为MediaPlayer增加 FFT频谱显示功能,仿windows效果,有源码
12672|6
 楼主| liuwei0908 发表于 2010-8-31 17:09 | 显示全部楼层 |阅读模式
硬件平台:S3C2450 + 7寸TFT([email=800x480@24bpp]800x480@24bpp[/email])
 楼主| liuwei0908 发表于 2010-8-31 17:10 | 显示全部楼层
源码:
 楼主| liuwei0908 发表于 2010-8-31 17:11 | 显示全部楼层
在实际硬件平台上的运行效果:
 楼主| liuwei0908 发表于 2010-9-2 13:58 | 显示全部楼层
源代码:
#include "Include.h"
const U32 __HeapSize =4096;
const U32 __StackSize =1024;
const U32 __Priority =200;
const char __Name[32] ="FFT 测试";
const U32 __Icon =0;
const char __IconPath[32] ="0.bmp";
const char __Version[8] ="V1.0";
const char __Date[16] =__DATE__;
const char __Time[16] =__TIME__;
const char __Desc[32] ="Copyright:Liuwei";
//定义做FFT的点数
#define LENGTH 512
#define bL 9
#define IN_TYPE  S16
#define OUT_TYPE S32
#define LEN_TYPE S32
#define PI 3.1415926535897932384626433832795
void FFT_Init(void);
void FFT_Input(IN_TYPE *pIn);
void FFT_Output(IN_TYPE *pIn, OUT_TYPE *pRe, OUT_TYPE *pIm);
LEN_TYPE BitRev[LENGTH];  //保存位倒置的值
//定义该宏将对结果进行归一化处理,否则不进行归一化处理,但是结果可能会溢出
//#define UNITARY 1
//定义该宏将使用查表法求正、余弦
#define USE_TABLE
//如果使用查表法求正、余弦,则定义表格
#ifdef USE_TABLE
#if LENGTH==32
//计算余弦用的表,放大了1024倍(32点FFT时用)
const short int COS_TABLE[LENGTH/2]=
  1024,1004,946,851,724,569,392,200,0,-200,
  -392,-569,-724,-851,-946
//计算正弦用的表,放大了1024倍(32点FFT时用)
const short int SIN_TABLE[LENGTH/2]=
  0,200,392,569,724,851,946,1004,1024,1004,
  946,851,724,569,392
#endif
#if LENGTH==64
//计算余弦用的表,放大了1024倍(64点FFT时用)
  1024,1019,1004,980,946,903,851,792,724,650,
  569,483,392,297,200,100,0,-100,-200,-297,
  -392,-483,-569,-650,-724,-792,-851,-903,-946,-980,
  -1004,-1019
//计算正弦用的表,放大了1024倍(64点FFT时用)
  0,100,200,297,392,483,569,650,724,792,
  851,903,946,980,1004,1019,1024,1019,1004,980,
  946,903,851,792,724,650,569,483,392,297,
  200,100
#endif
#if LENGTH==128
//计算余弦用的表,放大了1024倍(128点FFT时用)
  1024,1023,1019,1013,1004,993,980,964,946,926,
  903,878,851,822,792,759,724,688,650,610,
  569,526,483,438,392,345,297,249,200,150,
  100,50,0,-50,-100,-150,-200,-249,-297,-345,
  -392,-438,-483,-526,-569,-610,-650,-688,-724,-759,
  -792,-822,-851,-878,-903,-926,-946,-964,-980,-993,
  -1004,-1013,-1019,-1023
//计算正弦用的表,放大了1024倍(128点FFT时用)
  0,50,100,150,200,249,297,345,392,438,
  483,526,569,610,650,688,724,759,792,822,
  851,878,903,926,946,964,980,993,1004,1013,
  1019,1023,1024,1023,1019,1013,1004,993,980,964,
  946,926,903,878,851,822,792,759,724,688,
  650,610,569,526,483,438,392,345,297,249,
  200,150,100,50
#endif
#if LENGTH==256
//计算余弦用的表,放大了1024倍(256点FFT时用)
  1024,1024,1023,1021,1019,1016,1013,1009,1004,999,
  993,987,980,972,964,955,946,936,926,915,
  903,891,878,865,851,837,822,807,792,775,
  759,742,724,706,688,669,650,630,610,590,
  569,548,526,505,483,460,438,415,392,369,
  345,321,297,273,249,224,200,175,150,125,
  100,75,50,25,0,-25,-50,-75,-100,-125,
  -150,-175,-200,-224,-249,-273,-297,-321,-345,-369,
  -392,-415,-438,-460,-483,-505,-526,-548,-569,-590,
  -610,-630,-650,-669,-688,-706,-724,-742,-759,-775,
  -792,-807,-822,-837,-851,-865,-878,-891,-903,-915,
  -926,-936,-946,-955,-964,-972,-980,-987,-993,-999,
