进不去中断
454|5
jlyuan|  楼主 | 2017-2-26 19:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
zhaoxqi| | 2017-2-26 19:48 | 只看该作者
有没有捕获到脉冲?
jlyuan|  楼主 | 2017-2-26 19:50 | 只看该作者
其实是个低级的错误,不过我忘了,这是我的最终程序,很准的,你们可以参考一下
测试脉冲的周期时间——made by lqs
#include "msp430f4152.h"
#define LCD_ZREO                 0XFA//0xf5
#define LCD_ONE                  0x60
#define LCD_TWO                  0xD6
#define LCD_THREE                0xf4
#define LCD_FOUR                 0x6c
#define LCD_FIVE                 0xbc
#define LCD_SIX                  0xbe
#define LCD_SEVEN                0xe0
#define LCD_EIGHT                0xfe
#define LCD_NINE                 0xfc
unsigned char aa[10]={LCD_ZREO ,LCD_ONE ,LCD_TWO ,LCD_THREE , LCD_FOUR ,LCD_FIVE ,LCD_SIX ,LCD_SEVEN,  LCD_EIGHT ,LCD_NINE };
unsigned int j=0,sub=0,data=0;
unsigned char i=0;
float f=0;
void clkinit()
  FLL_CTL0 &= ~XT1OF;
  FLL_CTL0 &= ~XTS_FLL;
  FLL_CTL1 &= ~(FLL_DIV0);
  FLL_CTL1 &= ~(FLL_DIV1);
void Portinit()
  P1DIR &= 0X00;
  P1SEL |= 0X01;
void Timer_Ainit()
  TA0CTL |= TASSEL0 + MC_2;
  TA0R = 0X00;
  TACCTL0 |= SCS + CM1 + CAP + CCIE; // CCIS0 +
void LCDinit()
  unsigned char t;
  LCDACTL |= LCD4MUX + LCDON + LCDFREQ_128;
  LCDAPCTL0 = 0X1F;
  LCDAPCTL1 = 0X00;
  LCDAVCTL0 |= LCDCPEN;
  LCDAVCTL1 |= 0X18;
  P5SEL = 0XF0;
  for(t=0;t<10;t++)
    LCDMEM[t] = 0;
void chazhi()    //pulse recurrent time) 脉冲周期时间
    j++;
    if(j==1)
      TACCR0 = 0X00;
    if(j==2)
     j=0;
     sub = TACCR0;
void LCDdiaplay()
  sub= f/32768*1000;//0.0001
  LCDMEM[9] = 0x02;
  LCDMEM[8] = 0;
  data = sub%10;
  LCDMEM[7] = aa[data];  //1.000
  data = sub/10%10;
  LCDMEM[6] = aa[data] + 0x01;
  data = sub/100%10;
  LCDMEM[5] = aa[data];
  data = sub/1000%10;
  LCDMEM[4] = aa[data];
//  data = sub/10000%10;
  LCDMEM[3] = 0;
//  data = sub/100000%10;
  LCDMEM[2] = 0;
  LCDMEM[1] = 0;
  LCDMEM[0] = 0;
/*void testLCD()
  LCDMEM[0]=0xff;
  LCDMEM[1]=0xff;
  LCDMEM[2]=0xff;
  LCDMEM[3]=0xff;
  LCDMEM[4]=0xff;
  LCDMEM[5]=0xff;
  LCDMEM[6]=0xff;
  LCDMEM[7]=0xff;
  LCDMEM[8]=0xff;
  LCDMEM[9]=0xff;
void main( void )
  WDTCTL = WDTPW + WDTHOLD;       // Stop watchdog timer to prevent time out reset
  clkinit();
  Portinit();
  Timer_Ainit();
  LCDinit();
  _EINT();
  while(1)
      LCDdiaplay();
#pragma vector = TIMERA0_VECTOR
__interrupt void Timer_A0()
  //做脉冲的时间差值
   j++;
    if(j == 1)
      TAR = 0X00;  //定时器数TAR0送到TACCR0;
    if(j == 2)
     j = 0;
     f = TACCR0;
  TACCTL0 &= ~CCIFG;
zhenykun| | 2017-2-26 19:52 | 只看该作者
第一个程序确实错误太多了,不过恭喜楼主还是调试出来了
spark周| | 2017-2-26 19:54 | 只看该作者
理想的和实物仿真的的就是不一样
jlyuan|  楼主 | 2017-2-26 19:55 | 只看该作者
哦,那我就知道怎么回事了,多谢大家,结贴了哈
