24c256程序的显示问题
2390|1
 楼主| lading 发表于 2010-4-28 22:30 | 显示全部楼层 |阅读模式
这个程序显示出了问题,
程序如下:
#include <reg52.h>
#include <intrins.h>
#include<absacc.h>
#define  uchar unsigned char
#define  uint  unsigned int
sbit SCL = P1^5;   //I2C时钟
sbit SDA = P1^6;   //I2C数据/地址
void I2C_start()
    SCL = 0;
    _nop_();_nop_();_nop_();_nop_();_nop_();
    SDA = 1;
    SCL = 1;
    SDA = 0;
void I2C_writebyte(unsigned char dat)
    unsigned char i,temp;
    temp=dat;
    for(i = 0;i<8;i++)
    SCL = 0;
    SDA = temp&0x80;
    temp=temp<<1;
    SCL = 1;
   SCL = 0;
unsigned char I2C_readbyte()
    unsigned char dat,i;
   SCL = 0;
   SDA = 1;
   for(i = 0;i<8;i++)
      SCL = 1;
    dat=dat<<1;
    if(SDA)dat++;
    SCL = 0;
     SCL = 0;
   return(dat);
void I2C_response()
   unsigned char i = 0;
   SCL = 1;
   while((SDA == 1)&&(i<150))i++;
   SCL = 0;
void I2C_stop()
     SCL = 0;
   SDA = 0;
   SCL = 1;
   SDA = 1;
   SCL = 0;
void delay_I2C()
   int i;
for(i=0;i<1100;i++)_nop_();
void I2C_write_byte(int addr1,int addr2,unsigned char dat) //在指定地址写一位数据
I2C_start();
I2C_writebyte(0xa0);
I2C_response();
I2C_writebyte(addr1);
I2C_response();
I2C_writebyte(addr2);
I2C_response();
I2C_writebyte(dat);
I2C_response();
I2C_stop();
unsigned char I2C_read_byte(int addr1,int addr2)//从指定地址读一位数据
    I2C_start();
   I2C_response();
      I2C_response();
      I2C_response();
   I2C_start();
      I2C_writebyte(0xa1);
      I2C_response();
   return(I2C_readbyte());
   I2C_stop();
sbit LCM_E=P3^5;//定义接口
sbit LCM_RW=P3^6;
sbit LCM_RS=P3^7;
#define LCM_Data P2//数据接口
void LCM_WriteData(uchar WDLCM);
void LCM_WriteCommand(uchar WCLCM,BuysC);
uchar LCM_ReadData(void);
uchar LCM_ReadStatus(void);
void LCM_Init(void);
void DisplayOneChar(uchar X, uchar Y, uchar DData);
void DisplayListChar(uchar X, uchar Y, uchar code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
uchar code uctech[] = {"1602A"};
uchar code net[] = {"www.52c51.com"};
  /****************************1602A写数据函数**************************/
  /*函数原型:void LCM_WriteData(uchar WDLCM)
  /*函数功能:1602A写数据
  /*输入参数:要写入的数据
  /*输出参数:无
  /*调用模块:
  /*建立时间:2010/4/20
  /*作者:站长
   LCM_ReadStatus();//检测忙
   LCM_Data = WDLCM;
   LCM_RS = 1;
   LCM_RW = 0;
   LCM_E = 0;//若晶振速度太高可以在这后加小的延时
   LCM_E = 0;//延时
   LCM_E = 1;
  /****************************1602A写指令函数**************************/
  /*函数原型:void LCM_WriteCommand(uchar WCLCM,BuysC)
  /*函数功能:1602A写指令
  /*输入参数:要写入的指令
  /*输出参数:无
  /*调用模块:
  /*建立时间:2010/4/20
  /*作者:站长
void LCM_WriteCommand(uchar WCLCM,BuysC)//BuysC为0时忽略忙检测
    if (BuysC) LCM_ReadStatus();//根据需要检测忙
    LCM_Data = WCLCM;
    LCM_RS = 0;
    LCM_RW = 0;
    LCM_E = 0;
    LCM_E = 0;
    LCM_E = 1;
   /****************************1602A读数据函数**************************/
   /*函数原型:uchar LCM_ReadData(void)
