老x用51 DIY的VGA第三版:俄罗斯方块(更新完整源码及原理图)
46841|186
aibang 发表于 2016-1-12 00:08 | 显示全部楼层
我改了一下驱动用STC514k48S4,几乎不用外围元件驱动
P2.0  加1K电阻接显示器 R
P2.1  加1K电阻接显示器 G
P2.2 加1K电阻接显示器  B
P4.6 接 显示器场频
P4.7 接 显示器行频
P3.6 加100UF接喇叭,另外端接地。
使用内部RC震荡30M
aibang 发表于 2016-1-12 00:10 | 显示全部楼层
工程中去掉XWJ_VGA_DRIVE>LIB
加入以下VGA.C文件
#include "xwj_vga_drive.h"
#include "xwj_fk.h"
#include "xwj_osd_mini.h"
code unsigned char  char_fkdot[]={
        0xFF,0x01,0x39,0x55,0x6D,0x55,0x39,0x01,0xFF,0x01,0x39,0x45,0x45,0x45,0x39,
        0x01,0xFF,0x07,0x01,0x19,0x25,0x25,0x99,0x81,0xFF,0x07,0x01,0x3D,0x25,0x25,
        0xBD,0x81,0x75,0xF0,0x0A,0xED,0xA4,0x2F,0xF5,0x82,0xE4,0x35,0xF0,0xF5,0x83,
        0xE5,0x82,0x24,0xD5,0xF5,0x82,0xE5,0x83,0x34,0x01,0xF5,0x83,0xE4,0xF0,0x22};
uchar  *Music_prt;                //乐谱指针
uchar xdata Dis_Buf[FK_LINES *FK_LEN];
uchar ledloop;
uchar delayloop;                        //delay16.6()函数计数用
uchar Freq;
uchar syncON;
uchar syncOFF;
unsigned char LineCount;
unsigned char Lines;
uchar OSD_Lines;
uchar fk_Lines;
uchar Mus_Len;
uchar Wave;
bit Mute=1;                                   //Mute=1:静音
bit flag_delay;                        //一场标志,delay16.6()函数用
bit flag_delay_bak;                //一场标志,delay16.6()函数判断用
bit flag_Time0_5s_State;                //半秒标志
bit flag_IsShowLine;
bit flag_IsHiddenTimes;
extern unsigned char xdata *SramAdr;
unsigned int      PAL_lineVideo = 0 ;             // current visible video line number
unsigned int      PAL_max_y ;                     // last video line number
unsigned char   PAL_shift_y ;                   // first video line number (vertical centering)
#define PAL_VSYNC   P4^6
#define PAL_HSYNC   P4^7
#define PAL_BVID    P2^0
void init_io(void){
P0M0=0x00;
P0M1=0x00;
P0=0xFF;  //P0 为输入
P1M0=0x00;
P1M1=0x00;
P1=0x0FF;
P2M0=0xFF;
P2M1=0x00;
P2=0x0;
P4SW=0x70; //P4为IO
P4M0=0xff;
P4M1=0x00;
P4=0x0;
P3M0=0xFC;
P3M1=0;
P3=0x03;
P5M0=0xFF;
P5M1=0;
//P55=0;
void delay17(uchar x)                                //延时x个16.6毫秒(60Hz)
#pragma asm
C1E24:
                        MOV      A,R7
                        JZ       C1E36
C1E27:                MOV      C,flag_delay;//(0x20.0)
                        JNB      flag_delay_bak,C1E2D;//(0x20.3),C1E2D
                        CPL      C
C1E2D:               JNC      C1E27
                      MOV      C,flag_delay//(0x20.0)
                      MOV      flag_delay_bak,C
                      DEC      R7
                      SJMP     C1E24
C1E36:          RET
#pragma endasm
void Start_music(uchar * prt){
#pragma asm
                MOV      Freq,#0x01;
                MOV      Mus_Len,#0x01;
                MOV      R6,0x02;
                MOV      R7,0x01;
                MOV      Music_prt,R6;
                MOV      0x17,R7;
                CLR      Mute;//(0x20.2)
                 RET;
#pragma endasm
void Delay_us(unsigned char time){
    unsigned char a,b;
    for(b=time;b>0;b--)
        for(a=2;a>0;a--);
void    PAL_init(unsigned char y){
        PAL_shift_y =33 ;     // compute vertical offset for centering
void mus(void ){
#if 1
#pragma asm
///声音//////
C0E2F:
JB       Mute,C0E3E;
