使用F745+CY7C68003(USB PHY) ,USB HS通信,单发现枚举不到设备。 请ST的工程师给出帮助。 Thansk
附件是部分原理图和代码。系统晶振26mhz,stm32的vcc1.8v- void Stm32_Clock_Init(u32 plln,u32 pllm,u32 pllp,u32 pllq)
- HAL_StatusTypeDef ret = HAL_OK;
- RCC_OscInitTypeDef RCC_OscInitStructure;
- RCC_ClkInitTypeDef RCC_ClkInitStructure;
- RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
- __HAL_RCC_PWR_CLK_ENABLE();
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- RCC_OscInitStructure.OscillatorType=RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStructure.HSEState=RCC_HSE_ON;
- RCC_OscInitStructure.PLL.PLLState=RCC_PLL_ON;
- RCC_OscInitStructure.PLL.PLLSource=RCC_PLLSOURCE_HSE;
- RCC_OscInitStructure.PLL.PLLM=pllm;
- RCC_OscInitStructure.PLL.PLLN=plln;
- RCC_OscInitStructure.PLL.PLLP=pllp;
- RCC_OscInitStructure.PLL.PLLQ=pllq;
- ret=HAL_RCC_OscConfig(&RCC_OscInitStructure);
- if(ret!=HAL_OK) while(1);
- ret=HAL_PWREx_EnableOverDrive(); //¿ªÆôOver-Driver¹¦ÄÜ
- /* Select PLLSAI output as USB clock source */
- PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_CLK48;
- PeriphClkInitStruct.Clk48ClockSelection = RCC_CLK48SOURCE_PLLSAIP;
- PeriphClkInitStruct.PLLSAI.PLLSAIN = 432;
- PeriphClkInitStruct.PLLSAI.PLLSAIQ = 9;
- PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV2;
- if(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
- while(1) { ; }
- //Ñ¡ÖÐPLL×÷ΪϵͳʱÖÓÔ´²¢ÇÒÅäÖÃHCLK,PCLK1ºÍPCLK2
- RCC_ClkInitStructure.ClockType=(RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2);
- RCC_ClkInitStructure.SYSCLKSource=RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStructure.AHBCLKDivider=RCC_SYSCLK_DIV1;
- RCC_ClkInitStructure.APB1CLKDivider=RCC_HCLK_DIV4;
- RCC_ClkInitStructure.APB2CLKDivider=RCC_HCLK_DIV2;
- ret=HAL_RCC_ClockConfig(&RCC_ClkInitStructure,FLASH_LATENCY_5);
- void CY7C68003_Init(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- __HAL_RCC_GPIOA_CLK_ENABLE();
- __HAL_RCC_GPIOF_CLK_ENABLE();
- //CY7C68003 NRST
- GPIO_InitStruct.Pin=GPIO_PIN_7; //PA7
- GPIO_InitStruct.Mode=GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull=GPIO_NOPULL;
- GPIO_InitStruct.Speed=GPIO_SPEED_HIGH;
- HAL_GPIO_Init(GPIOA,&GPIO_InitStruct);
- //CY7C68003 NCS
- GPIO_InitStruct.Pin=GPIO_PIN_11; //PF11
- HAL_GPIO_Init(GPIOF,&GPIO_InitStruct);
- //RCC_MCO1SOURCE_HSE RCC_MCO1SOURCE_PLLCLK
- HAL_RCC_MCOConfig(RCC_MCO1,RCC_MCO1SOURCE_HSE ,RCC_MCODIV_1); //PA8 MCO1
- HAL_GPIO_WritePin(GPIOA,GPIO_PIN_7,GPIO_PIN_SET);
- HAL_GPIO_WritePin(GPIOF,GPIO_PIN_11,GPIO_PIN_RESET);
- void USB_OTG_BSP_Init(USB_OTG_CORE_HANDLE *pdev)
- __HAL_RCC_GPIOB_CLK_ENABLE();
- __HAL_RCC_GPIOC_CLK_ENABLE();
- __HAL_RCC_USB_OTG_HS_CLK_ENABLE();
- __HAL_RCC_USB_OTG_HS_ULPI_CLK_ENABLE();
- // CLK
- GPIO_InitStruct.Pin = GPIO_PIN_5 ;
- GPIO_InitStruct.Mode=GPIO_MODE_AF_PP;
- GPIO_InitStruct.Alternate=GPIO_AF10_OTG_HS ;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- // D0
- GPIO_InitStruct.Pin = GPIO_PIN_3 ;
- // D1 D2 D3 D4 D5 D6 D7
- GPIO_InitStruct.Pin = GPIO_PIN_0 | GPIO_PIN_1 |
- GPIO_PIN_5 | GPIO_PIN_10 | GPIO_PIN_11| GPIO_PIN_12 |
- GPIO_PIN_13 ;
- HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- // STP DIR NXT
- GPIO_InitStruct.Pin = GPIO_PIN_0 | GPIO_PIN_2 |
- GPIO_PIN_3 ;
- HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
- int main(void)
- Cache_Enable();
- HAL_Init();
- Stm32_Clock_Init(216,26,2,9);
- CY7C68003_Init();
- USBD_Init(&USB_OTG_dev,USB_OTG_FS_CORE_ID,&USR_desc,&USBD_MSC_cb,&USR_cb);
- delay_ms(1800);
- while(1)
