[AVR单片机] 用定时器1中断输出方波的汇编框架(适用初学AVR者)
8747|34
 楼主| 宇宙飞船 发表于 2010-7-25 23:55 | 显示全部楼层 |阅读模式
;MCU is mega16 ,xtal for 8M
.include  "m16def.inc"
.include  "Reg_Mem_def.inc"
.include  "Constant_def.inc"
     .ORG 0x00
          RJMP  Reset
;*********************MEGA16***********************
      .ORG $002 ;External Interrupt0 Vector Address
        RETI
      .ORG $004 ;External Interrupt1 Vector Address
        RETI
      .ORG $006 ;Output Compare2 Interrupt Vector Address
        RETI
      .ORG $008 ;Overflow2 Interrupt Vector Address
        RETI
      .ORG $00A ;Input Capture1 Interrupt Vector Address
        RETI
      .ORG $00C ;Output Compare1A Interrupt Vector Address
        RETI
      .ORG $00E ;Output Compare1B Interrupt Vector Address
        RETI
      .ORG $010 ;Overflow1 Interrupt Vector Address
        RJMP  Timer_1
      .ORG $012 ;Overflow0 Interrupt Vector Address
        RETI
      .ORG $014 ;SPI Interrupt Vector Address
        RETI
      .ORG $016 ;UART Receive Complete Interrupt Vector Address
        RETI
      .ORG $018 ;UART Data Register Empty Interrupt Vector Address
        RETI
      .ORG $01A ;UART Transmit Complete Interrupt Vector Address
        RETI
      .ORG $01C ;ADC Interrupt Vector Address
        RETI
      .ORG $01E ;EEPROM Interrupt Vector Address
        RETI
      .ORG $020 ;Analog Comparator Interrupt Vector Address
        RETI
      .ORG $022   ;Irq. vector address for Two-Wire Interface
        RETI
      .ORG $024   ;External Interrupt2 Vector Address
        RETI
      .ORG $026   ;Output Compare0 Interrupt Vector Address
        RETI
      .ORG $028   ;Store Program Memory Ready Interrupt Vector Address
        RETI
Timer_1:
        push   temp
        in     temp,sreg
        push   temp
     LDI    temp,high(65536-1250);10ms write:
     OUT    TCNT1H,temp          ; first write to H and then L while write to TCNT1.
     LDI    temp,low(65536-1250) ; first read  L and then H while read from TCNT1.
     OUT    TCNT1L,temp
;------------cpl the pc7 ----------------
        ldi    temp_2,(1<<;PC7)
        in     temp,PORTC
        eor    temp,temp_2
        out    PORTC,temp
        pop    temp
  out    sreg, temp
  pop    temp
        RETI
Reset:
        LDI  temp,Low(RAMEND)
     OUT  SPL,temp       ;Set stack pointer to last internal RAM location
     LDI  temp,High(RAMEND)
     OUT  SPH,temp
        LDI   temp,0
        OUT   DDRD,temp
     OUT   DDRC,temp
     OUT   DDRB,temp
        OUT   DDRA,temp
        OUT   PORTA,temp
        OUT   PORTB,temp
     OUT   PORTC,temp
     OUT   PORTD,temp
        LDI   temp,(1<<;PC7)  ;enable bit7 of portc to output.
        OUT   DDRC,temp
     cli                ;off all interrupt
        RCALL Initialize_Timer1
        RCALL Enable_Timer1_interrupt
        sei
loop_1:
        rjmp   loop_1
Initialize_Timer1:
       LDI  temp,CLK_DIV64      ;Timer1 base time for 0.125*64=8us
       OUT  TCCR1B,temp
       RET
Enable_Timer1_interrupt:
;---------set timer1 to interrupt.----------------------
       LDI   temp,0xFF       ;clear the interrupt mark of timer.
       OUT   TIFR,temp
       LDI   temp,0B00000100 ;enable timer1 interrupt
       OUT   TIMSK,temp
    LDI   temp,high(65536-1250);10ms,write:
    LDI   temp,low(65536-1250);read:
    OUT   TCNT1L,temp     ;first read  L and then H while read from TCNT1.
