- package message
- import (
-         "container/list"
-         "data_manager"
-         "encoding/json"
-         "errors"
-         "fmt"
-         "sync"
-         "github.com/pojoin/golis"
- var once sync.Once
- type CommandProperty int
- type Command interface {
-         //BuildResponse(info interface{}) (string, error)
-         CommandHandle(session *golis.Iosession, CmdInfo interface{}) error
-         GetCommandName() string
-         IsProvidedResult() bool
- type CommandAttribute struct {
-         CommandName      string
-         IsProvidedResult bool //CommandProperty
- ////////////////////////////dmc  command ////////////////////////////
- ////////////////////// dmc_register  /////////////////////
- type DmcRegist struct {
-         Command string `json:"command"`
-         MsgId   string `json:"msg_id"`
-         RoomId  int32  `json:"room_id"`
- type DmcCommandRegist struct {
-         cmdAtt CommandAttribute
- //////////////////////  dmc_heart_beat  //////////////////
- type DmcHeartBeat struct {
-         DmcId   int32  `json:"dmc_id"`
- type DmcCommandHeartBeat struct {
- ////////////////////// dmc_unregister //////////////////
- type DmcUnregister struct {
- type DmcCommandUnregister struct {
- ////////////////////// dmc_stream_query //////////////////
- type DmcStreamQuery struct {
-         StreamName string `json:"stream_name"`
- type DmcCommandStreamQuery struct {
- ////////////////// dmc _all_stream_update ////////////////
- type DmcAllStreamUpdate struct {
-         StreamInfoList []data_manager.StreamAttributes `json:"stream_info"`
- type DmcCommandAllStreamUpdate struct {
- ////////////////// dmc _capability_update ////////////////
- type DmcCapabilityUpdate struct {
-         Cap     Capability        `json:"capability"`
-         NCap    NetworkCapability `json:"network_capability"`
-         Ld      Load              `json:"load"`
-         NLd     NetworkLoad       `json:"network_load"`
- type DmcCommandCapabilityUpdate struct {
- //////////////////// dmc _stream_ update ////////////////
- type DmcStreamUpdate struct {
-         ////////////////// StreamAttributes /////////////////
-         Operate    data_manager.StreamOperate   `json:"operate"`
-         Name       string                       `json:"stream_name"`
-         Status     data_manager.StreamState     `json:"status"`
-         Attributes data_manager.StreamAttribute `json:"attributes"`
-         Type       data_manager.StreamType      `json:"type"`
-         DmsInfo    []string                     `json:"dms_info"`
- type DmcCommandStreamUpdate struct {
- //////////////////// dmc_get_dms_request ////////////////
- type DmcGetDmsRequest struct {
- type DmcCommandGetDmsRequest struct {
- ////////// dmc_get_dms_response /////////////
- type DmcGetDmsResponse struct {
- type DmcCommandGetDmsResponse struct {
- //////////////////////////   gmc request & response   /////////////////////////////
- func AddFrameTail(input []byte) []byte {
-         buf := make([]byte, len(input)+1)
-         copy(buf, input[:])
-         buf[len(input)] = 0x00
-         return buf
- func JsonMarshal(msgStruct interface{}) ([]byte, error) {
-         b, err := json.Marshal(msgStruct)
-         if err != nil {
-                 fmt.Println("encoding faild")
-                 return nil, errors.New("encoding faild")
-         } else {
-                 fmt.Println("encoded data : ")
-                 //fmt.Println(b)
-                 fmt.Println(string(b))
-         return b, err
- type GmcMessage interface {
-         BuildMessage() ([]byte, error)
- /////// gmc_reg_response ///////
- type GmcRegResponse struct {
- func (gm *GmcRegResponse) BuildMessage() ([]byte, error) {
-         //gmcRegResponse := &GmcRegResponse{"gmc_reg_response", gm.MsgId, gm.DmcId}
-         b, err := JsonMarshal(*gm)
-         if b == nil {
-                 return b, err
-         buf := AddFrameTail(b)
-         return buf, nil
- /////// gmc_response ///////
- type GmcResponse struct {
- func (gm *GmcResponse) BuildMessage() ([]byte, error) {
-         //gmcResponse := &GmcResponse{"gmc_response", gm.MsgId}
