我想用FPGA控制射频天线的信号通过FX2芯片传输给电脑,FX2的驱动、固件能识别,
用EP2OUT写入数据,存给EP6IN,能在计算机上用Cyconsole读出数据。但是用FPGA给FX2写数据的时候读不出数据。总是失败!
Dscr.a51里面照cypress给的开发包更改的内容是:
;; Interface Descriptor
      db   DSCR_INTRFC_LEN      ;; Descriptor length
      db   DSCR_INTRFC         ;; Descriptor type
      db   0               ;; Zero-based index of this interface
      db   0               ;; Alternate setting
      db   4               ;; Number of end points
      db   0ffH            ;; Interface class
      db   00H               ;; Interface sub class
      db   00H               ;; Interface sub sub class
      db   0               ;; Interface descriptor string index
;; Endpoint Descriptor
      db   DSCR_ENDPNT_LEN      ;; Descriptor length
      db   DSCR_ENDPNT         ;; Descriptor type
      db   02H               ;; Endpoint number, and direction
      db   ET_BULK            ;; Endpoint type
      db   00H               ;; Maximun packet size (LSB)
      db   02H               ;; Max packect size (MSB)
      db   00H               ;; Polling interval
      db   86H               ;; Endpoint number, and direction
      db   01H               ;; Endpoint number, and direction
      db   40H               ;; Maximun packet size (LSB)
      db   00H               ;; Max packect size (MSB)
      db   81H               ;; Endpoint number, and direction
HighSpeedConfigDscrEnd:
另外TD_Init()里面改的内容是:
void TD_Init(void)             // Called once at startup
   BREAKPT &= ~bmBPEN;      // to see BKPT LED go out TGE
   Rwuen = TRUE;            // Enable remote-wakeup
   CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1) ;
   // set the slave FIFO interface to 48MHz
 SYNCDELAY;
    PORTACFG=0x40;                 // 设置PA.7 为 slcs;
    SYNCDELAY;
 FIFORESET = 0x80;
    SYNCDELAY;
    FIFORESET = 0x02;
    SYNCDELAY;
 FIFORESET = 0x04;
 SYNCDELAY;
 FIFORESET = 0x06;
 SYNCDELAY;
    FIFORESET = 0x08;
    SYNCDELAY;
    FIFORESET = 0x00;
 SYNCDELAY;
    IFCONFIG |= 0xCB;
    SYNCDELAY;
 EP1OUTCFG = 0xA0;
 EP1INCFG = 0xA0;
    SYNCDELAY;
 EP2CFG = 0xA2;
    SYNCDELAY;
    EP6FIFOCFG =0x08;
   SYNCDELAY;
    EP6CFG = 0xe8;
   SYNCDELAY;
    PINFLAGSCD = 0x0e;
   SYNCDELAY;
   FIFOPINPOLAR = 0x00;
   SYNCDELAY;
    EP6AUTOINLENH = 0x02;
    SYNCDELAY;
    SYNCDELAY;
    EP6AUTOINLENL = 0x00;
    SYNCDELAY;
    SYNCDELAY;
   EP2BCL = 0x80;
   SYNCDELAY;
   EP2BCL = 0x80;
   SYNCDELAY;
  // enable dual autopointer feature
  AUTOPTRSETUP |= 0x01;
}请问这是什么原因呢??是固件的问题还是FPGA根本就没把数据写入呢?? |
