/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technology Corp. // E-mail: MicroC-8bit@nuvoton.com //*********************************************************************************************************** // Application: ADC Function // ADC Channel 0(P0.1 default) as ADC input // // Output : UART show ADC output result on hyper-terminal //*********************************************************************************************************** //------------------------- <<< Use Configuration Wizard in Context Menu >>> -------------------------------- // <o0.6> UART pin Select // <0=> Select P1.0, P1.1 as UART pin(default) // <1=> Select P2.6, P2.7 as UART pin(28 pin only) //-------------------------------- <<< end of configuration section >>> ------------------------------------- #define Uart_Port_Sel 0x00 #include "N79E715.h" #include "Typedef.h" #include "Define.h" #include "Common.h" #include "Delay.h" #include "ADC.h" #include "Version.h" #include <intrins.h> #include <stdio.h> #include <string.h> //----------------------------------------------------------------------------------------------------------- void Enable_ADC_Interrupt(void) { EADC = 1; EA = 1; } //----------------------------------------------------------------------------------------------------------- void ADC_Channel_Sel(E_ADCCNL_SEL channel) { switch (channel) { case E_CHANNEL0: // P0.1 (default) clr_AADR2; clr_AADR1; clr_AADR0; break; case E_CHANNEL1: // P0.2 clr_AADR2; clr_AADR1; set_AADR0; break; case E_CHANNEL2: // P0.3 clr_AADR2; set_AADR1; clr_AADR0; break; case E_CHANNEL3: // P0.4 clr_AADR2; set_AADR1; set_AADR0; break; case E_CHANNEL4: // P0.5 set_AADR2; clr_AADR1; clr_AADR0; break; case E_CHANNEL5: // P0.6 set_AADR2; clr_AADR1; set_AADR0; break; case E_CHANNEL6: // P0.7 set_AADR2; set_AADR1; clr_AADR0; break; case E_CHANNEL7: // P2.6 set_AADR2; set_AADR1; set_AADR0; break; } } //----------------------------------------------------------------------------------------------------------- void Set_ADC_Input_Mode(E_ADCCNL_SEL channel) { switch (channel) { case E_CHANNEL0: // ADC0(P0.1) is input-only mode P0DIDS |= SET_BIT1; // Disable digital function for P0.1 P0M1 |= SET_BIT1; P0M2 &= CLR_BIT1; break; case E_CHANNEL1: // ADC1(P0.2) is input-only mode P0DIDS |= SET_BIT2; // Disable digital function for P0.2 P0M1 |= SET_BIT2; P0M2 &= CLR_BIT2; break; case E_CHANNEL2: // ADC2(P0.3) is input-only mode P0DIDS |= SET_BIT3; // Disable digital function for P0.3 P0M1 |= SET_BIT3; P0M2 &= CLR_BIT3; break; case E_CHANNEL3: // ADC3(P0.4) is input-only mode P0DIDS |= SET_BIT4; // Disable digital function for P0.4 P0M1 |= SET_BIT4; P0M2 &= CLR_BIT4; break; case E_CHANNEL4: // ADC4(P0.5) is input-only mode P0DIDS |= SET_BIT5; // Disable digital function for P0.5 P0M1 |= SET_BIT5; P0M2 &= CLR_BIT5; break; case E_CHANNEL5: // ADC5(P0.6) is input-only mode P0DIDS |= SET_BIT6; // Disable digital function for P0.6 P0M1 |= SET_BIT6; P0M2 &= CLR_BIT6; break; case E_CHANNEL6: // ADC6(P0.7) is input-only mode P0DIDS |= SET_BIT7; // Disable digital function for P0.7 P0M1 |= SET_BIT7; P0M2 &= CLR_BIT7; break; case E_CHANNEL7: // ADC7(P2.6) is input-only mode(28 pin only) AUXR1 |= SET_BIT3; // Disable digital function for P2.6 P2M1 |= SET_BIT6; P2M2 &= CLR_BIT6; break; } } //----------------------------------------------------------------------------------------------------------- void Trigger_ADC_Convertion(void) { clr_ADCI; // Clear ADC flag (ADCI=0) set_ADCS; // ADC run (ADCS = 1) PCON |= SET_BIT0; // Enter idle mode } //----------------------------------------------------------------------------------------------------------- void ADC_Init(void) { Set_ADC_Input_Mode(E_CHANNEL0); // Set ADC0 (P0.1 default) is input only mode ADC_Channel_Sel(E_CHANNEL0); // ADC Channel Select (P0.1 default) Enable_ADC_Interrupt(); set_ADCEN; // Enable ADC Function } //----------------------------------------------------------------------------------------------------------- void main(void) { UINT16 u16ADCL; UINT16 u16ADC; AUXR1 |= Uart_Port_Sel; // Select P10/P11 as UART pin(default) InitialUART0_Timer1(9600); // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz Show_Version_Number_To_PC(); printf ("\n*==================================================================="); printf ("\n* Name: N79E715 Series ADC Sample Code."); printf ("\n*==================================================================="); ADC_Init(); while(1) { Trigger_ADC_Convertion(); u16ADCL = ADCCON0; u16ADCL = u16ADCL >> 6; // ADC[1:0] u16ADC = ADCH; u16ADC = (u16ADC << 2 ) + u16ADCL; // ADC[9:2] + ADC[1:0] printf ("\nADC Value = %d",u16ADC); // Show 10 bit ADC Delay1ms(500); } } //----------------------------------------------------------------------------------------------------------- void ADC_ISR(void) interrupt 11 // Vector @ 0x5B { clr_ADCI; // Clear ADC flag (ADCI = 0) clr_ADCS; // ADC stop (ADCS = 0) } //-----------------------------------------------------------------------------------------------------------
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
时间类勋章
人才类勋章
发帖类勋章
223
3792
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
