| 范例:opencore组织RISCMCU IP Core全套最新代码 __controlunit | ----------------------------------------------------------------------------
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity v_controlunit is
port( ir : in std_logic_vector(15 downto 0);
sr : in std_logic_vector(7 downto 0);
clk, clrn : in std_logic;
skip, extirq, timerirq : in std_logic;
en : buffer std_logic;
wr_reg : buffer std_logic;
rd_ram, wr_ram, ld_mar, ld_mbr, inc_zp, dec_zp : out std_logic;
sren : out std_logic_vector (6 downto 0);
c2a,c2b : out std_logic;
asel : out integer range 0 to 1;
bsel : out integer range 0 to 3;
bitsel : out integer range 0 to 7;
set : out std_logic;
add, subcp, logic, right, dir, pass_a : out std_logic;
wcarry : out std_logic;
logicsel : out integer range 0 to 3;
rightsel : out integer range 0 to 2;
dirsel : out integer range 0 to 1;
addoffset : out std_logic;
push, pull : out std_logic;
cpse, skiptest : out std_logic;
bclr,bset : out std_logic;
bld : out std_logic;
cbisbi : out std_logic;
vec2, vec4 : buffer std_logic;
dest : out integer range 0 to 15;
srsel : out integer range 0 to 7;
offset : out std_logic_vector(8 downto 0);
clr_i, set_i, clr_intf, clr_tov0 : out std_logic;
rd_sreg, wr_sreg : out std_logic;
rd_gimsk, wr_gimsk, rd_timsk, wr_timsk, rd_tifr,wr_tifr : out std_logic;
rd_mcucr,wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0,wr_tcnt0 : out std_logic;
rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb : out std_logic;
rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc : out std_logic;
rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind : out std_logic
end v_controlunit;
architecture controlunit of v_controlunit is
type statetype is (exes, nop2s, nop1s, lds, sts, cbisbis, sbicss, sleeps);
signal ibr : std_logic_vector(11 downto 0);
signal state : statetype;
signal one, neg, imm : std_logic;
signal
cpcm, sbcm, addm, cpsem, cpm, subm, adcm, andm, eorm, orm, movm,
cpim, sbcim, subim, orim, andim, ldm, stm, comm, negm, swapm, incm,
asrm, lsrm, rorm, decm, bsetm, bclrm, retm, retim, sleepm,
cbisbim, sbicsm, inm, outm, rjmpm, rcallm, ldim,
brbcsm, bldm, bstm, sbrcsm,
ld_incm, ld_decm, st_incm, st_decm : std_logic;
signal ioaddr : integer range 0 to 16#3f#;
signal rd_io, wr_io, break, irq, get_io, wr_ram_fast, branchtest, branch, jmp : std_logic;
component v_iodecoder
port( ioaddr : in integer range 0 to 16#3f#;
rd_io, wr_io : in std_logic;
end component;
begin
-- Instruction Decoder
-- Decode 51 instructions generate 46 'm signals
-- Combine brbcs+brbs (brbcs) cbi+sbi (cbisbi) sbrc+sbrs (sbrcs) sbic+sbis (sbics)
process(ir, wr_reg, get_io, ibr)
begin
cpcm <= '0'; sbcm <= '0'; addm <= '0';
cpsem <= '0'; cpm <= '0'; subm <= '0'; adcm <= '0';
andm <= '0'; eorm <= '0'; orm <= '0'; movm <= '0';
cpim <= '0'; sbcim <= '0'; subim <= '0'; orim <= '0'; andim <= '0';
ldm <= '0'; stm <= '0'; comm <= '0'; negm <= '0'; swapm <= '0'; incm <= '0';
asrm <= '0'; lsrm <= '0'; rorm <= '0'; decm <= '0';
bsetm <= '0'; bclrm <= '0'; retm <= '0'; retim <= '0'; sleepm <= '0';
cbisbim <= '0'; sbicsm <= '0';
inm <= '0'; outm <= '0'; rjmpm <= '0'; rcallm <= '0'; ldim <= '0';
brbcsm <= '0'; bldm <= '0'; bstm <= '0'; sbrcsm <= '0';
ld_incm <= '0'; ld_decm <= '0'; st_incm <= '0'; st_decm <= '0';
case ir(15 downto 12) is
when "0000" =>
if ir(11 downto 10) = "01" then cpcm <= '1'; end if;
if ir(11 downto 10) = "10" then sbcm <= '1'; end if;
if ir(11 downto 10) = "11" then addm <= '1'; end if;
when "0001" =>
if ir(11 downto 10) = "00" then cpsem<= '1'; end if;
if ir(11 downto 10) = "01" then cpm <= '1'; end if;
if ir(11 downto 10) = "10" then subm <= '1'; end if;
if ir(11 downto 10) = "11" then adcm <= '1'; end if;
when "0010" =>
if ir(11 downto 10) = "00" then andm <= '1'; end if;
if ir(11 downto 10) = "01" then eorm <= '1'; end if;
