040新手请教
1978|0
juelang|  楼主 | 2010-3-20 01:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我刚开始学040单片机,对片内资源还不是很了解,今天做了一个很简单的程序,可是有点小问题,请教高手指教
#include<C8051F040.H>
sbit P2_7=P2^7;
sbit P0_0=P0^0;
sbit P0_1=P0^1;
sbit P0_2=P0^2;
sbit P0_3=P0^3;
void config (void)//配置函数
    WDTCN = 0x07;// 设置WDT超时间隔
    WDTCN = 0xDE;   // 禁止WDT
    WDTCN = 0xAD;
           SFRPAGE = 0x0F; //选择特殊功能寄存器所在页
    XBR0 = 0x00;// XBAR0: Initial Reset Value
    XBR1 = 0x00;// XBAR1: Initial Reset Value
    XBR2 = 0x40;        // XBAR2: Initial Reset Value
    XBR3 = 0x00;    // XBAR3: Initial Reset Value
    SFRPAGE = 0x0F;
    P0MDOUT = 0xff; // Output configuration for P0
    P1MDOUT = 0x00; // Output configuration for P1
    P2MDOUT = 0x00; // Output configuration for P2
    P3MDOUT = 0x00; // Output configuration for P3
    P4MDOUT = 0xff; // Output configuration for P4
    P5MDOUT = 0x07; // Output configuration for P5
    P6MDOUT = 0x00; // Output configuration for P6
    P7MDOUT = 0x00; // Output configuration for P7
    P1MDIN = 0xFF;  // Input configuration for P1
    P2MDIN = 0xFF;  // Input configuration for P2
    P3MDIN = 0xFF;  // Input configuration for P3
    SFRPAGE = 0x0F;
    CLKSEL = 0x00;  // Oscillator Clock Selector
    OSCXCN = 0x00;        // EXTERNAL Oscillator Control Register
    OSCICN = 0x80;        // Internal Oscillator Control Register
void main()
unsigned long int i;
P2_7=0; //这个口接led的负极
   config();
   while(1)
//下面的P0_0到P0_3口都接led的正极,可是出现的结果是,P1_1口特别亮,而其他3个口的led
//一般亮,后来我改了这个P0MDOUT = 0xFF;,所有的led都一样亮了
//这是为什么呢
for(i=0;i<45000;i++)
P0_0=1;
P0_1=1;
P0_2=1;
P0_3=1;
