[DemoCode下载] NANO112系列的看门狗唤醒
1359|17
 楼主| wahahaheihei 发表于 2017-1-27 14:09 | 显示全部楼层 |阅读模式
穿戴式装置、可携式医疗测量装置、智能家居、无线智能抄表
  1. /******************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 3 $
  5. * $Date: 14/11/25 1:06p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Use WDT to wake up system from Power-down mode periodically.
  7. *
  8. * @note
  9. * Copyright (C) 2013-2014 Nuvoton Technology Corp. All rights reserved.
  10. *****************************************************************************/
  11. #include <stdio.h>
  12. #include "Nano1x2Series.h"
  13. void WDT_IRQHandler(void)
  14. {
  15.     // Clear WDT interrupt flag
  16.     WDT_CLEAR_TIMEOUT_INT_FLAG();
  17.     // Check WDT wake up flag
  18.     if(WDT_GET_TIMEOUT_WAKEUP_FLAG()) {
  19.         printf("Wake up by WDT\n");
  20.         // Clear WDT wake up flag
  21.         WDT_CLEAR_TIMEOUT_WAKEUP_FLAG();
  22.     }
  23. }
  24. void SYS_Init(void)
  25. {
  26.     /*---------------------------------------------------------------------------------------------------------*/
  27.     /* Init System Clock        */
  28.     /*---------------------------------------------------------------------------------------------------------*/
  29.     /* Unlock protected registers */
  30.     SYS_UnlockReg();
  31.     /* Enable External XTAL (4~24 MHz) */
  32.     CLK_EnableXtalRC(CLK_PWRCTL_HXT_EN_Msk);
  33.     /* Enable LIRC */
  34.     CLK_EnableXtalRC(CLK_PWRCTL_LIRC_EN_Msk);
  35.     /* Waiting for 12MHz clock ready */
  36.     CLK_WaitClockReady( CLK_CLKSTATUS_HXT_STB_Msk);
  37.     /* Waiting for LIRC clock ready */
  38.     CLK_WaitClockReady( CLK_CLKSTATUS_LIRC_STB_Msk);
  39.     /* Switch HCLK clock source to HXT */
  40.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT,CLK_HCLK_CLK_DIVIDER(1));
  41.     /* Enable IP clock */
  42.     CLK_EnableModuleClock(UART0_MODULE);
  43.     CLK_EnableModuleClock(WDT_MODULE);
  44.     /* Select IP clock source */
  45.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_UART_CLK_DIVIDER(1));
  46.     CLK_SetModuleClock(WDT_MODULE, 0, 0);
  47.     /* Update System Core Clock */
  48.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  49.     SystemCoreClockUpdate();
  50.     /*---------------------------------------------------------------------------------------------------------*/
  51.     /* Init I/O Multi-function        */
  52.     /*---------------------------------------------------------------------------------------------------------*/
  53.     /* Set GPB multi-function pins for UART0 RXD and TXD */
  54.     SYS->PB_L_MFP &= ~(SYS_PB_L_MFP_PB0_MFP_Msk | SYS_PB_L_MFP_PB1_MFP_Msk);
  55.     SYS->PB_L_MFP |= (SYS_PB_L_MFP_PB0_MFP_UART0_TX | SYS_PB_L_MFP_PB1_MFP_UART0_RX);
  56.     /* Lock protected registers */
  57.     SYS_LockReg();
  58. }
  59. int32_t main (void)
  60. {
  61.     /* Init System, IP clock and multi-function I/O
  62.        In the end of SYS_Init() will issue SYS_LockReg()
  63.        to lock protected register. If user want to write
  64.        protected register, please issue SYS_UnlockReg()
  65.        to unlock protected register if necessary */
  66.     SYS_Init();
  67.     /* Init UART to 115200-8n1 for print message */
  68.     UART_Open(UART0, 115200);
  69.     printf("\nThis sample code demonstrate using WDT to wake system up from power down mode\n");
  70.     // WDT register is locked, so it is necessary to unlock protect register before configure WDT
  71.     SYS_UnlockReg();
  72.     // WDT timeout every 2^14 WDT clock, disable system reset, enable wake up system
  73.     WDT_Open(WDT_TIMEOUT_2POW14, 0, FALSE, TRUE);
  74.     // Enable WDT timeout interrupt
  75.     WDT_EnableInt();
  76.     NVIC_EnableIRQ(WDT_IRQn);
  77.     while(1) {
  78.         // Wait 'til UART FIFO empty to get a cleaner console out
  79.         while(!UART_IS_TX_EMPTY(UART0));
  80.         CLK_PowerDown();
  81.     }
  82. }
  83. /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
、GPS数据记录器、烟感侦测装置、智能三表(水表、燃气表、热表)等
 楼主| wahahaheihei 发表于 2017-1-27 14:20 | 显示全部楼层
    /* Enable LIRC */
配置时钟源后,要等时钟配置完成。
yiyigirl2014 发表于 2017-1-27 14:43 | 显示全部楼层
这个清除标志啊,喂狗就不会中断了。
dongnanxibei 发表于 2017-1-27 15:00 | 显示全部楼层
看门狗唤醒掉电的系统。说明系统的看门狗跟系统是两个独立的
dongnanxibei 发表于 2017-1-27 15:23 | 显示全部楼层
稳稳の幸福 发表于 2017-1-27 15:40 | 显示全部楼层
串口非空,,,接受啊
zhuotuzi 发表于 2017-1-28 10:23 | 显示全部楼层
If user want to write  protected register, please issue SYS_UnlockReg()
mintspring 发表于 2017-1-28 10:39 | 显示全部楼层
看门狗定时器超时中断时钟,打开,设置超时的世界,哈哈。
稳稳の幸福 发表于 2017-1-28 13:12 | 显示全部楼层
如果超时中断发生了,就打印消息。
yiyigirl2014 发表于 2017-1-29 17:35 | 显示全部楼层
我看新唐的单片机看门狗都是类似的
huangcunxiake 发表于 2017-1-30 12:48 | 显示全部楼层
    WDT_EnableInt();
使能看门狗中断,加入中断序列。
dongnanxibei 发表于 2017-1-30 12:59 | 显示全部楼层
定时唤醒,可以用于省电的系统。
 楼主| wahahaheihei 发表于 2017-2-10 16:20 | 显示全部楼层
关于WDT的操作很有限的,在库函数的头文件可以看出来。
 楼主| wahahaheihei 发表于 2017-2-10 17:19 | 显示全部楼层
使用了两种时钟源,分别用于不同的模块。
 楼主| wahahaheihei 发表于 2017-2-10 18:55 | 显示全部楼层
  • void WDT_IRQHandler(void)
  •     // Clear WDT interrupt flag
  •     WDT_CLEAR_TIMEOUT_INT_FLAG();
  •     // Check WDT wake up flag
  •     if(WDT_GET_TIMEOUT_WAKEUP_FLAG()) {
  •         printf("Wake up by WDT\n");
  •         // Clear WDT wake up flag
  •         WDT_CLEAR_TIMEOUT_WAKEUP_FLAG();
这个地方应该算是两个标志位的处理,第一个是WDT超时中断的标志,另外一个是唤醒的中断,也就是发生了看门狗中断后会产生一个标志,因为这个中断系统会重启另外一个标记。。。。
zhuotuzi 发表于 2017-2-11 11:57 | 显示全部楼层
等于这个事件触发了两个标志位置位。
zhuotuzi 发表于 2017-2-11 12:01 | 显示全部楼层
zhuotuzi 发表于 2017-2-11 12:02 | 显示全部楼层
根据这个图才知道要配置哪个时钟。