   /*函数功能:1602A读数据
   /*输入参数:无
   /*输出参数:1602A返回的数据
   /*调用模块:
   /*建立时间:2010/4/20
   /*作者:站长
          LCM_RS = 1;
          LCM_RW = 1;
     LCM_E = 0;
     LCM_E = 0;
     LCM_E = 1;
           return(LCM_Data);
   /****************************1602A读状态函数**************************/
   /*函数功能:1602A读状态
   /*输入参数:无
   /*输出参数:1602A返回的状态
   /*调用模块:
   /*建立时间:2010/4/20
   /*作者:站长
     LCM_Data = 0xFF;
    LCM_RS = 0;
    LCM_RW = 1;
    LCM_E  = 0;
    LCM_E  = 0;
    LCM_E  = 1;
while (LCM_Data & 0x80);//检测忙信号
return(LCM_Data);}
/****************************1602A初始化函数**************************/
/*函数原型:void LCM_Init(void)
/*函数功能:1602A初始化
/*输入参数:无
/*输出参数:无
/*调用模块:
/*建立时间:2010/4/20
/*作者:站长
void LCM_Init(void)
  LCM_Data = 0;
  LCM_WriteCommand(0x38,0);//三次显示模式设置,不检测忙信号
  Delay5Ms();
  Delay5Ms();
  Delay5Ms();
  LCM_WriteCommand(0x38,1);//显示模式设置,开始要求每次检测忙信号
  LCM_WriteCommand(0x08,1);//关闭显示
  LCM_WriteCommand(0x01,1);//显示清屏
  LCM_WriteCommand(0x06,1);// 显示光标移动设置
  LCM_WriteCommand(0x0C,1);// 显示开及光标设置
/******************1602A按指定位置显示一个字符函数**********************/
/*函数原型:void DisplayOneChar(uchar X, uchar Y, uchar DData)
/*函数功能:1602A按指定位置显示一个字符
/*输入参数:X坐标 Y坐标 要显示的字符
/*输出参数:无
/*调用模块:
/*建立时间:2010/4/20
/*作者:站长
     Y &= 0x1;
     X &= 0xF;//限制X不能大于15,Y不能大于1
     if (Y) X |= 0x40;//当要显示第二行时地址码+0x40;
     X |= 0x80;// 算出指令码
     LCM_WriteCommand(X, 0);//这里不检测忙信号,发送地址码
     LCM_WriteData(DData);
   /*******************1602A按指定位置显示一串字符函数*********************/
   /*函数原型:void DisplayListChar(uchar X, uchar Y, uchar code *DData)
   /*输入参数:X坐标 Y坐标 要显示字符串的首地址
   /*输出参数:无
   /*调用模块:
   /*建立时间:2010/4/20
      /*作者:站长
  uchar ListLength;
  ListLength = 0;
  Y &= 0x1;
  while (DData[ListLength]>0x20)//若到达字串尾则退出
   if (X <= 0xF)//X坐标应小于0xF
     DisplayOneChar(X, Y, DData[ListLength]);//显示单个字符
     ListLength++;
     X++;
/********************5ms延时函数************************/
/*函数原型:void Delay5Ms(void)
/*函数功能:5ms延时
/*输入参数:无
/*输出参数:无
/*调用模块:
/*建立时间:2010/4/20
/*作者:站长
void Delay5Ms(void)
  unsigned int TempCyc = 5552;
  while(TempCyc--);
/********************400ms延时延时函数************************/
/*函数原型:void Delay400Ms(void)
/*函数功能:400ms延时延时
/*输入参数:无
/*输出参数:无
/*调用模块:
/*建立时间:2010/4/20*作者:站长
  uchar TempCycA = 5;
  unsigned int TempCycB;
  while(TempCycA--)
   TempCycB=7269;
   while(TempCycB--);
void main()
   unsigned char a ;
   delay_I2C();              //延时很重要,上电必须要延时一段时间才能对eeprom操作
      I2C_write_byte(0,6,0x38);//在地址4处写数据0x16
      delay_I2C();             //可要。
      a = I2C_read_byte(0,6);     //从地址4处读回数据
      Delay400Ms();//启动等待,等LCM讲入工作状态
      LCM_Init();//LCM初始化
   Delay5Ms();//延时片刻(可不要)
   LCM_ReadData();//测试用句无意义
   LCM_Data=255;
      DisplayOneChar(1,0,a);
有谁有解决的方法或者是有完整的程序,谢谢了。
 楼主| lading 发表于 2010-4-28 22:34 | 显示全部楼层
对了,单片机用的是51的。是做温度采集,采集温度的用18B20。谢谢!
