[STM32F7] STM32F723E-Discovery 评测(1)开箱
1417|3
 楼主| sky.sun.zz 发表于 2017-5-19 21:37 | 显示全部楼层 |阅读模式
STM32F723E-Discovery 评测 (3) PCROP
STM32F723E-Discovery 评测 (4) USB HS
STM32F723E-Discovery 评测(5)STemWin
感谢社区,感谢ST,有幸收到奖品STM32F723E-Discovery
                           正面
                       背面
                       扩展板
板上集成 ARM® 32-bit Cortex® -M7内核的STM32F723IE,官方对这款芯片主要性能介绍:
  • Core: ARM® 32-bit Cortex® -M7 CPU with FPU, adaptive real-time accelerator (ART Accelerator™) and L1-cache: 8 Kbyte of data cache and 8 Kbytes of instruction cache, allowing 0-wait state     execution from embedded Flash memory and external memories, frequency up to 216 MHz, MPU, 462 DMIPS/2.14 DMIPS/MHz (Dhrystone 2.1) and DSP instructions.
  • Memories
    • Up to 512 Kbytes of Flash memory with protection mechanisms (read and write protections, proprietary code readout protection (PCROP))
    • 528 bytes of OTP  memory
    • SRAM: 256 Kbytes (including 64 Kbytes of data TCM RAM for critical real-time data) + 16 Kbytes of instruction TCM RAM (for critical real-time routines) + 4  Kbytes of backup SRAM (available in the lowest power modes)
    • Flexible external  memory controller with up to 32-bit data bus: SRAM, PSRAM, SDRAM/LPSDR SDRAM, NOR/NAND memories
  • Dual mode Quad-SPI
  • Clock, reset and supplymanagement
    • 1.7 V to 3.6 V application supply and I/Os
    • POR, PDR, PVD and BOR
    • Dedicated USB power
    • 4-to-26 MHz crystal  oscillator
    • Internal 16 MHz factory-trimmed RC (1% accuracy)
    • 32 kHz oscillator for  RTC with calibration
    • Internal 32 kHz RC with calibration
  • Low-power
    • Sleep, Stop and Standby modes
    • VBAT supply for RTC, 32×32 bit backup registers + 4 Kbytes of backup SRAM
  • 3×12-bit, 2.4 MSPS ADC:  up to 24 channels and 7.2 MSPS in triple interleaved mode
  • 2×12-bit D/A converters
  • Up to 18 timers: up to thirteen 16-bit (1x low- power 16-bit timer available in Stop mode) and two 32-bit timers, each with up to 4 IC/OC/PWMs or pulse counter and quadrature (incremental) encoder inputs. All 15 timers running up to 216 MHz. 2x watchdogs, SysTick timer
  • General-purpose DMA: 16-stream DMA controller with FIFOs and burst support
  • Debug mode
    • SWD & JTAG interfaces
    • Cortex® -M7 Trace Macrocell™
  • Up to 140 I/O ports with  interrupt capability
    • Up to 136 fast I/Os up to 108 MHz
    • Up to 138 5 V-tolerant I/Os
  • Up to 21 communication  interfaces
    • Up to 3× I2 C interfaces (SMBus/PMBus)
    • Up to 4 USARTs/4  UARTs (27 Mbit/s, ISO7816 interface, LIN, IrDA, modem control)
    • Up to 5 SPIs (up to 54 Mbit/s), 3 with muxed simplex I2 Ss for audio class accuracy via internal audio PLL or external clock
    • 2 x SAIs (serial audio interface)
    • 1 x CAN (2.0B active)
    • 2 x SDMMCs
  • Advanced connectivity
    • USB 2.0 full-speed   device/host/OTG controller with on-chip PHY
    • USB 2.0  high-speed/full-speed device/host/OTG controller with dedicated DMA,on-chip full-speed PHY and on-chip Hi-speed PHY or ULPI depending on the part number
  • True random number generator
  • CRC calculation unit
  • RTC: subsecond accuracy,hardware calendar
  • 96-bit unique ID
    值得关注的是在这块STM32F723E-Discpvery板上配置了:
CIRRUS的数字音频音频处理芯片WIM8994ECS/R,连接到音频输入/输出接口和2个外置扬声器接口和数字麦克风;
一个USB OTG HS和一个USB OTG FS接口;
一个带电容触摸屏的240×240点阵的TFT液晶显示屏;
一片512Mbit  Quad_SPI NOR Flash MX25L51245G;
一片8Mbit PSRAM  IS66WV51216EBLL-55BLI;
                 硬件模块
                           顶层元件
                           背面元件
上电运行出厂预装的GUI演示视频,要播放的视频AVI文件、音频WAV文件拷贝到U盘,插在CN19 USB HS接口。刚进入时需要校正一下触摸屏对角线2点坐标。
   播放的视频非常流畅,这得益于STM32F723IE这款高性能M7内核芯片。
     240×240 TFT的触摸屏感觉有点小,手指头“占”地过份,屡“占”屡败,呵呵!
戈卫东 发表于 2017-5-19 21:52 | 显示全部楼层
是不是除了我都有723了?
又见ES。。。。。
 楼主| sky.sun.zz 发表于 2017-5-19 21:57 | 显示全部楼层
是不是除了我都有723了?
楼上别灰心,不懈努力会有的。这次723从722而来,来之不易呀!
