[应用相关] EMWIN526+T6963
1384|4
 楼主| 七颗咖啡豆 发表于 2016-12-19 10:13 | 显示全部楼层 |阅读模式
我看了手册,emwin自带6963的驱动,不知怎样用起来。
大腿大腿
 楼主| 七颗咖啡豆 发表于 2016-12-19 10:16 | 显示全部楼层
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
*        (c) 1996 - 2014  SEGGER Microcontroller GmbH & Co. KG       *
*        Internet: www.segger.com    Support:  support@segger.com    *
** emWin V5.26 - Graphical user interface for embedded applications **
All  Intellectual Property rights  in the Software belongs to  SEGGER.
emWin is protected by  international copyright laws.  Knowledge of the
source code may not be used to write a similar product.  This file may
only be used in accordance with the following terms:
The software has been licensed to  ARM LIMITED whose registered office
is situated at  110 Fulbourn Road,  Cambridge CB1 9NJ,  England solely
for  the  purposes  of  creating  libraries  for  ARM7, ARM9, Cortex-M
series,  and   Cortex-R4   processor-based  devices,  sublicensed  and
distributed as part of the  MDK-ARM  Professional  under the terms and
conditions  of  the   End  User  License  supplied  with  the  MDK-ARM
Professional.
Full source code is available at: www.segger.com
We appreciate your understanding and fairness.
File        : LCDConf.c
Purpose     : Display controller configuration, sample
Display     : T240128
---------------------------END-OF-HEADER------------------------------
#include "GUI.h"
#include "GUIDRV_SLin.h"
#ifndef WIN32
// #include "LCD_X_8080.h"
  #include "lcd6963.h"
#endif
*       Configuration
// Physical display size
#define XSIZE 240
#define YSIZE 128
// Color conversion
#define COLOR_CONVERSION GUICC_1
// Display driver
#define DISPLAY_DRIVER GUIDRV_SLIN_1
*       Static data
#ifndef WIN32
  GUI_PORT_API _PortAPI;
#endif
*       Static code
#define CMD_SET_ADDR   0x24
#define CMD_WRITE1     0xC0
#define CMD_AUTO_WRITE 0xB0
#define CMD_AUTO_READ  0xB1
#define CMD_AUTO_RESET 0xB2
#define LCD_RAMSIZE (0x2000)
#define LCD_GSTART  (0x0)
#define LCD_XSIZEB  ((XSIZE + 7) >> 3)
#define LCD_TSTART  (LCD_RAMSIZE - (LCD_XSIZEB) - (YSIZE >> 3))
void LCD_X_Init()
        LCD_PortConfig();//IO
        LCD_FSMCConfig();//FMSC
        LCD_Reset();//硬件复位
void LCD_X_Write00(uint8_t da)
        LCD_DAT_ADDR = da;
void LCD_X_Write01(uint8_t da)
        LCD_CMD_ADDR = da;
void LCD_X_WriteM00(uint8_t *pData, int length)
        while(length--){
                LCD_X_Write00(*pData++);
uint8_t LCD_X_Read00()
        return LCD_DAT_ADDR ;
*       _SetAddr
#ifndef WIN32
static void _SetAddr(U32 Off) {
  _PortAPI.pfWrite8_A0(Off & 0xff);
  _PortAPI.pfWrite8_A0(Off >> 8);
  _PortAPI.pfWrite8_A1(CMD_SET_ADDR);
*       _InitController
* Purpose:
*   Initializes the display controller
static void _InitController(void) {
  int i;
  LCD_X_Init();
  _SetAddr(0);
  for (i = 0; i < 100; i++) {
    _PortAPI.pfWrite8_A0(0xff);
    _PortAPI.pfWrite8_A1(CMD_WRITE1);
  _SetAddr(0);
  for (i = 0; i < LCD_RAMSIZE; i++) {
    _PortAPI.pfWrite8_A0(0x0);
  _PortAPI.pfWrite8_A1(0x81);           // SetModeXor
  _PortAPI.pfWrite8_A0((U8)LCD_TSTART);// SetTextAdr
  _PortAPI.pfWrite8_A0((U8)(LCD_TSTART >> 8));
  _PortAPI.pfWrite8_A1(0x40);
  _PortAPI.pfWrite8_A0(1);             // SetTextArea
  _PortAPI.pfWrite8_A0(1 >> 8);
  _PortAPI.pfWrite8_A1(0x41);
  _PortAPI.pfWrite8_A1(0x9C);           // SetTextGraph
  _PortAPI.pfWrite8_A0(LCD_GSTART);    // SetGraphAdr
  _PortAPI.pfWrite8_A0(LCD_GSTART >> 8);
  _PortAPI.pfWrite8_A1(0x42);
  _PortAPI.pfWrite8_A0(LCD_XSIZEB);    // SetGraphArea
  _PortAPI.pfWrite8_A0(LCD_XSIZEB >> 8);
  _PortAPI.pfWrite8_A1(0x43);
#endif
*       Public code
*       LCD_X_DisplayDriver
* Purpose:
*   This function is called by the display driver for several purposes.
