[微控制器/MCU] 我也来玩玩多线程
2911|2
 楼主| 米其林r 发表于 2010-6-27 14:27 | 显示全部楼层 |阅读模式
看着chenzhufly把多线程Photothreads在LPC1343上玩的有声有色,有贴为证http://bbs.**/viewthread.php?tid=103789,我也禁不住要试试。因为LPC1114同样资源紧张,呵呵 下面就一试。
同样我也参考了Photothreads的例程example-small,更多的参考了chenzhufly的photothreads的那个帖子,在帖子里chenzhufly对photothreads已经做过了介绍,这里我就不再重复了。下面是我修改的完的全部代码,附件里有我修改的工程文件。
#include "LPC11xx.h"   /* LPC11xx Peripheral Registers */
#include "gpio.h"
#include "pt.h"
/* Two flags that the two protothread functions use. */
static int protothread1_flag, protothread2_flag;
char flag = 0;
static struct pt pt1, pt2;
typedef unsigned char   uint8;                  //defined for unsigned 8-bits integer variable
typedef signed   char   int8;                   //defined for signed 8-bits integer variable
typedef unsigned int  uint16;                 //defined for unsigned 16-bits integer variable
typedef signed   int  int16;                  //defined for signed 16-bits integer variable
typedef unsigned long   uint32;                 //defined for unsigned 32-bits integer variable
typedef signed   long   int32;                  //defined for signed 32-bits integer variable
typedef float           fp32;                   //single precision floating point variable (32bits)
typedef double          fp64;                   //double precision floating point variable (64bits)
void Delay(uint16 dly);
void DelayMs(uint16 dly);
static int protothread1(struct pt *pt);
static int protothread2(struct pt *pt);
**   Main Function  main()
int main (void)
  /* Basic chip initialization is taken care of in SystemInit() called
   * from the startup code. SystemInit() and chip settings are defined
   * in the CMSIS system_<part family>.c file.
  GPIOInit();
  /* use port0_7 as output event*/
  GPIOSetDir( PORT0, 7, 1 );
  /* Initialize the protothread state variables with PT_INIT(). */
    PT_INIT(&pt1);
    PT_INIT(&pt2);
  while( 1 )
   protothread1(&pt1);
   protothread2(&pt2);
** Function name   : Delay
** Descriptions    : Delay
** Global variables:
** Input parameters:
** Returned value  :
** Calling modules :
** Example     :
** Created by      : LiXiaohai
** Created date    : 2010-04-29
** Modified by     :
** Modified date   :
while(dly--)
  Delay(2678);
** Function name   : void Delay(uint16 dly)
** Returned value  :
** Example     :
** Modified by     :
** Modified date   :
while(dly--);
static int
  /* A protothread function must begin with PT_BEGIN() which takes a
     pointer to a struct pt. */
  PT_BEGIN(pt);
  /* We loop forever here. */
  while(1) {
    /* Wait until the other protothread has set its flag. */
    PT_WAIT_UNTIL(pt, protothread2_flag != 0);
    flag = ~flag;
    GPIOSetValue(PORT0,7,flag);
    /* We then reset the other protothread's flag, and set our own
       flag so that the other protothread can run. */
    protothread2_flag = 0;
    protothread1_flag = 1;
    /* And we loop. */
  /* All protothread functions must end with PT_END() which takes a
    PT_END(pt);
* The second protothread function. This is almost the same as the
* first one.
static int
  PT_BEGIN(pt);
  while(1) {
    /* Let the other protothread run. */
    protothread2_flag = 1;
    PT_WAIT_UNTIL(pt, protothread1_flag != 0);
    DelayMs(500);
    /* We then reset the other protothread's flag. */
    protothread1_flag = 0;
    /* And we loop. */
  PT_END(pt);
LPC300 发表于 2010-6-27 14:28 | 显示全部楼层
好东西,不过现在我还领会不了啊!
 楼主| 米其林r 发表于 2010-6-27 14:29 | 显示全部楼层
小提示:以前不知道怎么导入不压缩的工程文件,今天我又研究了一下,居然还真让我发现了,呵呵。下面就说说方法。
2010-5-16 22:00
点击如上图中的红圈表示的Import existing projects,会弹出如下的对话框
2010-5-16 22:00
点击红圈表示后面的Browse按钮找到对应的工程文件夹即可,如下图示
