EM78P153S--WicePlUS,这样定义全局变量也错吗?
4455|5
 楼主| piter_tan 发表于 2010-6-23 01:41 | 显示全部楼层 |阅读模式
什么玩意编译器哦,怎么定义都是错的,请朋友帮忙看一下,谢谢
以下两种全局变量没哪一种可以通过的,编译时提示如下,
E:\DATE\EMIR\emir.c(95): error: undeclared identifier `irtime'
E:\DATE\EMIR\emir.c(140): error: undeclared identifier `irh'
其它寄存器提示同上
#include "EM78P153S.H"
//#include "clrram.h"
//---------------脚位定义-------------------------------
#define  jir  P65   //IR信号输入
#define  pnp_out P62   //驱动脚输出
#define NOP() _asm{nop}
#define WDTC() _asm{wdtc}
unsigned char [email=ir_h@0x20]ir_h@0x20[/email]: bank 1;  // ir高位地址
unsigned char [email=ir_l@0x21]ir_l@0x21[/email]: bank 1;  // ir低位地址
unsigned char [email=ir_d@0x22]ir_d@0x22[/email]: bank 1;  // ir数据码
unsigned char [email=ir_f@0x23]ir_f@0x23[/email]: bank 1;  // ir数据反码
unsigned char [email=ir_time@0x24]ir_time@0x24[/email]: bank 1; // ir时限计数器
unsigned char [email=ir_32@0x25]ir_32@0x25[/email]: bank 0;  // 判断ir循环器
unsigned char [email=gIrh@0x26]gIrh@0x26[/email]: bank 0;
unsigned char [email=gIrl@0x27]gIrl@0x27[/email]: bank 0;
unsigned char [email=gIrd@0x28]gIrd@0x28[/email]: bank 0;
unsigned char [email=gIrdl@0x29]gIrdl@0x29[/email]: bank 0;  //数据码低四位
unsigned char [email=IR_ADDRH@0x2a]IR_ADDRH@0x2a[/email]: bank 0;
unsigned char [email=IR_ADDRL@0x2b]IR_ADDRL@0x2b[/email]: bank 0;
unsigned char [email=flash_ird@0x2c]flash_ird@0x2c[/email]: bank 0; //暂存IRD数
unsigned char ir_h;  // ir高位地址
unsigned char ir_l;  // ir低位地址
unsigned char ir_d;  // ir数据码
unsigned char ir_f;  // ir数据反码
unsigned char ir_time; // ir时限计数器
unsigned char ir_32;  // 判断ir循环器
unsigned char gIrh;
unsigned char gIrl;
unsigned char gIrd;
unsigned char gIrdl;  //数据码低四位
unsigned char IR_ADDRH;
unsigned char IR_ADDRL;
unsigned char flash_ird; //暂存IRD数
bit bir_l;     //连接标志
bit bir;
bit bExit;
//================初始化程序======================
void safeguard_init1()
  RSR=0B00000000;    //0x04,选择BANK0
  P5CR=0;      //端口控制寄存器,设置为输出
  P6CR=0B11111011;   //P6端口控制器,除P62为输出外,基它脚作为输入
  PORT5=0;     //P5端口寄存器,输出为0
  PORT6=0B11111011;   //P5端口寄存器,输出为0
  ir_h=0;
void delay(unsigned char x)//48ms
unsigned char i;
  while(x--)
  for (i = 0; i<3; i++)
void Ir(void)
void main()
Ir();
void _intcall interrupt_l(void) @ 0x08:low_int 0
   _asm
      //save A --> 0x1F ; R3 --> 0x2E ; R4 --> 0x2F
      MOV 0X1F,A   ;backup A to 0x1F
      SWAPA 0X04   ;backup R4 to 0x2F
      MOV 0X2F,A   ;backup R4 to 0x2F
      SWAPA 0X03
      MOV 0X2E,A   ;backup R3 to 0x2E
void _intcall interrupt(void) @ int 0
   //backup C system
/*  _asm
MOV A,0X10 //Depend on WicePlus reports in information window, Output window
MOV 0X2C+1,A
MOV A,0X11
MOV 0X2B+1,A
MOV A,0X12
MOV 0X2A+1,A
MOV A,0X13
MOV 0X29+1,A
MOV A,0X14
MOV 0X28+1,A
  // Write your code (inline assembly or C) here
   //restore C system
/*  _asm
MOV A,0X2C+1 //Depend on WicePlus reports in information window, Output window
MOV 0X10,A
MOV A,0X2B+1
MOV 0X11,A
MOV A,0X2A+1
MOV 0X12,A
MOV A,0X29+1
MOV 0X13,A
MOV A,0X28+1
MOV 0X14,A
  //restore ACC,R3,R4
  _asm
      SWAPA 0X2E   ;restore R3
      MOV 0X03,A
      SWAPA 0X2F   ;restore R4
      MOV 0X04,A
      SWAP 0X1F    ;restore A
      SWAPA 0X1F
ayb_ice 发表于 2010-6-23 08:05 | 显示全部楼层
找个例程看看
 楼主| piter_tan 发表于 2010-6-23 09:39 | 显示全部楼层
上面我也是照百度上的例子来写的,可还是不行
WANGJJ888 发表于 2010-6-23 09:43 | 显示全部楼层
用中微的16P53都不用自己写程序。WANGJJ@MCU.COM.CN
 楼主| piter_tan 发表于 2010-6-23 09:51 | 显示全部楼层
LS的话是如何解释?程序不用自己写?厂家帮忙写吗
zenyunwu 发表于 2010-11-8 22:35 | 显示全部楼层
请问大家EM78P153不用的脚怎么处理最好呀?
