LM3S3739SSI读不到数据?
3117|0
 楼主| yuchl 发表于 2010-8-23 15:59 | 显示全部楼层 |阅读模式
lm, pi, se, IO, GPIO
LM3S的SPI,用SPI读写TC72一直都不到数据,设置如下。
    // Enables a peripheral SSI0
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
    // Configures pin(s) for use by the SSI peripheral
    // PA2 SSI0CLK(SSCK)  PA4 SSI0RX(MISO) PA5 SSI0TX(MOSI)
    GPIOPinTypeSSI(GPIO_PORTA_BASE, (GPIO_PIN_2 | GPIO_PIN_4 | GPIO_PIN_5));
    //GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_2);
    // PA4 SSI0RX(MISO)
    //GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_4);
    // PA5 SSI0TX(MOSI)
    //GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5);
    // Disables the synchronous serial interface
    SSIDisable(SSI0_BASE);
   // Configure the SSI, 1MHZ
    SSIConfigSetExpClk(SSI0_BASE,   // Base
                                 //SysCtlClockGet(),  // SSIClk
                                20000000,            // 5MHZ
                               SSI_FRF_MOTO_MODE_1, // Protocol
                               SSI_MODE_MASTER,     // Mode
                               1000000,             // BitRate
                               8 // DataWidth
   // Enables the synchronous serial interface
    SSIEnable(SSI0_BASE);
有用模块读写SPI EEPROM的吗?
  // CS 25LC256
CS_25LC256 = 0;
// Write Enable
//SSIDataPut(SSI0_BASE, 0x06);
// Read data from memory array beginning at selected address
SSIDataPut(SSI0_BASE, 0x03);
SSIDataPut(SSI0_BASE, 0x00);
//while((HWREG(SSI0_BASE + SSI_O_SR) & 0x04) == 0x04)
//{ SSIDataGet(SSI0_BASE, pulData);}
SSIDataPut(SSI0_BASE, 0xFF);
SSIDataGet(SSI0_BASE, pulData++);
CS_25LC256 = 1;
读不到数据?