       RET
hotpower 发表于 2010-7-26 03:04 | 显示全部楼层
路过看看有点眼晕~~~
让俺感觉回到了原始社会,至少像是到了秦朝~~~
hqgboy 发表于 2010-7-26 09:23 | 显示全部楼层
等到了清朝,再过来看看程序。
电子菜鸟435 发表于 2010-7-26 09:46 | 显示全部楼层
 楼主| 宇宙飞船 发表于 2010-7-26 11:26 | 显示全部楼层
俺将陆续整理出以下两个子程序,
1。算法中必需掌握的flash查表技术。
2。二进制转十进制的子程序以及其算法,这是所有类型单片机作数字显示都必需用到的技术,有了这项技术,就不必再依赖C编译器。从而可以设计出一个电子钟来。
xuyiyi 发表于 2010-7-26 11:31 | 显示全部楼层
呵呵!
飞船大师e文真好,全部用e文解释,俺初中生看不懂,何时飞船大师有空,请用咱们老祖宗的文字写一遍解释。
 楼主| 宇宙飞船 发表于 2010-7-26 11:38 | 显示全部楼层
因赶时间整理,来不及用中文注解,等俺有空了,再用中文重新注译一次。
xuyiyi 发表于 2010-7-26 12:30 | 显示全部楼层
谢谢飞船大师。
康康同学 发表于 2010-7-26 16:15 | 显示全部楼层
楼主从汇编开始讲解,看着让人生畏。另外,贴出的程序有些字符显示成表情了。
粉丝 发表于 2010-7-28 13:50 | 显示全部楼层
5楼真把那两个子程序放出来,那用C的肯定两腿发软,更不用说用C++的。。。。
 楼主| 宇宙飞船 发表于 2010-7-28 14:44 | 显示全部楼层
AVR的竟争对手实在是大多了,那些竟争对手的销售都是上纲上线的,飞船这几天正忙着出招反击那些阴谋家,把整理资料的一些精力浪费在版面整顿上了。
hotpower 发表于 2010-7-29 07:47 | 显示全部楼层
AVR从汇编开始本身就是败笔~~~
xuyiyi 发表于 2010-7-29 12:30 | 显示全部楼层
俺学AVR就是从汇编开始的,那时只有90S1200,  一片90S1200要20多块大洋,  那时AVR还没有C语言,不用汇编那只能直接打机器码了。:dizzy:
俺早期用Z80, MCS48时打过机器码,挺累的,挺辛苦的,千辛万苦的输入一小段程序调通后感到异常的兴奋,那种感觉真的很奇妙,象吸了白粉似的。;P
 楼主| 宇宙飞船 发表于 2010-7-30 12:24 | 显示全部楼层
真是多灾多难,昨天深夜想倒点汇编资料出来,一开工作的主机,竟发出啪啪声,接着闻到一股元件烧焦的味道。今天一早,拆开长城ATX2800电源一看,竟是PCB阻焊剂出现不稳定,造成PCB漏电,线间打火,击穿第一重的开关管,好在这电源有双重保护,估计硬盘应该不会出事。
这段期间连续出现两件巧合的事件,一件是在DIY坛子,本想直击报道DIY的全过程,但那进口的示波器竟突然**,检查发现同样是PCB漏电造成打火。有时,飞船也在想,是不是机缘未到,老天给出的指示。
还是大家用C的意念力实在是太强,以至于会造成有此巧合的结果。
hotpower 发表于 2010-7-31 01:13 | 显示全部楼层
汇编最大的确定就是变量难于驾驭~~~
51的汇编还好些,其他的都晕~~~
hotpower 发表于 2010-7-31 09:11 | 显示全部楼层
5楼课题应该是c/c++的长项而非汇编之优势。
现在是注重编程效率而非程序效率的年代。
汇编已是昔日黄花,满地芳香早已飘散…
大容量、高速度以及编译技术的提高和发展,c/c++必将全面取代汇编。
试问在pc初期有几个没用过汇编?当今有几个在pc端还用汇编???
评分
参与人数 1威望 +1 收起 理由
xuyiyi + 1
查看全部评分
xuyiyi 发表于 2010-7-31 10:12 | 显示全部楼层
HOT大叔正解!
年代不同啦!
时代也不同啦!
hotpower 发表于 2010-8-1 02:33 | 显示全部楼层
不管AVR是否没落,但技术层面上要有追求。
俺散布C++可谓“谬论和退化”,但汇编就能达到境界了吗???
假若AVR真的消亡,AVR专用的汇编能转行再入“境界”???能否???
这个AVR事件已经给人们带来最好的思索~~~
aweyfan 发表于 2010-8-1 20:53 | 显示全部楼层
把avr的定时器当51用,可以说是很烂的做法了
随便再跑点别的程序,输出的方波频率可能就不稳了
xwj 发表于 2010-8-1 21:01 | 显示全部楼层
赞同楼上,偶顶~~~
个人签名:技术是玩出来的!
75
