用的PIC16F877A,程序不知道哪里出错了,找茬了一天了。求指导;
CCP1输入捕获方式,用D端口的指示灯指示接收到的数据。指示灯用电阻上拉的。
程序如下:请指导下。
#include<pic.h>
//__CONFIG(0xFF32);
void ccp1_init()  //capture mode
        T1CON = 0x00;                //no postscale and no prescale
        CCP1CON = 0x04;         //capture mode and falling edge
        TMR1L = 0x00; //timer1 count from TMR1 to 0xffff
        TMR1H = 0x00;
        GIE = 1;
        PEIE = 1;
        CCP1IE = 1;
        CCP1IF = 0;
volatile unsigned int countl = 0;   //捕获的时间
volatile unsigned char leadcode_ok = 0; //引导码OK
volatile unsigned char time_start = 0;  //解码开始
volatile unsigned char i = 0;
volatile unsigned char ir_code[4] = {0,0,0,0}; // 红外接收到的4个数据
void main()
        TRISD = 0x00;                          //portd 输出  LED端口
        PORTD = 0xff;
        TRISC = 0xff;                        // CCP1 输入,对应红外输入
        ccp1_init();
        while (1)
void interrupt ccp1(void)
        if(CCP1IF && CCP1IE )
                CCP1IE = 0;
                if(time_start == 0)
                        TMR1H = 0;
                        TMR1L = 0 ;
                        TMR1ON = 1;
                        time_start = 1;
                else
                        TMR1ON = 0;
                        countl = TMR1H*256+TMR1L;
                        TMR1H = 0;
                        TMR1L = 0;
                        TMR1ON = 1;
                        if((countl >12500)&&(countl <14500)&&(leadcode_ok == 0))
                                leadcode_ok = 1;
                                i = 0;
                        else
                                if((countl >2000)&&(countl <2500)&&(leadcode_ok==1)) //bit 1
                                        ir_code[i/8] = ir_code[i/8]<<1+1;
                                        i++;
                                else
                                if((countl >1000)&&(countl <1300)&&(leadcode_ok==1))   //bit 0
                                        ir_code[i/8] = ir_code[i/8] <<1 ;
                                        i++;
                                else
                                        time_start = 0;
                                        leadcode_ok = 0;
                                        i = 0;
                        if(i==32)
                                        i = 0;
                                        time_start = 0;
                                        leadcode_ok = 0;
                                        PORTD = ~ir_code[3]; //用指示灯输出 红外数据
                TMR1IF = 0;
                CCP1IF = 0;
                CCP1IE = 1;
