue【1】数据正常
ADC1DualConvertedValue【3】也就是ADC1通道4数据异常
请各位大神帮帮忙
  1. /* 宏定义 --------------------------------------------------------------------*/
  2. #define ADC1_CDR_ADDRESS    ((uint32_t)&ADC1->DR)
  3. #define ADC2_CDR_ADDRESS    ((uint32_t)&ADC2->DR)
  4. /* 变量 ----------------------------------------------------------------------*/
  5. extern        u16 ADC1DualConvertedValue[3];
  6. extern        u16 ADC2DualConvertedValue[3];
  7. void K_DMA_Configuration(void)
  8. {
  9.         DMA_InitTypeDef DMA_InitStructure;
  10.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  11.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  12.   DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_CDR_ADDRESS;        //Specifies the peripheral base address for DMAy Channelx.
  13.   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADC1DualConvertedValue;                        //Specifies the memory base address for DMAy Channelx
  14.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;        //Specifies if the peripheral is the source or destination
  15.   DMA_InitStructure.DMA_BufferSize = 3;        //Specifies the buffer size, in data unit, of the specified Channel
  16.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                                                        //Specifies whether the Peripheral address register is incremented or not.
  17.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;        //Specifies whether the memory address register is incremented or not.
  18.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;                //Specifies the Peripheral data width
  19.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;                                                //Specifies the Memory data width.
  20.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Specifies the operation mode of the DMAy Channelx.
  21.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;        //Specifies the software priority for the DMAy Channelx
  22.   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;        //Specifies if the DMAy Channelx will be used in memory-to-memory transfer.
  23.   DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  24.
  25.   DMA_InitStructure.DMA_PeripheralBaseAddr = ADC2_CDR_ADDRESS;
  26.   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADC2DualConvertedValue;
  27.         DMA_Init(DMA2_Channel1, &DMA_InitStructure);
  28.   DMA_Cmd(DMA1_Channel1, ENABLE);
  29.   DMA_Cmd(DMA2_Channel1, ENABLE);
  30. }
  31. void  K_Adc_Init(void)
  32. {
  33.         ADC_CommonInitTypeDef ADC_CommonInitStructure;
  34.         ADC_InitTypeDef       ADC_InitStructure;
  35.         GPIO_InitTypeDef                         GPIO_InitStructure;
  36.
  37.         RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div1);                //配置ADC时钟
  38.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  39.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12, ENABLE);
  40.
  41.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_3|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;        //ADC1 CH124 ADC2 CH234
  42.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;                //模拟输入引脚
  43.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  44.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  45.
  46.   ADC_StructInit(&ADC_InitStructure);
  47.   ADC_VoltageRegulatorCmd(ADC1, ENABLE);
  48.   ADC_VoltageRegulatorCmd(ADC2, ENABLE);
  49.   delay_ms(10);
  50.
  51.   ADC_SelectCalibrationMode(ADC1, ADC_CalibrationMode_Single);
  52.   ADC_StartCalibration(ADC1);
  53.   ADC_SelectCalibrationMode(ADC2, ADC_CalibrationMode_Single);
  54.   ADC_StartCalibration(ADC2);
  55.
  56.   while(ADC_GetCalibrationStatus(ADC1) != RESET );
  57. //  calibration_value_1 = ADC_GetCalibrationValue(ADC1);
  58.   while(ADC_GetCalibrationStatus(ADC2) != RESET );
  59. //  calibration_value_2 = ADC_GetCalibrationValue(ADC2);
  60.
  61.   ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;            //ADC independent mode
  62.   ADC_CommonInitStructure.ADC_Clock = ADC_Clock_SynClkModeDiv1;                                //Synchronous clock mode divided by 1
  63.   ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;          //DMA12~10位分辨率
  64.   ADC_CommonInitStructure.ADC_DMAMode = ADC_DMAMode_Circular;         //DMA连续模式
  65.   ADC_CommonInitStructure.ADC_TwoSamplingDelay = 2;        //采样延迟0~f
  66.   ADC_CommonInit(ADC1, &ADC_CommonInitStructure);
  67.         ADC_CommonInit(ADC2, &ADC_CommonInitStructure);
  68.
  69.   ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Enable;                                //连续转换
  70.   ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;        //12位精度
  71.   ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_0;                        //ADC external trigger event 0
  72.   ADC_InitStructure.ADC_ExternalTrigEventEdge = ADC_ExternalTrigEventEdge_None;                //ADC No external trigger for regular conversion
  73.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC Data alignment right
  74.   ADC_InitStructure.ADC_OverrunMode = ADC_OverrunMode_Disable;        //ADC Overrun Mode disable
  75.   ADC_InitStructure.ADC_AutoInjMode = ADC_AutoInjec_Disable;        //ADC Auto injected Mode disable
  76.   ADC_InitStructure.ADC_NbrOfRegChannel = 3;
  77.   ADC_Init(ADC1, &ADC_InitStructure);
  78.   ADC_Init(ADC2, &ADC_InitStructure);
  79.
  80.   ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_1Cycles5);
  81.   ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 2, ADC_SampleTime_1Cycles5);
  82.         ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 3, ADC_SampleTime_1Cycles5);
  83.
  84.         ADC_RegularChannelConfig(ADC2, ADC_Channel_2, 1, ADC_SampleTime_1Cycles5);
  85.         ADC_RegularChannelConfig(ADC2, ADC_Channel_3, 2, ADC_SampleTime_1Cycles5);
  86.         ADC_RegularChannelConfig(ADC2, ADC_Channel_4, 3, ADC_SampleTime_1Cycles5);
  87.   ADC_Cmd(ADC1, ENABLE);
  88.   while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_RDY));
  89.   ADC_Cmd(ADC2, ENABLE);
  90.   while(!ADC_GetFlagStatus(ADC2, ADC_FLAG_RDY));
  91.
  92.   ADC_DMACmd(ADC1, ENABLE);
  93.   ADC_DMAConfig(ADC1, ADC_DMAMode_Circular);
  94.         ADC_DMACmd(ADC2, ENABLE);
  95.         ADC_DMAConfig(ADC2, ADC_DMAMode_Circular);
  96.   ADC_StartConversion(ADC1);
  97.         ADC_StartConversion(ADC2);
  98. }
