[STM8] [求助] STM8关闭了总中断为什么还是响应外部中断?
1988|5
 楼主| djqling 发表于 2017-2-21 10:26 | 显示全部楼层 |阅读模式
#include <stm8s.h>
#include <stm8s_exti.h>
#define uchar unsigned char
#define uint  unsigned int
uint curtain1_down,curtain1_up,curtain2_down,curtain2_up,K1,K2,K3;
void Delay_10ms()
  uint y;
for(y=6150; y>0; y--)//10ms=6150
void Delay_200ms()
  uint x,y;
for(x=20; x>0; x--)//200ms=20
for(y=6150; y>0; y--)//1ms=615
void Delay_50ms()
  uint x,y;
for(x=5; x>0; x--)//200ms=20
void main(void)
        K1=0;
        K2=0;
        K3=0;
        curtain1_down=0;
        curtain2_down=0;
        curtain1_up=0;
        curtain2_up=0;
        GPIO_DeInit(GPIOC);
        GPIO_DeInit(GPIOB);
        GPIO_DeInit(GPIOD);
        GPIO_Init(GPIOC,GPIO_PIN_1,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_2,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_6,GPIO_MODE_OUT_PP_LOW_SLOW);
        GPIO_Init(GPIOC,GPIO_PIN_7,GPIO_MODE_OUT_PP_LOW_SLOW);
        disableInterrupts();
        GPIO_Init(GPIOB,GPIO_PIN_1,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_2,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_3,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_4,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_5,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_6,GPIO_MODE_IN_PU_IT);
        GPIO_Init(GPIOB,GPIO_PIN_7,GPIO_MODE_IN_PU_IT);
        CLK_HSIPrescalerConfig( CLK_PRESCALER_HSIDIV8);
        EXTI_DeInit();
        EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOB , EXTI_SENSITIVITY_FALL_ONLY);
        enableInterrupts();
        while(1)
INTERRUPT_HANDLER(EXTI_PORTB_IRQHandler,4)
  Delay_50ms();
  if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_7)==0x00)//窗帘1降
    curtain1_down=curtain1_down+1;
      if(curtain1_down==1)
        curtain1_up=0;
        GPIO_WriteLow(GPIOC, GPIO_PIN_6);
        Delay_200ms();
        GPIO_WriteHigh(GPIOC, GPIO_PIN_7);
    if(curtain1_down==2)
        curtain1_down=0;
        curtain1_up=0;
        GPIO_WriteLow(GPIOC, GPIO_PIN_7);
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_6)==0x00)//窗帘1升
        curtain1_up=curtain1_up+1;
        if(curtain1_up==1)
          curtain1_down=0;
          Delay_200ms();
          GPIO_WriteHigh(GPIOC, GPIO_PIN_6);
         if(curtain1_up==2)
          curtain1_up=0;
          curtain1_down=0;
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_5)==0x00)//窗帘2降
   curtain2_down=curtain2_down+1;
      if(curtain2_down==1)
        curtain2_up=0;
        GPIO_WriteLow(GPIOC, GPIO_PIN_4);
        Delay_200ms();
        GPIO_WriteHigh(GPIOC, GPIO_PIN_5);
    if(curtain2_down==2)
        curtain2_down=0;
        curtain2_up=0;
        GPIO_WriteLow(GPIOC, GPIO_PIN_5);
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_4)==0x00)//窗帘2升
      curtain2_up=curtain2_up+1;
        if(curtain2_up==1)
          curtain2_down=0;
          Delay_200ms();
          GPIO_WriteHigh(GPIOC, GPIO_PIN_4);
         if(curtain2_up==2)
          curtain2_up=0;
          curtain2_down=0;
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_3)==0x00)
    K1=K1+1;
    if(K1==1)
    GPIO_WriteHigh(GPIOC, GPIO_PIN_3);
    if(K1==2)
      K1=0;
    GPIO_WriteLow(GPIOC, GPIO_PIN_3);
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_2)==0x00)
    K2=K2+1;
    if(K2==1)
    GPIO_WriteHigh(GPIOC, GPIO_PIN_2);
    if(K2==2)
      K2=0;
    GPIO_WriteLow(GPIOC, GPIO_PIN_2);
   if((GPIO_ReadInputData(GPIOB)&GPIO_PIN_1)==0x00)
    K3=K3+1;
    if(K3==1)
    GPIO_WriteHigh(GPIOC, GPIO_PIN_1);
    if(K3==2)
      K3=0;
    GPIO_WriteLow(GPIOC, GPIO_PIN_1);
//  enableInterrupts();
STM8S103K3.rar
1.16 MB, 下载次数: 0
泰山特曲123 发表于 2017-2-21 12:31 来自手机 | 显示全部楼层
肯定是你的中断没有关掉
cos12a 发表于 2017-2-21 12:40 | 显示全部楼层
肯定是哪些又偷开了.仿真跟踪一下.
aiwosuoai1992 发表于 2017-3-8 17:20 | 显示全部楼层
你不是又开了么
xiaox314 发表于 2017-3-8 17:27 | 显示全部楼层
是有这么一回事,如果设置了外部中断唤醒,关不关总中断都能触发
Soraka 发表于 2017-3-9 20:45 | 显示全部楼层
中断没有关掉
