对软定时器的一些思考
1916|4
s17701332|  楼主 | 2016-10-16 17:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一直想在单片机上实现一个像MFC和WPF一样的软定时器,前段时间看了《编程魔法师》以后自己花了点时间写了个,使用时需把timer_run函数放到定时器中断服务函数里面(设想中实时操作都是短时任务),本来已发到CSDN上的,想了想还是回来也给大家看下,看能不能再优化下
typedef struct _TIMER
        unsigned char isEnable;
        unsigned int  count;
        unsigned int  countNeed;
        void (*func)();
}TIMER;
void timer_Run(TIMER *timer)
        if(timer.isEnable)
                timer.count ++;
                if(timer.count == timer.countNeed)
                        timer.count = 0;
                        timer.func();
void startTimer(TIMER *timer)
        timer.count = 0;
        timer.isEnable = 1;
void stopTimer(TIMER *timer)
        timer.isEnable = 0;
        timer.count =0;
s17701332|  楼主 | 2016-10-16 17:01 | 只看该作者
发现个问题,上面的.需要换成->
s17701332|  楼主 | 2016-10-19 10:28 | 只看该作者
这个还是有点low了,需要在写中断的时候就要知道需要多少个定时器,需要经常维护,或许我们可以通过调用一个链表的方式实现
21ndt| | 2016-10-25 11:27 | 只看该作者
跟这个做得很像
https://github.com/0x1abin/MultiTimer/*
* Copyright (c) 2016 Zibin Zheng <znbin@qq.com>
* All rights reserved
#include "multi_timer.h"
//timer handle list head.
static struct Timer* head_handle = NULL;
//Timer ticks
static uint32_t _timer_ticks = 0;
  * @brief  Initializes the timer struct handle.
  * @param  handle: the timer handle strcut.
  * @param  timeout_cb: timeout callback.
  * @param  repeat: repeat interval time.
  * @retval None
void timer_init(struct Timer* handle, void(*timeout_cb)(), uint32_t timeout, uint32_t repeat)
        // memset(handle, sizeof(struct Timer), 0);
        handle->timeout_cb = timeout_cb;
        handle->timeout = _timer_ticks + timeout;
        handle->repeat = repeat;
  * @brief  Start the timer work, add the handle into work list.
  * @param  btn: target handle strcut.
  * @retval 0: succeed. -1: already exist.
int timer_start(struct Timer* handle)
        struct Timer* target = head_handle;
        while(target)
                if(target == handle) return -1;        //already exist.
                target = target->next;
        handle->next = head_handle;
        head_handle = handle;
        return 0;
  * @brief  Stop the timer work, remove the handle off work list.
  * @param  handle: target handle strcut.
  * @retval None
void timer_stop(struct Timer* handle)
        struct Timer** curr;
        for(curr = &head_handle; *curr; )
                struct Timer* entry = *curr;
                if (entry == handle)
                        *curr = entry->next;
//                        free(entry);
                else
                        curr = &entry->next;
  * @brief  main loop.
  * @param  None.
  * @retval None
void timer_loop()
        struct Timer* target;
        for(target=head_handle; target; target=target->next)
                if(_timer_ticks >= target->timeout)
                        if(target->repeat == 0)
                                timer_stop(target);
                        else
                                target->timeout = _timer_ticks + target->repeat;
                        target->timeout_cb();
  * @brief  background ticks, timer repeat invoking interval 1ms.
  * @param  None.
  * @retval None.
void timer_ticks()
        _timer_ticks++;
#ifndef _MULTI_TIMER_H_
#define _MULTI_TIMER_H_
#include "stdint.h"
typedef struct Timer {
    uint32_t timeout;
    uint32_t repeat;
    void (*timeout_cb)(void);
    struct Timer* next;
}Timer;
#ifdef __cplusplus
extern "C" {
#endif
void timer_init(struct Timer* handle, void(*timeout_cb)(), uint32_t timeout, uint32_t repeat);
int  timer_start(struct Timer* handle);
void timer_stop(struct Timer* handle);
void timer_ticks(void);
void timer_loop(void);
// void timer_again(struct Timer* handle);
// void timer_set_repeat(struct Timer* handle, uint32_t repeat);
#ifdef __cplusplus
#endif
#endif
s17701332|  楼主 | 2016-10-25 14:03 | 只看该作者
21ndt 发表于 2016-10-25 11:27
跟这个做得很像
用链表实现可以更好的重复利用,看来有人和我想法一样
