[DemoCode下载]
NANO112系列的看门狗唤醒
1187|17
穿戴式装置、可携式医疗测量装置、智能家居、无线智能抄表
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 3 $
* $Date: 14/11/25 1:06p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use WDT to wake up system from Power-down mode periodically.
* @note
* Copyright (C) 2013-2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Nano1x2Series.h"
void WDT_IRQHandler(void)
    // Clear WDT interrupt flag
    WDT_CLEAR_TIMEOUT_INT_FLAG();
    // Check WDT wake up flag
    if(WDT_GET_TIMEOUT_WAKEUP_FLAG()) {
        printf("Wake up by WDT\n");
        // Clear WDT wake up flag
        WDT_CLEAR_TIMEOUT_WAKEUP_FLAG();
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable External XTAL (4~24 MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXT_EN_Msk);
    /* Enable LIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_LIRC_EN_Msk);
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady( CLK_CLKSTATUS_HXT_STB_Msk);
    /* Waiting for LIRC clock ready */
    CLK_WaitClockReady( CLK_CLKSTATUS_LIRC_STB_Msk);
    /* Switch HCLK clock source to HXT */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT,CLK_HCLK_CLK_DIVIDER(1));
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(WDT_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_UART_CLK_DIVIDER(1));
    CLK_SetModuleClock(WDT_MODULE, 0, 0);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->PB_L_MFP &= ~(SYS_PB_L_MFP_PB0_MFP_Msk | SYS_PB_L_MFP_PB1_MFP_Msk);
    SYS->PB_L_MFP |= (SYS_PB_L_MFP_PB0_MFP_UART0_TX | SYS_PB_L_MFP_PB1_MFP_UART0_RX);
    /* Lock protected registers */
    SYS_LockReg();
int32_t main (void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("\nThis sample code demonstrate using WDT to wake system up from power down mode\n");
    // WDT register is locked, so it is necessary to unlock protect register before configure WDT
    SYS_UnlockReg();
    // WDT timeout every 2^14 WDT clock, disable system reset, enable wake up system
    WDT_Open(WDT_TIMEOUT_2POW14, 0, FALSE, TRUE);
    // Enable WDT timeout interrupt
    WDT_EnableInt();
    NVIC_EnableIRQ(WDT_IRQn);
    while(1) {
        // Wait 'til UART FIFO empty to get a cleaner console out
        while(!UART_IS_TX_EMPTY(UART0));
        CLK_PowerDown();
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
、GPS数据记录器、烟感侦测装置、智能三表(水表、燃气表、热表)等
wahahaheihei|  楼主 | 2017-1-27 14:20 | 只看该作者
    /* Enable LIRC */
配置时钟源后,要等时钟配置完成。
yiyigirl2014| | 2017-1-27 14:43 | 只看该作者
这个清除标志啊,喂狗就不会中断了。
dongnanxibei| | 2017-1-27 15:00 | 只看该作者
看门狗唤醒掉电的系统。说明系统的看门狗跟系统是两个独立的
dongnanxibei| | 2017-1-27 15:23 | 只看该作者
稳稳の幸福| | 2017-1-27 15:40 | 只看该作者
串口非空,,,接受啊
zhuotuzi| | 2017-1-28 10:23 | 只看该作者
If user want to write  protected register, please issue SYS_UnlockReg()
mintspring| | 2017-1-28 10:39 | 只看该作者
看门狗定时器超时中断时钟,打开,设置超时的世界,哈哈。
稳稳の幸福| | 2017-1-28 13:12 | 只看该作者
如果超时中断发生了,就打印消息。
yiyigirl2014| | 2017-1-29 17:35 | 只看该作者
我看新唐的单片机看门狗都是类似的
huangcunxiake| | 2017-1-30 12:48 | 只看该作者
    WDT_EnableInt();
使能看门狗中断,加入中断序列。
dongnanxibei| | 2017-1-30 12:59 | 只看该作者
定时唤醒,可以用于省电的系统。
wahahaheihei|  楼主 | 2017-2-10 16:20 | 只看该作者
关于WDT的操作很有限的,在库函数的头文件可以看出来。
wahahaheihei|  楼主 | 2017-2-10 17:19 | 只看该作者
使用了两种时钟源,分别用于不同的模块。
wahahaheihei|  楼主 | 2017-2-10 18:55 | 只看该作者
  • void WDT_IRQHandler(void)
  •     // Clear WDT interrupt flag
  •     WDT_CLEAR_TIMEOUT_INT_FLAG();
  •     // Check WDT wake up flag
  •     if(WDT_GET_TIMEOUT_WAKEUP_FLAG()) {
  •         printf("Wake up by WDT\n");
  •         // Clear WDT wake up flag
  •         WDT_CLEAR_TIMEOUT_WAKEUP_FLAG();
[size=12.6316px]这个地方应该算是两个标志位的处理,第一个是WDT超时中断的标志,另外一个是唤醒的中断,也就是发生了看门狗中断后会产生一个标志,因为这个中断系统会重启另外一个标记。。。。
zhuotuzi| | 2017-2-11 11:57 | 只看该作者
等于这个事件触发了两个标志位置位。
zhuotuzi| | 2017-2-11 12:01 | 只看该作者
zhuotuzi| | 2017-2-11 12:02 | 只看该作者
根据这个图才知道要配置哪个时钟。
