[STM32F3] 【转】STM32F303X单片机USB例程详细解析
1784|2
 楼主| 一代掌门 发表于 2016-11-11 19:18 | 显示全部楼层 |阅读模式
终于回到了熟悉的岗位。利用STM32系列单片机开发USBHid类设备及Joystick。最开始先来研读程序,近期会随着读程序随笔写出每个函数的分析。下边先说第一部分。
int main(void)
uint8_t i = 0;
/* SysTick end of count event each 10ms */
RCC_GetClocksFreq(&RCC_Clocks);
SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
/* Configure the USB */
USB_Config();
KEY_Init();
while (1)
  Mouse_Buffer = USBD_HID_GetPos();
  * @brief  Configure the USB.
  * @param  None
  * @retval None
void USB_Config(void)
  Set_System();  --------> 1
  Set_USBClock();  --------> 2
  USB_Interrupts_Config();  --------> 3
  USB_Init();  --------> 4
//  while (bDeviceState != CONFIGURED)
1. Set_System()
位于USB_Example\hw_config.c文件中。其主要功能是初始化单片机时钟系统、使能相关的外设电源。
  * @brief  Configures Main system clocks & power.
  * @param  None
  * @retval None
void Set_System(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f30x.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f30x.c file
/* Enable the PWR clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);  --------> 1.1
  /* Enable the SYSCFG module clock (used for the USB disconnect feature) */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);  --------> 1.2
  /* Enable the USB disconnect GPIO clock */
//  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIO_DISCONNECT, ENABLE);
/*Set PA11,12 as IN - USB_DM,DP*/
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);  --------> 1.3
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure);  -------- 1.4
  /*SET PA11,12 for USB: USB_DM,DP*/
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_14);  --------> 1.5
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource12, GPIO_AF_14);  --------> 1.5
#if defined(USB_USE_EXTERNAL_PULLUP)
//  /* USB_DISCONNECT used as USB pull-up */
//  GPIO_InitStructure.GPIO_Pin = USB_DISCONNECT_PIN;
//  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
//  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
//  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
//  GPIO_Init(USB_DISCONNECT, &GPIO_InitStructure);
#endif /* USB_USE_EXTERNAL_PULLUP */
  /* Configure the EXTI line 18 connected internally to the USB IP */
  EXTI_ClearITPendingBit(EXTI_Line18);  --------> 1.6
  EXTI_InitStructure.EXTI_Line = EXTI_Line18; /*USB resume from suspend mode*/
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);  --------> 1.7
  EXTI_ClearITPendingBit(USER_BUTTON_EXTI_LINE);  --------> 1.6
1.1 RCC_APB1PeriphClockCmd()
位于USB_Example\Libraries\STM32F30x_StdPeriph_Driver\src\stm32f30x_rcc.c文件中。其主要功能是使能或者禁止外设时钟。
  * @brief  Enables or disables the Low Speed APB (APB1) peripheral clock.
  * @NOTE   After reset, the peripheral clock (used for registers read/write access)
  *         is disabled and the application software has to enable this clock before
  *         using it.
  * @param  RCC_APB1Periph: specifies the APB1 peripheral to gates its clock.
  *   This parameter can be any combination of the following values:
  *     @arg RCC_APB1Periph_TIM2
  *     @arg RCC_APB1Periph_TIM3
  *     @arg RCC_APB1Periph_TIM4
  *     @arg RCC_APB1Periph_TIM6
  *     @arg RCC_APB1Periph_TIM7
  *     @arg RCC_APB1Periph_WWDG
  *     @arg RCC_APB1Periph_SPI2
  *     @arg RCC_APB1Periph_SPI3
  *     @arg RCC_APB1Periph_USART2
  *     @arg RCC_APB1Periph_USART3
  *     @arg RCC_APB1Periph_UART4
  *     @arg RCC_APB1Periph_UART5
  *     @arg RCC_APB1Periph_I2C1
  *     @arg RCC_APB1Periph_I2C2
  *     @arg RCC_APB1Periph_USB
  *     @arg RCC_APB1Periph_CAN1
  *     @arg RCC_APB1Periph_PWR
  *     @arg RCC_APB1Periph_DAC
  * @param  NewState: new state of the specified peripheral clock.
  *         This parameter can be: ENABLE or DISABLE.
