[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _iodecoder
2437|0
 楼主| yun888 发表于 2010-8-30 11:09 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
entity v_iodecoder is
port( ioaddr : in integer range 0 to 16#3f#;
rd_io, wr_io : in std_logic;
rd_sreg, wr_sreg : out std_logic;
rd_gimsk, wr_gimsk, rd_timsk, wr_timsk, rd_tifr,wr_tifr : out std_logic;
rd_mcucr,wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0,wr_tcnt0 : out std_logic;
rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb : out std_logic;
rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc : out std_logic;
rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind : out std_logic
end v_iodecoder;
architecture iodecoder of v_iodecoder is
begin
process(rd_io, ioaddr)
begin
rd_sreg <= '0';
rd_gimsk <= '0';
rd_timsk <= '0';
rd_tifr <= '0';
rd_mcucr <= '0';
rd_tccr0 <= '0';
rd_tcnt0 <= '0';
rd_portb <= '0';
rd_ddrb <= '0';
rd_pinb <= '0';
rd_portc <= '0';
rd_ddrc <= '0';
rd_pinc <= '0';
rd_portd <= '0';
rd_ddrd <= '0';
rd_pind <= '0';
if rd_io = '1' then
case ioaddr is
when 16#3f# => rd_sreg <= '1';
when 16#3b# => rd_gimsk <= '1';
when 16#39# => rd_timsk <= '1';
when 16#38# => rd_tifr <= '1';
when 16#35# => rd_mcucr <= '1';
when 16#33# => rd_tccr0 <= '1';
when 16#32# => rd_tcnt0 <= '1';
when 16#18# => rd_portb <= '1';
when 16#17# => rd_ddrb <= '1';
when 16#16# => rd_pinb <= '1';
when 16#15# => rd_portc <= '1';
when 16#14# => rd_ddrc <= '1';
when 16#13# => rd_pinc <= '1';
when 16#12# => rd_portd <= '1';
when 16#11# => rd_ddrd <= '1';
when 16#10# => rd_pind <= '1';
when others =>
end case;
end if;
end process;
process(wr_io, ioaddr)
begin
wr_sreg <= '0';
wr_gimsk <= '0';
wr_timsk <= '0';
wr_tifr <= '0';
wr_mcucr <= '0';
wr_tccr0 <= '0';
wr_tcnt0 <= '0';
wr_portb <= '0';
wr_ddrb <= '0';
wr_portc <= '0';
wr_ddrc <= '0';
wr_portd <= '0';
wr_ddrd <= '0';
if wr_io = '1' then
case ioaddr is
when 16#3f# => wr_sreg <= '1';
when 16#3b# => wr_gimsk <= '1';
when 16#39# => wr_timsk <= '1';
when 16#38# => wr_tifr <= '1';
when 16#35# => wr_mcucr <= '1';
when 16#33# => wr_tccr0 <= '1';
when 16#32# => wr_tcnt0 <= '1';
when 16#18# => wr_portb <= '1';
when 16#17# => wr_ddrb <= '1';
when 16#15# => wr_portc <= '1';
when 16#14# => wr_ddrc <= '1';
when 16#12# => wr_portd <= '1';
when 16#11# => wr_ddrd <= '1';
when others =>
end case;
end if;
end process;
end iodecoder;
