[STM32F4] Jlink 下载不进去
1755|2
 楼主| sdibt 发表于 2017-7-1 18:53 | 显示全部楼层 |阅读模式
JLink info:
DLL: V4.15n, compiled Jun 18 2010 19:55:09
Firmware: J-Link V9 compiled Apr 22 2016 11:47:06
Hardware: V9.20
Feature(s) : RDI, GDB, FlashDL, FlashBP, JFlash, RDDI
**JLink Warning: No matching core found.
* JLink Info: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
**JLink Warning: Failed to reset CPU. VECTRESET has confused core.
* JLink Info: Core is locked-up, trying to disable WDT.
* JLink Info: CPU core locked up
* JLink Info: CPU halted
**JLink Warning: T-bit of XPSR is 0 but should be 1. Changed to 1.
***JLink Error: Parity error (Data = 0xF9FBFCFD, ReceivedParity = 1)
***JLink Error: Could not start CPU core. (ErrorCode: -1)
这种情况应该怎么解决,求助大神帮忙
 楼主| sdibt 发表于 2017-7-2 09:18 | 显示全部楼层
有没有人碰到这样的情况,求指导!!!
grant_jx 发表于 2017-7-2 09:57 | 显示全部楼层
正版,还是盗版JLink?
之前这个工具是否正常工作过?
