STM32 上电串口发送0是怎么回事
27089|40
肥羊 发表于 2020-6-30 15:08 | 显示全部楼层
wago2008 发表于 2013-4-15 19:30
无论这么设置USart,上电后都会发送一个无效字符,这个是STATUS寄存器的上电初始值有问题造成的,Usart的发 ...
试过都不行,还是会自动发0x00
肥羊 发表于 2020-6-30 15:11 | 显示全部楼层
  1. //初始化IO 串口1
  2. //bound:波特率
  3. void uart_init1(u32 bound){
  4.         //GPIO端口设置
  5.         GPIO_InitTypeDef GPIO_InitStructure;
  6.         USART_InitTypeDef USART_InitStructure;
  7.         NVIC_InitTypeDef NVIC_InitStructure;
  8.         USART_DeInit(USART1);  //复位串口1
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);        //使能USART1,GPIOA时钟
  10.
  11.                         //USART1_TX   PA.9
  12.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
  15.         GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9
  16.         //USART1_RX          PA.10
  17.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  18.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  19.         GPIO_Init(GPIOA, &GPIO_InitStructure);  //初始化PA10
  20.         //Usart1 NVIC 配置
  21.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  22.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
  23.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
  24.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
  25.         NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
  26.         //USART 初始化设置
  27.         USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
  28.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
  29.         USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
  30.         USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
  31.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
  32.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
  33.         USART_Init(USART1, &USART_InitStructure); //初始化串口
  34.         USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断
  35.         USART_ITConfig(USART1, USART_IT_TC  , ENABLE);
  36.
  37.         USART_Cmd(USART1, ENABLE);                    //使能串口
  38.         memset( &HostTxRxData, 0, sizeof(HostTxRxData));
  39.         //USART_ClearFlag( USART1, USART_IT_TC );
  40.
  41. }
我是这样配置的一样不行
diweo 发表于 2020-6-30 16:23 | 显示全部楼层
发就发了呗,如果因为接收了这个0而导致程序异常,那只能说这个程序写得太烂了。
updownq 发表于 2023-2-2 09:37 | 显示全部楼层
是不是在串口上连接了什么负载
pmp 发表于 2023-2-4 14:03 | 显示全部楼层
上电时状态不太稳定造成的,解决办法是程序开始加一个几十毫秒的延时。
kmzuaz 发表于 2023-2-4 21:24 | 显示全部楼层
初始化程序有问题。
kkzz 发表于 2023-2-6 12:30 | 显示全部楼层
上电初始值有问题
caigang13 发表于 2023-2-6 12:31 来自手机 | 显示全部楼层
这种情况肯定是你的软件问题了
saservice 发表于 2023-2-6 13:41 | 显示全部楼层
串口助手的波特率和单片机设置的是否一致?
elsaflower 发表于 2023-2-7 20:49 | 显示全部楼层
串口波特率和晶振计算的是否准确?
软核硬核 发表于 2023-2-8 10:58 | 显示全部楼层
确实有这个问题,好像很多开发板都是这样的问题。
LLGTR 发表于 2023-2-8 10:59 | 显示全部楼层
pattywu 发表于 2013-10-12 18:28
10楼说的对,先初始化USART寄存器,等过了一个字符的发送时间再,再初始化TX引脚。
    ST的参考手册上 ...
下回试试,之前都忽略了这个0数据了。
天天向善 发表于 2023-2-8 11:00 | 显示全部楼层
软件问题,抓波形好像能抓到这个0数据。
febgxu 发表于 2023-2-8 17:08 | 显示全部楼层
那是起始位,每次用串口通讯时都会这样先发送‘0’
abotomson 发表于 2023-2-8 21:37 | 显示全部楼层
应该是你发送端口和一个高电平电源短路了。
cjl504 发表于 2023-2-10 08:53 来自手机 | 显示全部楼层
应该是硬件问题,我以前遇到过
SantaBunny 发表于 2023-2-11 10:40 | 显示全部楼层
应该是你硬件的问题
eefas 发表于 2023-2-14 11:28 | 显示全部楼层
接收端是浮空,发送端是复用推挽输出了吧。
sanfuzi 发表于 2023-2-14 11:41 | 显示全部楼层
上电瞬间,电平的变化导致的
minzisc 发表于 2023-2-16 13:35 | 显示全部楼层
低为start bit, 高为stop bit,另一端的串口误认为这是一次串口传输,又由于TX一直保持低到串口初始化,所以数据被识别为0x00
