[STM32F7]
F745+CY7C68003(USB PHY),枚举不到设备问题
1015|0
hevenwu|  楼主 | 2017-1-18 09:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
USB, pi, IO, GPIO, gp
使用F745+CY7C68003(USB PHY) ,USB HS通信,单发现枚举不到设备。 请ST的工程师给出帮助。 Thansk
附件是部分原理图和代码。系统晶振26mhz,stm32的vcc1.8v
void Stm32_Clock_Init(u32 plln,u32 pllm,u32 pllp,u32 pllq)
    HAL_StatusTypeDef ret = HAL_OK;
    RCC_OscInitTypeDef RCC_OscInitStructure;
    RCC_ClkInitTypeDef RCC_ClkInitStructure;
          RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
    __HAL_RCC_PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    RCC_OscInitStructure.OscillatorType=RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStructure.HSEState=RCC_HSE_ON;
    RCC_OscInitStructure.PLL.PLLState=RCC_PLL_ON;
    RCC_OscInitStructure.PLL.PLLSource=RCC_PLLSOURCE_HSE;
    RCC_OscInitStructure.PLL.PLLM=pllm;
    RCC_OscInitStructure.PLL.PLLN=plln;
    RCC_OscInitStructure.PLL.PLLP=pllp;
    RCC_OscInitStructure.PLL.PLLQ=pllq;
    ret=HAL_RCC_OscConfig(&RCC_OscInitStructure);
    if(ret!=HAL_OK) while(1);
    ret=HAL_PWREx_EnableOverDrive(); //¿ªÆôOver-Driver¹¦ÄÜ
    /* Select PLLSAI output as USB clock source */
                PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_CLK48;
                PeriphClkInitStruct.Clk48ClockSelection = RCC_CLK48SOURCE_PLLSAIP;
                PeriphClkInitStruct.PLLSAI.PLLSAIN = 432;
                PeriphClkInitStruct.PLLSAI.PLLSAIQ = 9;
                PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV2;
                if(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct)  != HAL_OK)
                        while(1) { ; }
    //Ñ¡ÖÐPLL×÷ΪϵͳʱÖÓÔ´²¢ÇÒÅäÖÃHCLK,PCLK1ºÍPCLK2
    RCC_ClkInitStructure.ClockType=(RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2);
    RCC_ClkInitStructure.SYSCLKSource=RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStructure.AHBCLKDivider=RCC_SYSCLK_DIV1;
    RCC_ClkInitStructure.APB1CLKDivider=RCC_HCLK_DIV4;
    RCC_ClkInitStructure.APB2CLKDivider=RCC_HCLK_DIV2;
    ret=HAL_RCC_ClockConfig(&RCC_ClkInitStructure,FLASH_LATENCY_5);
void CY7C68003_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    __HAL_RCC_GPIOA_CLK_ENABLE();
          __HAL_RCC_GPIOF_CLK_ENABLE();
          //CY7C68003 NRST
    GPIO_InitStruct.Pin=GPIO_PIN_7; //PA7
    GPIO_InitStruct.Mode=GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pull=GPIO_NOPULL;
    GPIO_InitStruct.Speed=GPIO_SPEED_HIGH;
    HAL_GPIO_Init(GPIOA,&GPIO_InitStruct);
          //CY7C68003 NCS
    GPIO_InitStruct.Pin=GPIO_PIN_11; //PF11
    HAL_GPIO_Init(GPIOF,&GPIO_InitStruct);
          //RCC_MCO1SOURCE_HSE  RCC_MCO1SOURCE_PLLCLK
          HAL_RCC_MCOConfig(RCC_MCO1,RCC_MCO1SOURCE_HSE ,RCC_MCODIV_1);                //PA8  MCO1
    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_7,GPIO_PIN_SET);
    HAL_GPIO_WritePin(GPIOF,GPIO_PIN_11,GPIO_PIN_RESET);
void USB_OTG_BSP_Init(USB_OTG_CORE_HANDLE *pdev)
          __HAL_RCC_GPIOB_CLK_ENABLE();
          __HAL_RCC_GPIOC_CLK_ENABLE();
          __HAL_RCC_USB_OTG_HS_CLK_ENABLE();
          __HAL_RCC_USB_OTG_HS_ULPI_CLK_ENABLE();
                // CLK
                GPIO_InitStruct.Pin = GPIO_PIN_5 ;
                GPIO_InitStruct.Mode=GPIO_MODE_AF_PP;
    GPIO_InitStruct.Alternate=GPIO_AF10_OTG_HS ;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
                // D0
                GPIO_InitStruct.Pin = GPIO_PIN_3  ;
                // D1 D2 D3 D4 D5 D6 D7
                GPIO_InitStruct.Pin = GPIO_PIN_0 | GPIO_PIN_1  |
                         GPIO_PIN_5 | GPIO_PIN_10 | GPIO_PIN_11| GPIO_PIN_12 |
                         GPIO_PIN_13 ;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
                // STP DIR NXT
                GPIO_InitStruct.Pin = GPIO_PIN_0  | GPIO_PIN_2  |
                     GPIO_PIN_3 ;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
int main(void)
Cache_Enable();
    HAL_Init();
    Stm32_Clock_Init(216,26,2,9);
CY7C68003_Init();
USBD_Init(&USB_OTG_dev,USB_OTG_FS_CORE_ID,&USR_desc,&USBD_MSC_cb,&USR_cb);
        delay_ms(1800);
        while(1)
stm32f7.pdf
23.75 KB