-         if b == nil {
-                 return b, err
-         return buf, nil
- /////// gmc_stream_query_result ///////
- type GmcStreamQueryResult struct {
-         Result     string     `json:"result"`
-         DmsInfo    *list.List `json:"dms_info"`
- func (gm *GmcStreamQueryResult) BuildMessage() ([]byte, error) {
-         if b == nil {
-                 return b, err
-         return buf, nil
- //////// gmc_get_dms_request //////////
- type GmcGetDmsRequest struct {
- func (gm *GmcGetDmsRequest) BuildMessage() ([]byte, error) {
-         //gmcResponse := &GmcGetDmsRequest{"gmc_get_dms_request", gm.MsgId}
-         if b == nil {
-                 return b, err
-         return buf, nil
- /////////// gmc_get_dms_response /////////
- type GmcGetDmsResponse struct {
- func (gm *GmcGetDmsResponse) BuildMessage() ([]byte, error) {
-         if b == nil {
-                 return b, err
-         return buf, nil
- /////// gmc_stream_published_notify //////
- type GmcStreamPublishedNotify struct {
- func (gm *GmcStreamPublishedNotify) BuildMessage() ([]byte, error) {
-         if b == nil {
-                 return b, err
-         return buf, nil
- /////////// func BuildGmcMessage ////////////
- func BuildGmcMessage(gmcMsg GmcMessage) ([]byte, error) {
-         msg, err := gmcMsg.BuildMessage()
-         if err != nil {
-                 return nil, err
-         return msg, nil
- func (dcr *DmcCommandRegist) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("register command handle ........ ")
-         cmd := CmdInfo.(*DmcRegist)
-         fmt.Println("cmd:", cmd.Command, " msgid:", cmd.MsgId, " roomid:", cmd.RoomId)
-         dmc_instance := data_manager.GetDmcInstance()
-         dmc_id := dmc_instance.GetDmcId()
-         dmc_info := data_manager.DmcInfo{dmc_id, list.New(), list.New(), cmd.RoomId, session}
-         dmc_instance.AddDmcInfo(dmc_id, dmc_info)
-         gmcResponse := &GmcRegResponse{"gmc_reg_response", cmd.MsgId, dmc_id}
-         buf, err := BuildGmcMessage(gmcResponse)
-         if err != nil {
-                 return err
-         fmt.Println("------------- Session write frame: ---")
-         session.Write(buf)
-         return nil
- func (dcr *DmcCommandRegist) GetCommandName() string {
-         return dcr.cmdAtt.CommandName
- func (dcr *DmcCommandRegist) IsProvidedResult() bool {
-         return dcr.cmdAtt.IsProvidedResult
- ///////////////////// dmc_heart_beat ////////////////////////
- func (dcr *DmcCommandHeartBeat) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("heart beat command handle ........ ")
-         cmd := CmdInfo.(*DmcHeartBeat)
-         fmt.Println("cmd:", cmd.Command, " msgid:", cmd.MsgId, " dmcid:", cmd.DmcId)
-         return nil
- func (dcr *DmcCommandHeartBeat) GetCommandName() string {
- func (dcr *DmcCommandHeartBeat) IsProvidedResult() bool {
- func (dcr *DmcCommandUnregister) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("unregister command handle ........ ")
-         cmd := CmdInfo.(*DmcUnregister)
-         dmc_instance.DelDmcInfo(cmd.DmcId)
-         gmcResponse := &GmcResponse{"gmc_response", cmd.MsgId}
-         if err != nil {
-                 return err
-         return nil
- func (dcr *DmcCommandUnregister) GetCommandName() string {
- func (dcr *DmcCommandUnregister) IsProvidedResult() bool {
- func (dcr *DmcCommandStreamQuery) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("stream query command handle ........ ")
-         cmd := CmdInfo.(*DmcStreamQuery)
-         fmt.Println("cmd:", cmd.Command, " msgid:", cmd.MsgId, " dmcid:", cmd.DmcId, "streamname:", cmd.StreamName)
-         stream_instance := data_manager.GetStreamInstance()
-         stream_info, result := stream_instance.GetStreamInfo(cmd.StreamName)
-         var queryresponse *GmcStreamQueryResult
-         if result == true {
-                 queryresponse = &GmcStreamQueryResult{"gmc_stream_query_result", cmd.MsgId, "Found", cmd.StreamName, stream_info.DmsInfo}
-         } else {
-                 queryresponse = &GmcStreamQueryResult{"gmc_stream_query_result", cmd.MsgId, "Not Found", cmd.StreamName, nil}