  * @retval None
void RCC_APB1PeriphClockCmd(uint32_t RCC_APB1Periph, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_RCC_APB1_PERIPH(RCC_APB1Periph));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    RCC->APB1ENR |= RCC_APB1Periph;
  else
    RCC->APB1ENR &= ~RCC_APB1Periph;
RCC在USB_Example\Libraries\CMSIS\Device\ST\STM32F30x\Include\stm32f30x.h中定义:
#define RCC                 ((RCC_TypeDef *) RCC_BASE)
RCC_BASE在同文件中定义:
#define RCC_BASE              (AHB1PERIPH_BASE + 0x00001000)
AHB1PERIPH_BASE也在同文件中定义:
#define AHB1PERIPH_BASE       (PERIPH_BASE + 0x00020000)
#define PERIPH_BASE           ((uint32_t)0x40000000) /*!< Peripheral base address in the alias region */
其中:
RCC_BASE展开来为(uint32_t)0x40000000 + 0x00020000 + 0x00001000,即(uint32_t)0x40021000,对应手册中P42中的RCC寄存器。
而RCC_TypeDef 在USB_Example\Libraries\CMSIS\Device\ST\STM32F30x\Include\stm32f30x.h中定义:
  * @brief Reset and Clock Control
typedef struct
  __IO uint32_t CR;         /*!< RCC clock control register,                                  Address offset: 0x00 */
  __IO uint32_t CFGR;       /*!< RCC clock configuration register,                            Address offset: 0x04 */
  __IO uint32_t CIR;        /*!< RCC clock interrupt register,                                Address offset: 0x08 */
  __IO uint32_t APB2RSTR;   /*!< RCC APB2 peripheral reset register,                          Address offset: 0x0C */
  __IO uint32_t APB1RSTR;   /*!< RCC APB1 peripheral reset register,                          Address offset: 0x10 */
  __IO uint32_t AHBENR;     /*!< RCC AHB peripheral clock register,                           Address offset: 0x14 */
  __IO uint32_t APB2ENR;    /*!< RCC APB2 peripheral clock enable register,                   Address offset: 0x18 */
  __IO uint32_t APB1ENR;    /*!< RCC APB1 peripheral clock enable register,                   Address offset: 0x1C */
  __IO uint32_t BDCR;       /*!< RCC Backup domain control register,                          Address offset: 0x20 */
  __IO uint32_t CSR;        /*!< RCC clock control & status register,                         Address offset: 0x24 */
  __IO uint32_t AHBRSTR;    /*!< RCC AHB peripheral reset register,                           Address offset: 0x28 */
  __IO uint32_t CFGR2;      /*!< RCC clock configuration register 2,                          Address offset: 0x2C */
  __IO uint32_t CFGR3;      /*!< RCC clock configuration register 3,                          Address offset: 0x30 */
} RCC_TypeDef;
上面的结构体定义对应手册中P133中的7.4.14 RCC register map。
“1. Set_System()”中调用RCC_APB1PeriphClockCmd()时的第一个参数RCC_APB1Periph_PWR在USB_Example\Libraries\STM32F30x_StdPeriph_Driver\inc\stm32f30x_rcc.h中定义:
#define RCC_APB1Periph_PWR               ((uint32_t)0x10000000)
对应手册P120中"Bit 28 PWREN: Power interface clock enable"。
综合以上内容可知,RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);  --------> 1.1 所实现功能如其注释所述,使能电源时钟。
 楼主| 一代掌门 发表于 2016-11-11 19:19 | 显示全部楼层
接上一篇**。继续void Set_System(void)的分析。
1.2 RCC_APB2PeriphClockCmd()
位于USB_Example\Libraries\STM32F30x_StdPeriph_Driver\src\stm32f30x_rcc.c文件中。其主要功能也是使能或禁止外设时钟,不过是APB2总线上的。
  * @brief  Enables or disables the High Speed APB (APB2) peripheral clock.
  * @note   After reset, the peripheral clock (used for registers read/write access)
  *         using it.
  * @param  RCC_APB2Periph: specifies the APB2 peripheral to gates its clock.
  *     @arg RCC_APB2Periph_SYSCFG
  *     @arg RCC_APB2Periph_SPI1
  *     @arg RCC_APB2Periph_USART1
  *     @arg RCC_APB2Periph_TIM15
  *     @arg RCC_APB2Periph_TIM16
  *     @arg RCC_APB2Periph_TIM17
  *     @arg RCC_APB2Periph_TIM8
  * @retval None
void RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState)
  assert_param(IS_RCC_APB2_PERIPH(RCC_APB2Periph));
    RCC->APB2ENR |= RCC_APB2Periph;
  else
    RCC->APB2ENR &= ~RCC_APB2Periph;
RCC、APB3ENR的说明见前一篇**,在此不再赘述。
“1. Set_System()”中调用RCC_APB2PeriphClockCmd()时传入的第一个参数RCC_APB2Periph_SYSCFG在USB_Example\Libraries\STM32F30x_StdPeriph_Driver\inc\stm32f30x_rcc.h中定义:
#define RCC_APB2Periph_SYSCFG            ((uint32_t)0x00000001)
对应手册P120中"Bit 0 SYSCFGEN: SYSCFG clock enable"。
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);  --------> 1.2 所实现功能如其注释所述,使能系统配置控制器时钟。
