【经验】ISE 6.2引起“对象名已存在”系统错误的解决
2318|0
 楼主| wangjun88 发表于 2010-8-30 11:32 | 显示全部楼层 |阅读模式
se, TI, ic, AN, ST
原来是电脑安装了MultiLINX Cable drivers引起的问题.在设备管理中删掉了Jungo项下面的重复驱动就行了.
XILINX公司网站描述如下:
General Description:
When I install ISE 6.2i CD 2 of 2, an "Object name already exists" system error occurs during the installation of the MultiLINX Cable drivers.
Solution 1:
On some Windows platforms, this error is caused by an error condition when the registry is written to during the MultiLINX Cable installation. You can click "OK" and safely ignore this error.
When the MultiLINX USB cable is plugged in on certain Windows platforms, Windows might not automatically associate the MultiLINX driver with the MultiLINX Cable. If this occurs, use the Windows "Browse" dialog box and manually select the "MultiLINX Cable" association.
Solution 2:
If the problem continues once the software is installed, you might need to remove duplicate installed cable drivers from the Windows 2000/XP Device Manager. To remove the duplicate driver, follow these steps:
1. Open the System Properties dialog box from the Control Panel.
2. Click on the Hardware tab.
3. Under the Device Manager section, click on the Device Manager button.
4. Under the Jungo section, remove any duplicate icons.