-         b, err := json.Marshal(queryresponse)
-         if err != nil {
-                 return errors.New("encoding faild")
-         } else {
-                 //fmt.Println(b)
-         buf := make([]byte, len(b)+1)
-         copy(buf, b[:])
-         buf[len(b)] = 0x00
-         return nil
- func (dcr *DmcCommandStreamQuery) GetCommandName() string {
- func (dcr *DmcCommandStreamQuery) IsProvidedResult() bool {
- ////////////////// dmc_all_stream_update ////////////////
- func (dcr *DmcCommandAllStreamUpdate) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("all stream  update command handle ........ ")
-         cmd := CmdInfo.(*DmcAllStreamUpdate)
-         fmt.Printf("------------------ len=%d cap=%d slice=%v\n", len(cmd.StreamInfoList), cap(cmd.StreamInfoList), cmd.StreamInfoList)
-         fmt.Println("cmd:", cmd.Command, " dmc id:", cmd.DmcId, " msg id:", cmd.MsgId)
-         stream_lst := cmd.StreamInfoList
-         for _, stream_info := range stream_lst {
-                 temp_stream_info := data_manager.NewStreamInfo(stream_info.Name, cmd.DmcId, stream_info.State, stream_info.Attributes, stream_info.Type, list.New())
-                 stream_instance.AddStreamInfo(stream_info.Name, temp_stream_info)
-         if err != nil {
-                 return err
-         return nil
- func (dcr *DmcCommandAllStreamUpdate) GetCommandName() string {
- func (dcr *DmcCommandAllStreamUpdate) IsProvidedResult() bool {
- ////////////////// dmc_capability_update ////////////////
- func (dcr *DmcCommandCapabilityUpdate) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("capability  update command handle ........ ")
-         cmd := CmdInfo.(*DmcCapabilityUpdate)
-         fmt.Println("cmd:", cmd.Command, " msgid:", cmd.MsgId, " dmcid:", cmd.DmcId, " cap item:", cmd.Cap.Item, " ld item", cmd.Ld.Item, " nld item:", cmd.NLd.Item)
-         return nil
- func (dcr *DmcCommandCapabilityUpdate) GetCommandName() string {
- func (dcr *DmcCommandCapabilityUpdate) IsProvidedResult() bool {
- //////////////////// dmc_stream_update ////////////////
- func (dcr *DmcCommandStreamUpdate) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("stream  update command handle ........ ")
-         cmd := CmdInfo.(*DmcStreamUpdate)
-         fmt.Println(" cmd:", cmd.Command, " dmc id:", cmd.DmcId, " msg id:", cmd.MsgId, " stream name:", cmd.Name)
-         if cmd.Operate == data_manager.ADDStream {
-                 temp_stream_info := data_manager.NewStreamInfo(cmd.Name, cmd.DmcId, cmd.Status, cmd.Attributes, cmd.Type, list.New())
-                 stream_instance.AddStreamInfo(cmd.Name, temp_stream_info)
-         } else if cmd.Operate == data_manager.DELStream {
-                 stream_instance.DelStreamInfo(cmd.Name)
-         } else {
-                 stream_instance.ModStreamInfo(cmd.Name, temp_stream_info)
-         if err != nil {
-                 return err
-         return nil
- func (dcr *DmcCommandStreamUpdate) GetCommandName() string {
- func (dcr *DmcCommandStreamUpdate) IsProvidedResult() bool {
- func (dcr *DmcCommandGetDmsRequest) CommandHandle(session *golis.Iosession, CmdInfo interface{}) error {
-         fmt.Println("get dms request command handle ........ ")
-         cmd := CmdInfo.(*DmcGetDmsRequest)
-         fmt.Println(" cmd:", cmd.Command, " msg id:", cmd.MsgId, " dmc id:", cmd.DmcId)
-         dmcManager := data_manager.GetDmcInstance()
-         dmc, err1 := dmcManager.GetDmc(data_manager.GET_A_USEFUL_DMS)
-         if err1 != nil {
-                 return errors.New("source dmc session is nil")
-         session_source_dmc := dmc.Session
-         gmcGetDmsRequest := &GmcGetDmsRequest{"gmc_get_dms_request", cmd.MsgId}
-         buf, err := BuildGmcMessage(gmcGetDmsRequest)
-         if err != nil {
-                 return err
-         fmt.Println("------------- Session write gmcGetDmsRequest frame: ---")
-         session_source_dmc.Write(buf)
-         return nil
- func (dcr *DmcCommandGetDmsRequest) GetCommandName() string {
- func (dcr *DmcCommandGetDmsRequest) IsProvidedResult() bool {