*   To support the according task the routine needs to be adapted to
*   the display controller. Please note that the commands marked with
*   'optional' are not cogently required and should only be adapted if
*   the display controller supports these features.
* Parameter:
*   LayerIndex - Index of layer to be configured
*   Cmd        - Please refer to the details in the switch statement below
*   pData      - Pointer to a LCD_X_DATA structure
* Return Value:
*   < -1 - Error
*     -1 - Command not handled
*      0 - Ok
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
  int r;
  GUI_USE_PARA(LayerIndex);
  GUI_USE_PARA(pData);
  switch (Cmd) {
  // Required
  case LCD_X_INITCONTROLLER: {
    // Called during the initialization process in order to set up the
    // display controller and put it into operation. If the display
    // controller is not initialized by any external routine this needs
    // to be adapted by the customer...
    // Nothing done here, see 'LCD_X_ON'.
    #ifndef WIN32
      _InitController();
    #endif
    return 0;
  default:
    r = -1;
  return r;
*       LCD_X_Config
* Purpose:
*   Called during the initialization process in order to set up the
*   display driver configuration.
void LCD_X_Config(void) {
  GUI_DEVICE * pDevice;
  // Set display driver and color conversion
  pDevice = GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);
  // Common display driver configuration
  LCD_SetSizeEx(0, XSIZE, YSIZE);
  LCD_SetVSizeEx(0, XSIZE, YSIZE);
  // Set driver specific configuration items
  #ifndef WIN32
    CONFIG_SLIN Config = {0};
    // Setup hardware access routines
    _PortAPI.pfWrite8_A0  = LCD_X_Write00;
    _PortAPI.pfWrite8_A1  = LCD_X_Write01;
    _PortAPI.pfWriteM8_A0 = LCD_X_WriteM00;
    _PortAPI.pfRead8_A0   = LCD_X_Read00;
    GUIDRV_SLin_SetBus8(pDevice, &_PortAPI);
    // Pass configuration structure to driver
    Config.UseCache  = 1;
    Config.CheckBusy = 1;
    GUIDRV_SLin_Config(pDevice, &Config);
    // Set controller
    GUIDRV_SLin_SetT6963(pDevice);
  #endif
/*************************** End of file ****************************/
 楼主| 七颗咖啡豆 发表于 2016-12-19 10:18 | 显示全部楼层
然后就是
GUIDRV_SLin_1_API;
GUIDRV_SLin_Config;
GUIDRV_SLin_SetBus8;
四个函数找不到
 楼主| 七颗咖啡豆 发表于 2016-12-19 11:24 | 显示全部楼层
估计是.lib 里面没有
 楼主| 七颗咖啡豆 发表于 2016-12-19 11:33 | 显示全部楼层
难道这些函数也要用户实现么?
