[STM32F0] STM32之TIM3_PWM程序
1103|3
 楼主| cowboy2014 发表于 2016-11-20 16:30 | 显示全部楼层 |阅读模式
原理图:
调PB5的亮度
程序分析:
  1. int main(void)
  3.         unsigned char a=0;
  4.         TIM_OCInitTypeDef  TIM3_OCInitStructure;
  5.           RCC_Configuration();
  6.           time_ini();
  7.     SysTick_Config(72000);          //配置SYSTICK时钟节拍为1ms一次
  8.           while(1){
  9.                   Delay(1);                 //延时1ms
  10.                 TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                                          //PWM模式2
  11.                   TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;                  //输出禁止
  12.                   TIM3_OCInitStructure.TIM_Pulse = CCR2_Val;                                                          //确定占空比
  13.                   TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  14.                   TIM_OC2Init(TIM3, &TIM3_OCInitStructure);
  15.                   /*调整CCR2_Val的值来改变占空比,逐步的控制LED1的亮度, 占空比大过一定值时,
  16.                 亮度的变化就不明显了,所以CCR2_VAL最大设定到17000*/
  17.                 if(a==0) CCR2_Val=CCR2_Val+10;
  18.                 else CCR2_Val=CCR2_Val-10;
  19.                 if(CCR2_Val>17000){ CCR2_Val=17000; a=1;}
  20.                 else if(CCR2_Val<200){ CCR2_Val=200; a=0;}
  21.           }
  22. }
 楼主| cowboy2014 发表于 2016-11-20 16:31 | 显示全部楼层
时钟初始化打开RCC_APB2Periph_AFIO ,RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOCD| RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE
  1. void RCC_Configuration(void){
  2.   SystemInit();
  3.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  4.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
  5.                                                   | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE , ENABLE);
  6. }
配置初始化,初始化PB5为复用输出,TIM3部分映射到PB5,设置PWM的时钟为72M/(3*2400)=10K,初始化TIM3时钟,
占空比为CCR2_Val /(TIM_Period  +1)
 楼主| cowboy2014 发表于 2016-11-20 16:32 | 显示全部楼层
  1. void time_ini(void){
  2.   GPIO_InitTypeDef GPIO_InitStructure;
  3.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  4.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                                                //PB5复用为TIM3的通道2
  5.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  6.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  7.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  8.   /*TIM3局部复用功能开启        在TIM3的局部复用开启时,PB5会被复用为TIM3_CH2*/
  9.   GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3 , ENABLE);        //TIM3部分映射到PB5
  10.
  11.    /*-------------------------------------------------------------------
  12.   TIM3CLK=72MHz  预分频系数Prescaler=2 经过分频 定时器时钟为24MHz
  13.   根据公式 通道输出占空比=TIM3_CCR2/(TIM_Period+1),可以得到TIM_Pulse的计数值
  14.   捕获/比较寄存器2 TIM3_CCR2= CCR2_Val
  15.   -------------------------------------------------------------------*/
  16.   TIM3_TimeBaseStructure.TIM_Prescaler = 2;                                                   //预分频器TIM3_PSC=3                24M
  17.   TIM3_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                //计数器向上计数模式 TIM3_CR1[4]=0
  18.   TIM3_TimeBaseStructure.TIM_Period =2399;                                           //自动重装载寄存器TIM3_APR  确定频率为10KHz
  19.   TIM3_TimeBaseStructure.TIM_ClockDivision = 0x0;                                        //时钟分频因子 TIM3_CR1[9:8]=00
  20.   TIM3_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  21.   TIM_TimeBaseInit(TIM3,&TIM3_TimeBaseStructure);                                        //写TIM3各寄存器参数
  22.
 楼主| cowboy2014 发表于 2016-11-20 16:33 | 显示全部楼层
  1. TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                            //PWM模式2 TIM3_CCMR1[14:12]=111 在向上计数时,
  2.        //一旦TIMx_CNT<TIMx_CCR1时通道1为无效电平,否则为有效电平
  3.   TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;    //输入/捕获2输出允许  OC2信号输出到对应的输出引脚PB5
  4.   TIM3_OCInitStructure.TIM_Pulse = CCR2_Val;                                            //确定占空比,这个值决定了有效电平的时间。
  5.   TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;            //输出极性  低电平有效 TIM3_CCER[5]=1;
  6.
  7.   TIM_OC2Init(TIM3, &TIM3_OCInitStructure);
  8.   TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  9.   TIM_Cmd(TIM3,ENABLE);        //启动定时器3 TIM3_CR1[0]=1;
  10. }
  11.     SysTick_Config(72000);          //配置SYSTICK时钟节拍为1ms一次
  12.         while(1){
  13.                   Delay(1);                 //延时1ms
  14.                 TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                                          //PWM模式2
  15.                   TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;                  //输出禁止
  16.                   TIM3_OCInitStructure.TIM_Pulse = CCR2_Val;                                                          //确定占空比
  17.                   TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  18.                   TIM_OC2Init(TIM3, &TIM3_OCInitStructure);
  19.                   /*调整CCR2_Val的值来改变占空比,逐步的控制LED1的亮度, 占空比大过一定值时,
  20.                 亮度的变化就不明显了,所以CCR2_VAL最大设定到17000*/
  21.                 if(a==0) CCR2_Val=CCR2_Val+10;
  22.                 else CCR2_Val=CCR2_Val-10;
  23.                 if(CCR2_Val>17000){ CCR2_Val=17000; a=1;}
  24.                 else if(CCR2_Val<200){ CCR2_Val=200; a=0;}
  25.           }
