求助STM32 CAN收发 PA11&12回环OK 正常模式无数据发送
6444|14
 楼主| e_boys 发表于 2010-6-14 10:28 | 显示全部楼层 |阅读模式
问题如题,以下是我的源代码:请各位大侠帮帮忙!
源代码有两个部分,一个是main.c 一个是stm32f10x_it.c(此文件中我只使用了can接收中断和系统定时中断) (cantx和canrx都是一样的)
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main program body
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Local includes ------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
vu32 ret; /* for return of the interrupt handling */
volatile TestStatus TestRx;
ErrorStatus HSEStartUpStatus;
u16 TimingDelay;
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
TestStatus CAN_Polling(void);
TestStatus CAN_Interrupt(void);
void SysTick_Configuration(void);
void delay_ms(u16 temp)
  TimingDelay = temp;
  while(TimingDelay != 0);
* Function Name  : SysTick_Configuration
* Description    : 系统时钟设置
* Input          : None
* Output         : None
* Return         : None
        RCC_ClocksTypeDef         RCC_ClocksStatus;
        /* Return SysTick data */
        RCC_GetClocksFreq(&RCC_ClocksStatus);
        /* SysTick event each 1 ms with input clock equal to 9MHz (HCLK/8)*/
        SysTick_SetReload(RCC_ClocksStatus.HCLK_Frequency/8/1000);
        /* Enable the SysTick Interrupt */
        SysTick_ITConfig(ENABLE);
        /* Enable the SysTick Counter */
          SysTick_CounterCmd(SysTick_Counter_Enable);
* Function Name  : main
* Input          : None
* Output         : None
* Return         : None
int main(void)
   CanTxMsg TxMessage;
   u32 i = 0;
   u8 temp_data;
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO ports pins Configuration */
  GPIO_Configuration();
  /* System Clocks */
  SysTick_Configuration();
  /* CAN transmit at 100Kb/s and receive by polling in loopback mode*/
  TestRx = CAN_Polling();
  while (1)
          /* transmit 1 message */
          TxMessage.StdId=0x12;
          TxMessage.ExtId=0x34;
          TxMessage.IDE=CAN_ID_EXT;
          TxMessage.RTR=CAN_RTR_DATA;
          TxMessage.DLC=2;
          TxMessage.Data[0]=0xDE;
          TxMessage.Data[1]=0xCA;
          temp_data = CAN_Transmit(&TxMessage);
          temp_data = CAN_TransmitStatus(temp_data);
          i = 0;
          while(( temp_data != CANTXOK) && (i != 0xFF))
            i++;
          GPIOA->ODR |= 0x0100;           //蜂鸣器响:
          if(temp_data == CANTXOK) delay_ms(600); //以不同声音区分发送状态;
          else delay_ms(100);
          GPIOA->ODR &= (~0x0100); //蜂鸣器关:
          delay_ms(900);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x04)
  /* GPIOA , GPIOB ,GPIOC , GPIOD and AFIO clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOD, ENABLE);
  /* CAN Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
  //GPIO_PinRemapConfig(GPIO_Remap1_CAN, ENABLE);
  /* Configure PA.08 Output push-pull */   //蜂鸣器;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure CAN pin: RX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  /* Configure CAN pin: TX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
* Function Name  : NVIC_Configuration
* Description    : Configures the NVIC and Vector Table base address.
* Input          : None
* Output         : None
* Return         : None
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* enabling interrupt */
  NVIC_InitStructure.NVIC_IRQChannel=USB_LP_CAN_RX0_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
* Function Name  : CAN_Polling
* Description    : Configures the CAN and transmit and receive by polling
* Input          : None
* Output         : None
* Return         : PASSED if the reception is well done, FAILED in other case
{u8 Error;
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  /* CAN register init */
  CAN_DeInit();
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
  CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;//CAN_Mode_LoopBack;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=5;
  Error =CAN_Init(&CAN_InitStructure);
if (Error == 0)
        return FAILED;
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  CAN_ITConfig(CAN_IT_TME, ENABLE);
  return PASSED; /* Test Passed */
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
//文件2:stm32f10x_it.c
* File Name          : stm32f10x_it.c
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main Interrupt Service Routines.
*                      This file can be used to describe all the exceptions
*                      subroutines that may occur within user application.
*                      When an interrupt happens, the software will branch
*                      automatically to the corresponding routine.
*                      The following routines are all empty, user can write code
*                      for exceptions handlers and peripherals IRQ interrupts.
#include "stm32f10x_it.h"
extern vu32 ret;
extern u16 TimingDelay;
/* Private function prototypes -----------------------------------------------*/
* Function Name  : SysTickHandler
* Description    : This function handles SysTick Handler.
