[PIC®/AVR®/dsPIC®产品] 关于回调函数的理解
1021|1
 楼主| wodezpyzz 发表于 2016-11-17 08:55 | 显示全部楼层 |阅读模式
typedef enum S_ERR
          S_ERR_OK,        // no error
          S_ERR_BUSY,        // Read or Write process is in busy.
          S_ERR_NO_BUFFER,        // no buffer room for data received
          S_ERR_TIMEOUT,        // timeout when read
          S_ERR_UNKNOWN_CMD,        // not in use
          S_ERR_INVALID_CMD,        // not in use
          S_ERR_CANCEL,        // not in use
          S_ERR_PARA        // provide function with invalid argument
}S_ERR;
//*** callback function type definitions ***
typedef void(*CB_ERR)(S_ERR);
typedef void(*CB_DONE_WRITE)(S_ERR);
typedef void(*CB_DONE_READ)(S_ERR, UINT32);
void sci_appl_Init(void)
            S_ERR err = S_ERR_OK;
err = HAL_Init( (CB_ERR)CBError ); // initiate HAL (must provide valid argument otherwise HAL_Init will return error(S_ERR_PARA).)
if( err == S_ERR_OK )
               init_appl_data();        // initialize application-layer's data
           HAL_Config_Set(&s_HALconfig_LEN);        // configure HAL (assign Work-mode)
           //HAL_Config_Set(&s_HALconfig_TIME);
           //HAL_Config_Set(&s_HALconfig_CHAR);
       #if DMA_MODE == DMA_REC_SEND
               HAL_Read_DMA(RX_BUFFER_SIZE,s_pReadBuffer,CBDoneRead);        // request HAL to read.(for Serial-x)
       //        HAL_Read_DMA2(RX_BUFFER_SIZE,s_pReadBuffer2,CBDoneRead2);        // request HAL to read.(for LittleSwan)
               HAL_Read_Poll2(RX_BUFFER_SIZE,s_pReadBuffer2,CBDoneRead2);        // use poll method for littleswan receiving.
       #else
               HAL_Read(RX_BUFFER_SIZE,s_pReadBuffer2,CBDoneRead2);        // request HAL to read.
       #endif
ReadBuffer[0]=0x01; // test
S_ERR HAL_Init(CB_ERR _fpError)
UINT8 dummy;
if( NULL == _fpError )
          err = S_ERR_PARA;
else
          s_fpError = _fpError;  // Store CallBack function pointers
if(S_ERR_OK == err)        // if no error encountered.
hw_voInitUART();  // initiate UART module hardware
return err;
请问我该如何理解这一句?err = HAL_Init( (CB_ERR)CBError );
wsnsyy 发表于 2016-11-17 10:03 | 显示全部楼层
CBError转换为CB_ERR类型,然后传递给HAL_Init
