[DemoCode下载]
N76E003 的IAP数据Flash编程方式
4047|9
稳稳の幸福|  楼主 | 2017-3-17 20:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2016
//  File Function: N76E003 APROM program DATAFLASH (APROM) demo code
#include <stdio.h>
#include "N76E003.h"
#include "Define.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#define     CID_READ            0x0B
#define     DID_READ            0x0C
        Since the DATAFLASH is in the APROM. Program command is same as program APROM
#define     PAGE_ERASE_AP       0x22
#define     BYTE_READ_AP        0x00
#define     BYTE_PROGRAM_AP     0x21
#define     PAGE_SIZE           128
#define     ERASE_FAIL          0x70
#define     PROGRAM_FAIL        0x71
#define     IAPFF_FAIL          0x72
#define     IAP_PASS            0x00
// Following define by customer
// Please confirm the start addresss not over your code size
#define     DATA_SIZE           4096
#define     DATA_START_ADDR     0x3800
Following IAP command register is also define in SFR_Macro.h
        #define set_IAPEN   BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON |= SET_BIT0 ;EA=BIT_TMP
        #define clr_IAPEN   BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON &= ~SET_BIT0;EA=BIT_TMP
        #define set_APUEN   BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN |= SET_BIT0 ;EA=BIT_TMP
        #define clr_APUEN   BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN &= ~SET_BIT0;EA=BIT_TMP
void IAP_ERROR_LED(void)
        while (1)
                clr_P03;
                Timer1_Delay1ms(100);
                set_P03;
void Trigger_IAP(void)
    set_IAPGO;        //trigger IAP
    if((CHPCON&SET_BIT6)==SET_BIT6)             // if fail flag is set, toggle error LED and IAP stop
                        clr_IAPFF;
                        IAP_ERROR_LED();
                WARNING:
        No matter read or writer, when IAPFF is set 1,
        this step process is fail. DATA should be ignore.
Erase APROM subroutine:
void Erase_APROM(void)
    UINT16 u16Count;
    set_IAPEN;        // Enable IAP function
                IAPFD = 0xFF;        // IMPORTANT !! To erase function must setting IAPFD = 0xFF
    IAPCN = PAGE_ERASE_AP;
    set_APUEN;        //  APROM modify Enable
    for(u16Count=0x0000;u16Count<DATA_SIZE/PAGE_SIZE;u16Count++)                //
        IAPAL = LOBYTE(u16Count*PAGE_SIZE + DATA_START_ADDR);
        IAPAH = HIBYTE(u16Count*PAGE_SIZE + DATA_START_ADDR);
        Trigger_IAP();
    clr_APUEN;
    clr_IAPEN;
void Erase_APROM_Verify(void)
    UINT16 u16Count;
    set_IAPEN;
    IAPAL = LOBYTE(DATA_START_ADDR);
    IAPAH = HIBYTE(DATA_START_ADDR);
    IAPCN = BYTE_READ_AP;
    for(u16Count=0;u16Count<DATA_SIZE/PAGE_SIZE;u16Count++)
        IAPFD = 0x00;
        Trigger_IAP();
        if(IAPFD != 0xFF)
                                        IAP_ERROR_LED();
        IAPAL++;
        if(IAPAL == 0x00)
          IAPAH++;
    clr_IAPEN;
void Program_APROM(void)
    UINT16 u16Count;
    set_IAPEN;
    set_APUEN;
    IAPCN = BYTE_PROGRAM_AP;
    for(u16Count=0;u16Count<DATA_SIZE;u16Count++)
        IAPFD++;
        Trigger_IAP();
        IAPAL++;
        if(IAPAL == 0)
            IAPAH++;
    clr_APUEN;
    clr_IAPEN;
void Program_APROM_Verify(void)
    UINT16 u16Count;
    UINT8  u8Read_Data;
    set_IAPEN;
    u8Read_Data = 0x00;
        Trigger_IAP();
        if(IAPFD != u8Read_Data)
                                        IAP_ERROR_LED();
        IAPAL++;
        if(IAPAL == 0)
            IAPAH++;
        u8Read_Data ++;
    clr_IAPEN;
void main (void)
  Set_All_GPIO_Quasi_Mode;
//---------toggle GPIO1---------
        clr_GPIO1;
        Timer0_Delay1ms(100);
        set_GPIO1;
        clr_GPIO1;
        set_GPIO1;
//---------end toggle GPIO1---------
    Erase_APROM();
                Erase_APROM_Verify();
    Program_APROM();
    Program_APROM_Verify();
        clr_GPIO1;
        set_GPIO1;
        clr_GPIO1;
        set_GPIO1;
    while(1);
IAP的妙处,就是在程序里可以自己写闪存。
yiyigirl2014| | 2017-3-17 20:48 | 只看该作者
一般都是要按页擦除掉后,才能再次写入。
zhuotuzi| | 2017-3-18 18:46 | 只看该作者
这样就可以用多余的空间存储掉电保护的数据了。
wahahaheihei| | 2017-3-20 18:22 | 只看该作者
这个烧录进去怎么用啊。
huangcunxiake| | 2017-3-21 19:58 | 只看该作者
Trigger_IAP();
一切就绪后,触发IAP
zhuotuzi| | 2017-3-21 20:18 | 只看该作者
这种应该用括号搞起来比较安全吧
稳稳の幸福|  楼主 | 2017-3-21 23:36 | 只看该作者
一般51如果做那种不需要更新的产品,就不需要这么玩了。
598330983| | 2017-3-24 09:43 | 只看该作者
想成为高手必须学这个IAP。
bxliang| | 2018-8-23 11:53 | 只看该作者
请问有做过N76E003掉电数据保存吗