  -1004,-1009,-1013,-1016,-1019,-1021,-1023,-1024
//计算正弦用的表,放大了1024倍(256点FFT时用)
  0,25,50,75,100,125,150,175,200,224,
  249,273,297,321,345,369,392,415,438,460,
  483,505,526,548,569,590,610,630,650,669,
  688,706,724,742,759,775,792,807,822,837,
  851,865,878,891,903,915,926,936,946,955,
  964,972,980,987,993,999,1004,1009,1013,1016,
  1019,1021,1023,1024,1024,1024,1023,1021,1019,1016,
  1013,1009,1004,999,993,987,980,972,964,955,
  946,936,926,915,903,891,878,865,851,837,
  822,807,792,775,759,742,724,706,688,669,
  650,630,610,590,569,548,526,505,483,460,
  438,415,392,369,345,321,297,273,249,224,
  200,175,150,125,100,75,50,25
#endif
#if LENGTH==512
//计算余弦用的表,放大了1024倍(512点FFT时用)
  1024,1024,1024,1023,1023,1022,1021,1020,1019,1018,
  1016,1015,1013,1011,1009,1007,1004,1002,999,996,
  993,990,987,983,980,976,972,968,964,960,
  955,951,946,941,936,931,926,920,915,909,
  903,897,891,885,878,872,865,858,851,844,
  837,830,822,815,807,799,792,784,775,767,
  759,750,742,733,724,715,706,697,688,678,
  669,659,650,640,630,620,610,600,590,579,
  569,558,548,537,526,516,505,494,483,472,
  460,449,438,426,415,403,392,380,369,357,
  345,333,321,309,297,285,273,261,249,237,
  224,212,200,187,175,163,150,138,125,113,
  100,88,75,63,50,38,25,13,0,-13,
  -25,-38,-50,-63,-75,-88,-100,-113,-125,-138,
  -150,-163,-175,-187,-200,-212,-224,-237,-249,-261,
  -273,-285,-297,-309,-321,-333,-345,-357,-369,-380,
  -392,-403,-415,-426,-438,-449,-460,-472,-483,-494,
  -505,-516,-526,-537,-548,-558,-569,-579,-590,-600,
  -610,-620,-630,-640,-650,-659,-669,-678,-688,-697,
  -706,-715,-724,-733,-742,-750,-759,-767,-775,-784,
  -792,-799,-807,-815,-822,-830,-837,-844,-851,-858,
  -865,-872,-878,-885,-891,-897,-903,-909,-915,-920,
  -926,-931,-936,-941,-946,-951,-955,-960,-964,-968,
  -972,-976,-980,-983,-987,-990,-993,-996,-999,-1002,
  -1004,-1007,-1009,-1011,-1013,-1015,-1016,-1018,-1019,-1020,
  -1021,-1022,-1023,-1023,-1024,-1024
//计算正弦用的表,放大了1024倍(512点FFT时用)
  0,13,25,38,50,63,75,88,100,113,
  125,138,150,163,175,187,200,212,224,237,
  249,261,273,285,297,309,321,333,345,357,
  369,380,392,403,415,426,438,449,460,472,
  483,494,505,516,526,537,548,558,569,579,
  590,600,610,620,630,640,650,659,669,678,
  688,697,706,715,724,733,742,750,759,767,
  775,784,792,799,807,815,822,830,837,844,
  851,858,865,872,878,885,891,897,903,909,
  915,920,926,931,936,941,946,951,955,960,
  964,968,972,976,980,983,987,990,993,996,
  999,1002,1004,1007,1009,1011,1013,1015,1016,1018,
  1019,1020,1021,1022,1023,1023,1024,1024,1024,1024,
  1024,1023,1023,1022,1021,1020,1019,1018,1016,1015,
  1013,1011,1009,1007,1004,1002,999,996,993,990,
  987,983,980,976,972,968,964,960,955,951,
  946,941,936,931,926,920,915,909,903,897,
  891,885,878,872,865,858,851,844,837,830,
  822,815,807,799,792,784,775,767,759,750,
  742,733,724,715,706,697,688,678,669,659,
  650,640,630,620,610,600,590,579,569,558,
  548,537,526,516,505,494,483,472,460,449,
  438,426,415,403,392,380,369,357,345,333,
  321,309,297,285,273,261,249,237,224,212,
