其他的信号都会跟着变
506|7
zwll|  楼主 | 2017-6-16 22:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在CYC28中新加了AMuxN模块,可以超过八路信号输入,但是试了试发现,只要我修改一路信号,其他的信号都会跟着变
yinxiangh| | 2017-6-16 22:46 | 只看该作者
你是怎么试的呢?
zwll|  楼主 | 2017-6-16 22:49 | 只看该作者
补充code
// C main line
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
INT iData;
void adc_display(void)
                        INT i;
                        ADCINC12_Start(ADCINC12_HIGHPOWER);
                        ADCINC12_GetSamples(1);
                        while(ADCINC12_fIsDataAvailable() == 0);
                           ADCINC12_ClearFlag();
                        iData = ADCINC12_iGetData()+0x800;
                        for(i=0;i<20000;i++);
                        LCD_Position(0,6);
                        LCD_PrHexInt(iData);
                        ADCINC12_Stop();
void delay(void)
        INT i;
        for(i=0;i<50;i++);
void main(void)
        INT input_changer;
        input_changer = 0;
        M8C_EnableGInt ; // Uncomment this line to enable Global Interrupts
        PGA_Start(PGA_MEDPOWER);
        AMuxN_Start();
        LCD_Start();
        for(;;)
                        switch(input_changer)
                        case 0:
                           AMuxN_InputSelect(AMuxN_PORT0,AMuxN_PIN1);
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_0");
                        input_changer += 1 ;
                        break;
                        case 1:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN3);
                            adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_1");
                        input_changer -= 1;
                        break;
                        case 2:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN2);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_2");
                        input_changer += 1;
                        break;
                        case 3:
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_3");
                        input_changer += 1;
                        break;
                        case 4:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN4);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_4");
                        input_changer += 1;
                        break;
                        case 5:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN5);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_5");
                        input_changer += 1;
                        break;
                        case 6:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN6);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_6");
                        input_changer += 1;
                        break;
                        case 7:
                        AMuxN_InputSelect(AMuxN_PORT0, AMuxN_PIN7);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("0_7");
                        input_changer += 1;
                        break;
                        case 8:
                        AMuxN_InputSelect(AMuxN_PORT1, AMuxN_PIN0);
                        delay();
                        adc_display();
                        LCD_Position(1,6);
                        LCD_PrCString("1_0");
                        input_changer = 0;
                        break;
                        default: input_changer = 0;
chenjunt| | 2017-6-16 22:51 | 只看该作者
user module datasheet said:
This API only connects the specified pin to the bus, does not disconnect any pins from the bus.
So, before connnect a pin, you have to make sure all the other pins disconnect, if you don't want them connected.
zwll|  楼主 | 2017-6-16 22:53 | 只看该作者
能否给一个具体的实例
zwll|  楼主 | 2017-6-16 22:55 | 只看该作者
特别是那个连线的图是怎么连接的?
morrisk| | 2017-6-16 22:59 | 只看该作者
不懂,帮顶了
zwll|  楼主 | 2017-6-16 23:01 | 只看该作者
结贴了,多谢大家讨论这么多哈,呵呵
