求救,stm32关闭全局中断问题
10397|5
 楼主| ilymy 发表于 2010-5-5 11:21 | 显示全部楼层 |阅读模式
我使用裸奔方式
先定义
#define  NVIC_ISER0              (*(volatile unsigned long *) 0xE000E100)
#define  NVIC_ICER0              (*(volatile unsigned long *) 0xE000E180)
我使用rtc秒中断定义如下
#define dis_rtc_g_it NVIC_ICER0 |= 1<<3
#define en_rtc_g_it  NVIC_ISER0 |= 1<<3   //rtc全局中断
开始我写
en_rtc_g_it;
程序可以正常运行,也可以进秒中断
但是在某个地方我需要关闭它,于是我写
dis_rtc_g_it;
结果所有的中断都关了,包括timer等。
后来我干脆程序一开始不写en_rtc_g_it;,只写dis_rtc_g_it;,结果所有的中断还是都关闭了。
请问是什么原因呢,下面是官方文档
寄存器说明---------------------------------
4.2.3         Interrupt clear-enable registers (NVIC_ICERx)
Address offset: 0x00 - 0x0B
Reset value: 0x0000 0000
Required privilege: Privileged
The ICER0-ICER2 registers disable interrupts, and show which interrupts are enabled.
31          30          29          28          27          26 25 24 23 22 21 20 19 18 17 16
CLRENA[31:16]
rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1     rc_w1
15          14          13          12          11          10 9 8 7 6 5 4 3 2 1 0
CLRENA[15:0]
Bits 31:0  CLRENA[31:0]: Interrupt clear-enable bits.
Write:
0: No effect
1: Disable interrupt
Read:
0: Interrupt disabled
1: Interrupt enabled.
地址---------------------------------
NVIC register map
The table provides shows the NVIC register map and reset values. The base address of the
main NVIC register block is 0xE000E100. The NVIC_STIR register is located in a separate
block at 0xE000EF00.
void NVIC_SetPendingIRQ (IRQn_t IRQn) Set IRQn pending
void NVIC_ClearPendingIRQ (IRQn_t IRQn) Clear IRQn pending status
uint32_t NVIC_GetActive (IRQn_t IRQn)
Return the IRQ number of the active
interrupt
void NVIC_SetPriority (IRQn_t IRQn, uint32_t priority)          Set priority for IRQn
uint32_t NVIC_GetPriority (IRQn_t IRQn) Read priority of IRQn
void NVIC_SystemReset (void) Reset the system
Table 36.     CMSIS functions for NVIC control (continued)
CMSIS interrupt control function Description
Table 37.     NVIC register map and reset values
Offset       Register
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
0x000
NVIC_ISER0 SETENA[31:0]
Reset Value        0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
0x004
NVIC_ISER1 SETENA[63:32]
0x008
NVIC_ISER2
Reserved
SETENA
[67:64]
Reset Value 0    0    0    0
0x080
NVIC_ICER0 CLRENA[31:0]
0x084
NVIC_ICER1 CLRENA[63:32]
0x088
NVIC_ICER2
Reserved
CLRENA
[67:64]
Reset Value 0    0    0    0
向量表--------------------------------
0      7      settable    WWDG Window Watchdog interrupt 0x0000_0040
1      8      settable    PVD
PVD through EXTI Line detection
interrupt
0x0000_0044
2      9      settable    TAMPER Tamper interrupt 0x0000_0048
3     10     settable    RTC RTC global interrupt 0x0000_004C
 楼主| ilymy 发表于 2010-5-5 11:28 | 显示全部楼层
我狂晕,刚试了一下把
改成
#define dis_rtc_g_it NVIC_ICER0 = 1<<3
就可以了,这是为什么呢
 楼主| ilymy 发表于 2010-5-5 11:31 | 显示全部楼层
这个寄存器为什么不能用或操作呢
我试了
#define dis_rtc_g_it NVIC_ICER0 |= (1<<3)
也不行
香水城 发表于 2010-5-5 11:31 | 显示全部楼层
|=  是读出再写回;
=   是写入前不读出。
请检查读出的是什么内容。
 楼主| ilymy 发表于 2010-5-5 11:34 | 显示全部楼层
想了一下,明白了
关键在于这个寄存器的读操作上面
如果用或操作,会先读取此寄存器的值,而读这个寄存器会读出当前中断使能的情况,如果某个中断被使能,那么相应的位数值为“1”,这样再写回去的话,就会把所有打开的中断关闭!!!
 楼主| ilymy 发表于 2010-5-5 11:37 | 显示全部楼层
谢谢香主