DJNZ   Wave,C0E3C;
CPL      Beep;
MOV    Wave,Freq;
SJMP    C0E46;
C0E3C:
SJMP     C0E43;
C0E3E:
SETB     Beep
NOP;
NOP;
NOP;
C0E43:
NOP;
NOP;
NOP;
C0E46:
#if 1
JNB      flag_IsHiddenTimes,C0F11
        //不显示跳转
MOV      A,Lines;
XRL      A,#45
JZ       C0E55
//是否已经45行
LJMP     C0F11
#endif
//音乐
C0E55:
JB       Mute,C0EA0
DEC      Mus_Len
MOV      A,Mus_Len
JNZ      C0E93
INC      0x17
MOV      A,0x17
MOV      R6,Music_prt
JNZ      C0E68
INC      Music_prt;
C0E68:
DEC      A
MOV      DPL,A
MOV      DPH,R6
CLR      A
MOVC     A,@A+DPTR
MOV      Freq,A
INC      0x17
MOV      A,0x17
MOV      R6,Music_prt
JNZ      C0E7B
INC      Music_prt
C0E7B:
DEC      A
MOV      DPL,A
MOV      DPH,R6
CLR      A
MOVC     A,@A+DPTR
MOV      Mus_Len,A
SETB     C
SUBB     A,#0x01
JNC      C0E8F
SETB     Mute
CLR      PWM0
SJMP     C0EA0;
C0E8F:
SETB     PWM0
SJMP     C0EA0;
C0E93:
MOV      A,Mus_Len
CLR      C
SUBB     A,#0x06
JNC      C0E9E
CLR      PWM0
SJMP     C0EA0;
C0E9E:
SETB     PWM0;
C0EA0:
CPL      flag_delay
DEC      ledloop
MOV      A,ledloop
JNZ      C0F11
  clr c;//youbang test
//这里获取不到位fk_run
// MOV      C, fk_run
CPL      C
JNC      C0EB2
MOV      ledloop,#30;
SJMP     C0EB5;
C0EB2:
MOV      ledloop,#15;
C0EB5:
CPL      IO_LED;
CPL      flag_Time0_5s_State;//(0x20.
C0F11:
ret;
#pragma endasm
#endif
#define FOSC 30000000L          //系统频率
#define BAUD 600000            //串口波特率
#define NONE_PARITY     0       //无校验
#define ODD_PARITY      1       //奇校验
#define EVEN_PARITY     2       //偶校验
#define MARK_PARITY     3       //标记校验
#define SPACE_PARITY    4       //空白校验
#define PARITYBIT NONE_PARITY   //定义校验位
#define S1_S0 0x40              //P_SW1.6
#define S1_S1 0x80              //P_SW1.7
sfr P_SW1       =   0xA2;   //0000,0000 外设端口切换寄存器1
void uart(void)
    ACC = P_SW1;
    ACC &= ~(S1_S0 | S1_S1);    //S1_S0=0 S1_S1=0
    P_SW1 = ACC;                //(P3.0/RxD, P3.1/TxD)
#if (PARITYBIT == NONE_PARITY)
    SCON = 0x50;                //8位可变波特率
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    SCON = 0xda;                //9位可变波特率,校验位初始为1
#elif (PARITYBIT == SPACE_PARITY)
    SCON = 0xd2;                //9位可变波特率,校验位初始为0
#endif
    AUXR |= 0x40;                //定时器1为1T模式
    TMOD = 0x00;                //定时器1为模式0(16位自动重载)
    TL1 = (65536 - (FOSC/4/BAUD));   //设置波特率重装值
    TH1 = (65536 - (FOSC/4/BAUD))>>8;
    TR1 = 1;                    //定时器1开始启动
    ES = 1;                     //使能串口中断
    EA = 1;
void vga_init(void){
  AUXR = 0x80;
  init_io();
  //uart();
  PAL_init(180);
    ACC = P_SW1;
#pragma asm
  MOV      TMOD,#0x22
  MOV      SCON,#0x0
  MOV      TH0,#0xb1
  MOV      TL0,#0xb1
  MOV      TH1,#0xb1
  MOV      TL1,#0xb1
MOV        TCON,#0x51 //51
  MOV      IP,#0x08;//08
MOV       IPH,#0x0A
  MOV      IE,#0x8a//8a
  MOV      syncON,#0x7F
  MOV      syncOFF,#0xFF
  CLR       flag_IsShowLine;
  SETB     flag_IsHiddenTimes;
  MOV      Lines,#45
  MOV      LineCount,#85;
  CLR      A
  MOV      OSD_Lines,A
  MOV      fk_Lines,#159
  MOV      ledloop,#30
  CLR      IO_LED;
#pragma endasm
void time1()interrupt 3
