[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _rom
2082|0
 楼主| wangjun88 发表于 2010-8-30 10:59 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
entity v_rom is
port( pc : in std_logic_vector(8 downto 0);
instruction : out std_logic_vector(15 downto 0));
end v_rom;
architecture rom of v_rom is
component LPM_ROM
generic (
LPM_WIDTH: integer := 16;
LPM_WIDTHAD: integer := 9;
LPM_NUMWORDS: integer := 512;
LPM_FILE: string := "program.mif";
LPM_ADDRESS_CONTROL: string := "UNREGISTERED";
LPM_OUTDATA: string := "UNREGISTERED"
port (
ADDRESS: in STD_LOGIC_VECTOR(LPM_WIDTHAD-1 downto 0);
inclock: IN STD_LOGIC := '0';
outclock: IN STD_LOGIC := '0';
memenab: IN STD_LOGIC := '1';
Q: out STD_LOGIC_VECTOR(LPM_WIDTH-1 downto 0)
end component;
signal gnd, vcc : std_logic;
begin
vcc <= '1';
gnd <= '0';
v1 : LPM_ROM
port map (address => pc, memenab => vcc, q => instruction);
end rom;
