jtag仿真时延时函数跳不出来
2523|1
 楼主| linfuchi 发表于 2010-5-26 09:51 | 显示全部楼层 |阅读模式
在KEIL Uvision中void Delay(__IO uint32_t nCount){}函数跳不出来,什么缘故?
这样调用的:Delay(0x8ffff);
#include "stm32f10x.h"
#include "stm32_eval.h"
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void Delay(__IO uint32_t nCount);
void main(void)
  /* System Clocks Configuration **********************************************/
  RCC_Configuration();
  /* Configure all unused GPIO port pins in Analog Input mode (floating input
     trigger OFF), this will reduce the power consumption and increase the device
     immunity against EMI/EMC *************************************************/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);//开GPIOA
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  while (1)
       GPIO_SetBits(GPIOA, GPIO_Pin_6);  //GPIOC.6=1
       Delay(0x8ffff);
       GPIO_ResetBits(GPIOA, GPIO_Pin_6);    //GPIOC.6=0
       Delay(0x8ffff);
  /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
     initialize the PLL and update the SystemFrequency variable. */
  SystemInit();
  for(; nCount != 0; nCount--);
ST_ARM 发表于 2010-6-17 11:58 | 显示全部楼层
在调用Delay(__IO uint32_t nCount)时,将输入参数的只设为比较小的值,如6,进入函数单步执行,看看问题出在哪里。
