29466+ 6936 通信问题.....附有程序.
3002|5
 楼主| rocky_bian 发表于 2010-7-19 11:05 | 显示全部楼层 |阅读模式
这个main.c 里面含有发送 与接受,当有按键时,发送数据,另一个设备接收数据,这个过程是能实现的,问题是如何才能正确显示接受到的数据
 楼主| rocky_bian 发表于 2010-7-19 11:08 | 显示全部楼层
当有按键的时候,将 TxPayloadBuffer[]的数据发送出去
SW1_Data_ADDR |= SW1_MASK; // Write a 1 so we can read the switch
        if (!(SW1_Data_ADDR & SW1_MASK))
            // Transmit a packet when the "Switch 1" button is pressed.
            nRED_LED_Data_ADDR &= ~nRED_LED_MASK; // Red LED On
            Delay(DELAY_COUNT); // Give the user a chance to see the LED.
            // This also guarantees the receiver has been running for at least 1ms.
            // Stop receiving so that we can transmit
            RadioAbort();
            RadioSetPtr(TxPayloadBuffer); // Set the transmit buffer
            RadioBlockingTransmit(0, PAYLOAD_LENGTH); // Send it
            ++TransmittedCount;
            nRED_LED_Data_ADDR |= nRED_LED_MASK; // Red LED Off
            // Wait for user to release the "Switch 1" button.
            while(!(SW1_Data_ADDR & SW1_MASK));
            RadioSetPtr(RxPayloadBuffer); // Set the receive buffer
            RadioStartReceive(); // Restart the receiver
            Delay(SWITCH_DEBOUCE); // Debounce switch
 楼主| rocky_bian 发表于 2010-7-19 11:09 | 显示全部楼层
main里面循环检测接受的状态.
        RxState = RadioGetReceiveState();
        if (RxState & RADIO_COMPLETE)
            ReceivedPayloadSize = RadioEndReceive();
            if (!(RxState & RADIO_ERROR))
                if (ReceivedPayloadSize == PAYLOAD_LENGTH)
                    // Successfully received a packet
                    ++ReceivedCount;
                    // Give the user feedback a packet has been received
                    nGREEN_LED_Data_ADDR &= ~nGREEN_LED_MASK; // Green LED On
                    nGREEN_LED_Data_ADDR |= nGREEN_LED_MASK; // Green LED Off
                // else drop Packet. Not the correct length
            else
                // Packet received with an error.
            // Restart the receive operation
 楼主| rocky_bian 发表于 2010-7-19 11:11 | 显示全部楼层
问题是如何才能得到接受的数据(数组)呢???按道理接受的数据应该放置在RxPayloadBuffer里面!
jxin 发表于 2010-7-23 18:08 | 显示全部楼层
还没解决阿, 这个要专家才能帮上啊
 楼主| rocky_bian 发表于 2010-8-19 15:44 | 显示全部楼层
又一个月了 ,还是没有解决...玩RF的人真的太少了,我都快奔溃了