if ir(11 downto 10) = "10" then orm <= '1'; end if;
if ir(11 downto 10) = "11" then movm <= '1'; end if;
when "0011" =>
cpim <= '1';
when "0100" =>
sbcim <= '1';
when "0101" =>
subim <= '1';
when "0110" =>
orim <= '1';
when "0111" =>
andim <= '1';
when "1000" =>
if ir(11 downto 9) = "000" then ldm <= '1'; end if;
if ir(11 downto 9) = "001" then stm <= '1'; end if;
when "1001" =>
if ir(1 downto 0) = "01" then ld_incm <= '1'; end if;
if ir(1 downto 0) = "10" then ld_decm <= '1'; end if;
end if;
if ir(1 downto 0) = "01" then st_incm <= '1'; end if;
if ir(1 downto 0) = "10" then st_decm <= '1'; end if;
end if;
if ir(11 downto 9) = "010" then
case ir(3 downto 0) is
when "0000" => comm <= '1';
when "0001" => negm <= '1';
when "0010" => swapm <= '1';
when "0011" => incm <= '1';
when "0101" => asrm <= '1';
when "0110" => lsrm <= '1';
when "0111" => rorm <= '1';
when "1010" => decm <= '1';
when "1000" =>
if ir(8 downto 7) = "00" then bsetm <= '1'; end if;
if ir(8 downto 7) = "01" then bclrm <= '1'; end if;
if ir(8 downto 7) & ir(4) = "100" then retm <= '1'; end if;
if ir(8 downto 7) & ir(4) = "101" then retim <= '1'; end if;
if ir(8 downto 7) = "11" then sleepm <= '1'; end if;
when others =>
end case;
elsif ir(11 downto 10) = "10" then
if ir(8) = '0' then cbisbim <= '1'; -- cbi, sbi
else sbicsm <= '1'; end if; -- sbic, sbis
end if;
when "1011" =>
if ir(11) = '0' then inm <= '1';
else outm <= '1';
end if;
when "1100" =>
rjmpm <= '1';
when "1101" =>
rcallm <= '1';
when "1110" =>
ldim <= '1';
when "1111" =>
if ir(11) = '0' then brbcsm <= '1'; end if;
if ir(11 downto 9) = "100" then bldm <= '1'; end if;
if ir(11 downto 9) = "101" then bstm <= '1'; end if;
if ir(11 downto 10) = "11" then sbrcsm <= '1'; end if;-- sbrc, sbrs
when others =>
end case;
-- Generate Fetch Stage Signals : C2A and C2B (C2A active also when fetch I/O)
if ((ibr(7 downto 4) = ir(7 downto 4)) and wr_reg = '1') or get_io = '1' then
c2a <= '1';
else
c2a <= '0';
end if;
if (ibr(7 downto 4) = ir(3 downto 0)) and wr_reg = '1' then
c2b <= '1';
else
c2b <= '0';
end if;
end process;
-- Generate wcarry, logicsel, rightsel and dirsel
-- Load IBR with IR when EN active
process(clk,clrn)
begin
if clrn = '0' then
ibr <= "000000000000";
wcarry <= '0';
logicsel <= 0;
rightsel <= 0;
dirsel <= 0;
elsif clk'event and clk = '1' then
if en = '1' then
ibr <= ir(11 downto 0);
end if;
wcarry <= adcm or sbcm or sbcim or cpcm;
if orm = '1' or orim = '1' then logicsel <= 1;
elsif eorm = '1' then logicsel <= 2;
elsif comm = '1' then logicsel <= 3;
else logicsel <= 0;
end if;
if rorm = '1' then rightsel <= 1;
elsif asrm = '1' then rightsel <= 2;
else rightsel <= 0;
end if;
if swapm = '1' then dirsel <= 1;
else dirsel <= 0;
end if;
end if;
end process;
-- Finite State Machine
irq <= (timerirq or extirq) and sr(7);
break <= branch or skip or irq;
process(clk, clrn)
begin
if clrn = '0' then
state <= exes;
en <= '1'; get_io <= '0';
pass_a <= '0'; wr_reg <= '0'; sren <= "0000000";
rd_io <= '0'; wr_io <= '0'; rd_ram <= '0'; wr_ram_fast <= '0';
ld_mar <= '0'; ld_mbr <= '0'; inc_zp <= '0'; dec_zp <= '0';
add <= '0'; subcp <= '0'; logic <= '0'; right <= '0'; dir <= '0';
jmp <= '0'; push <= '0'; pull <= '0'; branchtest <= '0';
bclr <= '0'; bset <= '0'; bld <= '0';
cpse <= '0'; skiptest <= '0';
cbisbi <= '0';
vec2 <= '0'; vec4 <= '0'; set_i <= '0';
cbisbi <= '0';
case state is
when exes =>
if break = '1' then
if branch = '1' then
state <= nop1s;
elsif skip = '1' then
elsif irq = '1' then
state <= nop2s;
push <= '1';
if extirq = '1' then
vec2 <= '1';
else
vec4 <= '1';
end if;
end if;
else
if rjmpm = '1' or rcallm = '1' or retm = '1' or retim = '1' then
state <= nop2s;
elsif cbisbim = '1' then
state <= cbisbis;
elsif sbicsm = '1' then
state <= sbicss;
