[DSP编程] DSP28335新建CCS6工程后build后报错_新手求助
2758|4
 楼主| zgdzwlds 发表于 2017-1-28 15:17 | 显示全部楼层 |阅读模式
新买了一套DSPF28335准备学习一下,电脑是WIN10只能用CCS6,建立工程Test后,main.c不做处理空函数,build之后就会报错,如下所示,求助~
#10010 errors encountered during linking; "Test.out" not built
gmake: *** [Test.out] Error 1
gmake: Target 'all' not remade because of errors.
symbol "_InitSci" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj" symbol "_InitSci" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj"
symbol "_InitSciaGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj" symbol "_InitSciaGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj"
symbol "_InitScibGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj" symbol "_InitScibGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj"
symbol "_InitScicGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj" symbol "_InitScicGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj"
symbol "_InitSciGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj" symbol "_InitSciGpio" redefined: first defined in "./src/DSP2833x_Sci.obj"; redefined in "./src/DSP2833x_Sci1.obj"
求助~感激不尽
 楼主| zgdzwlds 发表于 2017-1-28 15:20 | 显示全部楼层
这是文件配置情况
Dongfangyuxiao 发表于 2017-1-28 17:28 | 显示全部楼层
redefined
应该是调用头文件不当。
 楼主| zgdzwlds 发表于 2017-1-28 21:05 | 显示全部楼层
redefined
应该是调用头文件不当。
Main函数里什么也没写,应该没有调用呃。。
zhangmangui 发表于 2017-1-31 15:51 | 显示全部楼层
应该是缺少相关文件
建议你下载controlSUITE    打开里面的工程   编译看看
还有工程属性下  看看相关调用路径等