  200,187,175,163,150,138,125,113,100,88,
  75,63,50,38,25,13
#endif
#if LENGTH==1024
//计算余弦用的表,放大了1024倍(1024点FFT时用)
  1024,1024,1024,1024,1024,1024,1023,1023,1023,1022,
  1022,1022,1021,1021,1020,1020,1019,1018,1018,1017,
  1016,1016,1015,1014,1013,1012,1011,1010,1009,1008,
  1007,1006,1004,1003,1002,1000,999,998,996,995,
  993,992,990,989,987,985,983,982,980,978,
  976,974,972,970,968,966,964,962,960,958,
  955,953,951,948,946,944,941,939,936,934,
  931,928,926,923,920,917,915,912,909,906,
  903,900,897,894,891,888,885,882,878,875,
  872,868,865,862,858,855,851,848,844,841,
  837,834,830,826,822,819,815,811,807,803,
  799,796,792,788,784,779,775,771,767,763,
  759,755,750,746,742,737,733,729,724,720,
  715,711,706,702,697,692,688,683,678,674,
  669,664,659,654,650,645,640,635,630,625,
  620,615,610,605,600,595,590,584,579,574,
  569,564,558,553,548,543,537,532,526,521,
  516,510,505,499,494,488,483,477,472,466,
  460,455,449,443,438,432,426,421,415,409,
  403,398,392,386,380,374,369,363,357,351,
  345,339,333,327,321,315,309,303,297,291,
  285,279,273,267,261,255,249,243,237,230,
  224,218,212,206,200,194,187,181,175,169,
  163,156,150,144,138,132,125,119,113,107,
  100,94,88,82,75,69,63,57,50,44,
  38,31,25,19,13,6,0,-6,-13,-19,
  -25,-31,-38,-44,-50,-57,-63,-69,-75,-82,
  -88,-94,-100,-107,-113,-119,-125,-132,-138,-144,
  -150,-156,-163,-169,-175,-181,-187,-194,-200,-206,
  -212,-218,-224,-230,-237,-243,-249,-255,-261,-267,
  -273,-279,-285,-291,-297,-303,-309,-315,-321,-327,
  -333,-339,-345,-351,-357,-363,-369,-374,-380,-386,
  -392,-398,-403,-409,-415,-421,-426,-432,-438,-443,
  -449,-455,-460,-466,-472,-477,-483,-488,-494,-499,
  -505,-510,-516,-521,-526,-532,-537,-543,-548,-553,
  -558,-564,-569,-574,-579,-584,-590,-595,-600,-605,
  -610,-615,-620,-625,-630,-635,-640,-645,-650,-654,
  -659,-664,-669,-674,-678,-683,-688,-692,-697,-702,
  -706,-711,-715,-720,-724,-729,-733,-737,-742,-746,
  -750,-755,-759,-763,-767,-771,-775,-779,-784,-788,
  -792,-796,-799,-803,-807,-811,-815,-819,-822,-826,
  -830,-834,-837,-841,-844,-848,-851,-855,-858,-862,
  -865,-868,-872,-875,-878,-882,-885,-888,-891,-894,
  -897,-900,-903,-906,-909,-912,-915,-917,-920,-923,
  -926,-928,-931,-934,-936,-939,-941,-944,-946,-948,
  -951,-953,-955,-958,-960,-962,-964,-966,-968,-970,
  -972,-974,-976,-978,-980,-982,-983,-985,-987,-989,
  -990,-992,-993,-995,-996,-998,-999,-1000,-1002,-1003,
  -1004,-1006,-1007,-1008,-1009,-1010,-1011,-1012,-1013,-1014,
  -1015,-1016,-1016,-1017,-1018,-1018,-1019,-1020,-1020,-1021,
  -1021,-1022,-1022,-1022,-1023,-1023,-1023,-1024,-1024,-1024,
  -1024,-1024
//计算正弦用的表,放大了1024倍(1024点FFT时用)
  0,6,13,19,25,31,38,44,50,57,
  63,69,75,82,88,94,100,107,113,119,
  125,132,138,144,150,156,163,169,175,181,
  187,194,200,206,212,218,224,230,237,243,
  249,255,261,267,273,279,285,291,297,303,
  309,315,321,327,333,339,345,351,357,363,
  369,374,380,386,392,398,403,409,415,421,
  426,432,438,443,449,455,460,466,472,477,
  483,488,494,499,505,510,516,521,526,532,
