[STM8] 单键作业
635|3
 楼主| Listate 发表于 2016-8-22 16:28 | 显示全部楼层 |阅读模式
pi, IO, gp, GPIO, TE
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
BitStatus bit_status;
void Delay(uint16_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
void main(void)
  /* Initialize I/Os in Output Mode */
  GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);
  GPIO_Init(GPIOD, GPIO_PIN_ALL, GPIO_MODE_OUT_OD_LOW_FAST);
  GPIO_Init(GPIOA, GPIO_PIN_2, GPIO_MODE_IN_PU_NO_IT);
  GPIO_ExternalPullUpConfig(GPIOA, GPIO_PIN_2, ENABLE);
  while (1)
    /* Toggles LEDs */
    GPIO_Write(GPIOE, 0x20);
    GPIO_Write(GPIOD, 0xFE);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xFD);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xFB);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xF7);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xEF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xDF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0xBF);
    Delay(0xFFFF);
    GPIO_Write(GPIOD, 0x7F);
    Delay(0xFFFF);
    GPIO_Write(GPIOE, 0x00);
    Delay(0xFFFF);
    Delay(0xFFFF);
    Delay(0xFFFF);
    bit_status = GPIO_ReadInputPin(GPIOA, GPIO_PIN_2);
    if (bit_status == RESET)  //SET or RESET
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
androidbus 发表于 2016-8-22 16:47 | 显示全部楼层
看看,怎么没有提供电路图呢?
xyz549040622 发表于 2016-8-22 22:08 | 显示全部楼层
  1.     if (bit_status == RESET)  //SET or RESET
  2.     {
  3.       GPIO_Write(GPIOE, 0x00);
  4.     }
  5.       GPIO_Write(GPIOE, 0x20);
后面是不是少了个else呢?
Thethree 发表于 2016-8-23 09:09 | 显示全部楼层
单键是什么意思呢,不是矩阵,有个电路图就好了