* Input          : None
* Output         : None
* Return         : None
void SysTickHandler(void)
    if(TimingDelay > 0) TimingDelay--;
* Function Name  : USB_HP_CAN_TX_IRQHandler
* Description    : This function handles USB High Priority or CAN TX interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_HP_CAN_TX_IRQHandler(void)
    CAN_ITConfig(CAN_IT_TME, DISABLE);
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN_RX0_IRQHandler(void)
  vu8 temp_flag=0;        //用于在线调试的时候看数据所用
  CanRxMsg RxMessage;
  RxMessage.StdId=0x00;
  RxMessage.ExtId=0x00;
  RxMessage.IDE=0;
  RxMessage.DLC=0;
  RxMessage.FMI=0;
  RxMessage.Data[0]=0x00;
  RxMessage.Data[1]=0x00;
  CAN_Receive(CAN_FIFO0, &RxMessage);
  if((RxMessage.StdId==0x12) && (RxMessage.ExtId==0x34) && (RxMessage.IDE==CAN_ID_EXT)
     && (RxMessage.DLC==2) && ((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xDECA))
    temp_flag = 1;
  else
    temp_flag = 0;
  temp_flag = 0;
* Function Name  : CAN_RX1_IRQHandler
* Description    : This function handles CAN RX1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void CAN_RX1_IRQHandler(void)
 楼主| e_boys 发表于 2010-6-14 15:09 | 显示全部楼层
香版主可否帮忙看看啊? 谢谢了!
McuPlayer 发表于 2010-6-14 15:22 | 显示全部楼层
香斑也挺郁闷的,咋天天看别人的source code呢
 楼主| e_boys 发表于 2010-6-14 16:55 | 显示全部楼层
哈哈!我也不想,但是我**独自一个人搞了一周了还不见进展故来网上请教高手!就等不见高人回帖自得请版主了! 3# McuPlayer
 楼主| e_boys 发表于 2010-6-14 16:56 | 显示全部楼层
哈哈!我也不想,但是我**独自一个人搞了一周了还不见进展故来网上请教高手!久等不见高人回帖只得请版主了!
IJK 发表于 2010-6-14 17:14 | 显示全部楼层
1.CAN正常通信模式,需要至少2个节点
2.用示波器看看CAN_RX引脚的电平,正常应该是高电平
 楼主| e_boys 发表于 2010-6-14 17:38 | 显示全部楼层
我现在检测出一些现象,我改为正常模式后上电一开始检测到了一组波形从CANTX输出,之后就不在出现波形(使用回环模式结果是不停发送的,因为我的程序就是让他不停发送的)
第二个现象是,我使用回环模式下CANTX不停发送信号,我一路跟踪信号到MCP2551-I / SN的第一脚TXD波形仍然是正常,但是我此时用示波器量到MCP2551-I / SN输出引脚CANH和CANL的时候却没有了变化。这里有点晕呀! 6# IJK
 楼主| e_boys 发表于 2010-6-14 17:42 | 显示全部楼层
IJK,谢谢您的回复
我有点疑惑,
1、2个节点是要3个设备吧?
2、如果我现在只有两台一样的设备(都可收发,我使用一台收,一台发)可以发数据吗?
3、正常模式下用示波器测CAN_RX引脚的电平是3.4V左右正常吗?
IJK 发表于 2010-6-15 09:00 | 显示全部楼层
1、2个节点 2个设备就行了
2、如果只有两台一样的设备(都可收发,我使用一台收,一台发),可以发数据
3、正常模式下用示波器测CAN_RX引脚的电平是3.4V左右,基本正常
另外,看CAN初始化(CAN_Polling)是否成功,还要看CAN的状态寄存器。
 楼主| e_boys 发表于 2010-6-15 09:29 | 显示全部楼层
CAN初始化成功,返回PASSED标志,还有就是发生后我检测发送状态寄存器返回值为CANTXPENDING 标志 9# IJK
 楼主| e_boys 发表于 2010-6-15 09:39 | 显示全部楼层
我修改了波特率和那个发送数据个数后发现
如果更改发送数据个数为8个
          TxMessage.DLC=8;
          for(i=0;i<8;i++)
             TxMessage.Data[i]=i;
或者更改波特率设置为如下 CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_9tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_8tq;
  CAN_InitStructure.CAN_Prescaler=200;
以上两种更改都会导致在回环模式下都无法发送正常。
 楼主| e_boys 发表于 2010-6-15 16:09 | 显示全部楼层
哈哈!总算搞定了。我这只瞎猫总算碰上了死耗子!东猜西猜总算找到了问题,发送不成功是我一只稳压管有问题把它拉到地了。发送搞定了有出现接收到的ID出现全0的现象(不过那个程序不是这个,是我改过的精简版本),后来又改成这个OK了(是发送参数变量ID中途被清零了)。
 楼主| e_boys 发表于 2010-6-15 16:10 | 显示全部楼层
谢谢各位的帮忙!谢谢了!
贝多芬爵士 发表于 2011-5-5 18:48 | 显示全部楼层
6# IJK
如果是一些方波正常不呢?
phctgu 发表于 2011-5-17 14:28 | 显示全部楼层
CAN  简单的很