    unsigned char   *ptr ;  // temporary pointer
    unsigned char   *osdp ;  // temporary pointer
    unsigned int line,osd;
               //AL_lineVideo++;
        if (PAL_lineVideo>521){
                   P4=0;
                   flag_IsHiddenTimes=1;
                if (PAL_lineVideo==524){
                        P4|=0x40;
                        Lines=45;
                        LineCount=85;
                       fk_Lines=159;//159行
                        PAL_lineVideo=0;
                         Delay_us(3) ;          // horizontal sync : low leve
                         P4|=0x80;
        }else{
                        P4&=0x7F;
       //                  Delay_us(1) ;
                        osd=((PAL_lineVideo-64)>>1);
                         osdp=diaplay_buf+(osd*6);
                        P4|=0xC0;
                  if(((PAL_lineVideo)>63)&&((PAL_lineVideo)<(230)))
                        //P4|=0xC0;
                                line=((PAL_lineVideo-64)>>3)+1;
                                ptr=Dis_Buf+(FK_LINES *FK_LEN-(line*10));
                                ACC=*ptr;
                                #pragma asm
                                 MOV      P2,#0x0A
                                 MOV      R6,#0x05 //OSD 一行五个字
                                 MOV      R5,#10    //方块10行
                                //发送数据10个方块数据
                                FK:
                                MOVX     A,@DPTR
                                MOV P2,A
                                INC      DPTR
                                DJNZ     R5,FK
                                MOV P2,#0x0A;
#if 1
#pragma endasm
                                ACC=*osdp;
#pragma asm
                                MOV P2,#0x04;
                                //发送5个字节
                                OSD:
                                MOVX     A,@DPTR
#if 0
        //                        CLR TI
                //                MOV SBUF,A
#else
                                RRC A;
                                MOV P2^0,c;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
                                RRC A;
                                MOV P2^0,C;
#endif
                                    INC      DPL
                                    DJNZ     R6,OSD
                                    MOV      P2,#0x04
                                //OSD发送完毕
#endif
                                MOV P2,#0;
#pragma endasm
                                Lines--;
else{
        //Delay_us(3) ;
        //P4&=0x7F;
        //P4&=0x7F;
        //P4|=0xC0;
                flag_IsHiddenTimes=0;
        PAL_lineVideo++;
        mus();
        //P4=0xff;
aibang 发表于 2016-1-12 00:17 | 显示全部楼层
单片机可以使用15系列其他的单片机,淘宝随便买个开发板就可以搭起来[attach]565004[/attach
目前还有点小问题,下降速度太快,最多只能变换3次。
OSD信息栏目有点大,屏幕没有全屏,图像有点小抖动。
工作忙没空去修改了,其他爱好者可以下载修改。如果有改进再贴上来。
aibang 发表于 2016-1-12 00:28 | 显示全部楼层
其中一个终端屏幕是我用这个驱动来做的终端界面
limingnefu 发表于 2016-4-16 21:42 | 显示全部楼层
太过分了呀,光是用VGA就很牛很牛了,还做了声音!!!一个字,佩服!
liwen21 发表于 2016-6-21 21:36 | 显示全部楼层
用一下74hc165d吧,缓冲一下效果更好。
happy0god 发表于 2020-12-17 08:53 | 显示全部楼层
好东西,必须点赞