elsif ldm = '1' or ld_incm = '1' or ld_decm = '1' then
state <= lds;
elsif stm = '1' or st_incm = '1' or st_decm = '1' then
state <= sts;
elsif sleepm = '1' then
state <= sleeps;
end if;
-- PC signals
jmp <= rjmpm or rcallm; -- encoded
push <= rcallm;
pull <= retm or retim;
-- PC and IR signals
en <= not (cbisbim or sbicsm
or stm or st_incm or st_decm or
ldm or ld_incm or ld_decm);
-- General Purpose Register File signals
wr_reg <= addm or adcm or incm
or subm or subim or sbcm or sbcim or decm or negm
or andm or andim or orm or orim or eorm or comm
or lsrm or rorm or asrm
or ldim or movm or swapm
or inm;
inc_zp <= ld_incm or st_incm;
dec_zp <= ld_decm or st_decm;
-- ALU signals
add <= addm or adcm or incm;
subcp <= subm or subim or sbcm or sbcim or decm or negm
or cpm or cpim or cpcm;
logic <= andm or andim or orm or orim or eorm or comm;
right <= lsrm or rorm or asrm;
dir <= ldim or movm or swapm;
bld <= bldm;
pass_a <= outm or stm or st_incm or st_decm;
cpse <= cpsem;
skiptest <= sbrcsm;
-- SR signals
bclr <= bclrm;
bset <= bsetm;
set_i <= retim;
sren(0) <= addm or adcm
or subm or subim or sbcm or sbcim or cpm or cpcm or cpim or negm
or comm
or lsrm or rorm or asrm;
for i in 1 to 4 loop
sren(i) <= addm or adcm or incm
or subm or subim or sbcm or sbcim or cpm or cpcm or cpim or decm or negm
end loop;
sren(5) <= addm or adcm
or subm or subim or sbcm or sbcim or cpm or cpcm or cpim or negm;
sren(6) <= bstm;
-- Data RAM signals
ld_mar <= ldm or ld_incm or ld_decm or stm or st_incm or st_decm;
ld_mbr <= stm or st_incm or st_decm;
-- I/O decoder signals
wr_io <= outm;
rd_io <= inm or sbicsm or cbisbim;
if inm = '1' or outm = '1' then
ioaddr <= conv_integer(ir(10 downto 9) & ir(3 downto 0));
else
ioaddr <= conv_integer('0' & ir(7 downto 3));
end if;
-- Branch Evaluation Unit signal
branchtest <= brbcsm;
-- Fetch I/O, generate C2A
get_io <= cbisbim or sbicsm;
end if;
when nop2s =>
state <= nop1s;
when nop1s =>
state <= exes;
when cbisbis =>
state <= exes;
cbisbi <= '1';
wr_io <= '1';
when sbicss =>
state <= exes;
skiptest <= '1';
when lds =>
state <= exes;
wr_reg <= '1';
rd_ram <= '1';
when sts =>
state <= exes;
wr_ram_fast <= '1';
when sleeps =>
en <= '0';
if irq = '1' then
en <= '1';
state <= nop2s;
push <= '1';
vec2 <= '1';
else
vec4 <= '1';
end if;
end if;
end case;
end if;
end process;
-- Generate Delayed WR_RAM signal to avoid writing to wrong address
process(state, wr_ram_fast)
begin
if state = exes then
wr_ram <= wr_ram_fast;
else
wr_ram <= '0';
end if;
end process;
process(branchtest, sr, ibr)
begin
if branchtest = '1' and (sr(conv_integer(ibr(2 downto 0))) = not ibr(10)) then
branch <= '1';
else
branch <= '0';
end if;
end process;
-- IO address decoder
iodec : v_iodecoder
port map (ioaddr, rd_io, wr_io, rd_sreg, wr_sreg, rd_gimsk, wr_gimsk, rd_timsk, wr_timsk, rd_tifr, wr_tifr, rd_mcucr, wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0, wr_tcnt0, rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb, rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc, rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind);
-- Intruction Buffer Register (IBR) to signals ------------------
dest <= conv_integer(ibr(7 downto 4));
srsel <= conv_integer(ibr(6 downto 4));
set <= ibr(9);
bitsel <= conv_integer(ibr(2 downto 0));
offset <= ibr(8 downto 0) when jmp = '1' else
ibr(9) & ibr(9) & ibr(9 downto 3);
-- Generate Fetch Stage Signals : ASEL and SEL
imm <= subim or sbcim or cpim or andim or orim or ldim;
one <= incm or decm;
neg <= negm;
asel <= 1 when neg = '1' and get_io = '0' else
0;
bsel <= 1 when neg = '1' else
2 when imm = '1' else
3 when one = '1' else
0;
-- Decode Control Signal
addoffset <= branch or jmp; -- PC
clr_i <= vec2 or vec4; -- PC
clr_intf <= vec2; -- External Interrupt
clr_tov0 <= vec4; -- Timer
end controlunit;