  537,543,548,553,558,564,569,574,579,584,
  590,595,600,605,610,615,620,625,630,635,
  640,645,650,654,659,664,669,674,678,683,
  688,692,697,702,706,711,715,720,724,729,
  733,737,742,746,750,755,759,763,767,771,
  775,779,784,788,792,796,799,803,807,811,
  815,819,822,826,830,834,837,841,844,848,
  851,855,858,862,865,868,872,875,878,882,
  885,888,891,894,897,900,903,906,909,912,
  915,917,920,923,926,928,931,934,936,939,
  941,944,946,948,951,953,955,958,960,962,
  964,966,968,970,972,974,976,978,980,982,
  983,985,987,989,990,992,993,995,996,998,
  999,1000,1002,1003,1004,1006,1007,1008,1009,1010,
  1011,1012,1013,1014,1015,1016,1016,1017,1018,1018,
  1019,1020,1020,1021,1021,1022,1022,1022,1023,1023,
  1023,1024,1024,1024,1024,1024,1024,1024,1024,1024,
  1024,1024,1023,1023,1023,1022,1022,1022,1021,1021,
  1020,1020,1019,1018,1018,1017,1016,1016,1015,1014,
  1013,1012,1011,1010,1009,1008,1007,1006,1004,1003,
  1002,1000,999,998,996,995,993,992,990,989,
  987,985,983,982,980,978,976,974,972,970,
  968,966,964,962,960,958,955,953,951,948,
  946,944,941,939,936,934,931,928,926,923,
  920,917,915,912,909,906,903,900,897,894,
  891,888,885,882,878,875,872,868,865,862,
  858,855,851,848,844,841,837,834,830,826,
  822,819,815,811,807,803,799,796,792,788,
  784,779,775,771,767,763,759,755,750,746,
  742,737,733,729,724,720,715,711,706,702,
  697,692,688,683,678,674,669,664,659,654,
  650,645,640,635,630,625,620,615,610,605,
  600,595,590,584,579,574,569,564,558,553,
  548,543,537,532,526,521,516,510,505,499,
  494,488,483,477,472,466,460,455,449,443,
  438,432,426,421,415,409,403,398,392,386,
  380,374,369,363,357,351,345,339,333,327,
  321,315,309,303,297,291,285,279,273,267,
  261,255,249,243,237,230,224,218,212,206,
  200,194,187,181,175,169,163,156,150,144,
  138,132,125,119,113,107,100,94,88,82,
  75,69,63,57,50,44,38,31,25,19,
  13,6
#endif
#endif
函数功能:对指定长度的二进制数求对应的位倒置值。
入口参数:N:要求倒序的值。L:bit数。
返    回:N的位倒置值。
备    注:无。
LEN_TYPE DoBitRev(LEN_TYPE N, LEN_TYPE L)
LEN_TYPE Temp1,Temp2;
LEN_TYPE i;
for(i=0;i<L/2;i++)
  Temp1=0;
  Temp2=0;
  if(N&(1<<i))
   Temp1=1;
  if(N&(1<<(L-1-i)))
   Temp2=1;
  N&=~(1<<i);
  N&=~(1<<(L-1-i));
  N|=(Temp2<<i);
  N|=(Temp1<<(L-1-i));
return N;
/////////////////////////End of function/////////////////////////////
函数功能:初始化位倒置值数组,供FFT运算时查表用。
入口参数:无。
返    回:无。
备    注:结果保存在全局变量BitRev数组中。
void FFT_Init(void)
LEN_TYPE i;
for(i=0;i<LENGTH;i++) //求位反转
  BitRev[i]=DoBitRev(i,bL);
函数功能:对输入数据进行倒序处理。
入口参数:pIn:要处理的数据缓冲区地址。
返    回:无。
备    注:在调用FFT_Output之前应该调用该函数对数据进行倒序处理。
LEN_TYPE i;
IN_TYPE Temp;
  if(BitRev[i]>i)  //如果倒位序比原序大,则交换
   Temp=pIn[i];
   pIn[i]=pIn[BitRev[i]];
   pIn[BitRev[i]]=Temp;
函数功能 FFT输出。
入口参数:pIn:输入数据的缓冲区;pRe:保存实部的缓冲区;pIm:保存虚部的缓冲区。
返    回:无。
备    注:在调用该函数之前应该调用FFT_Input函数对数据进行倒序处理。
LEN_TYPE i,j;
LEN_TYPE BlockSize;
OUT_TYPE tr,ti;
LEN_TYPE OffSet1,OffSet2;
#ifdef USE_TABLE
LEN_TYPE OffSet0;
#endif
long c,s;
//先计算2点的
for(j=0;j<LENGTH;j+=2)
  tr=pIn[j+1];
  pRe[j+1]=(pIn[j]-tr);
  pIm[j+1]=0;
  pRe[j]=(pIn[j]+tr);
  pIm[j]=0;
for(BlockSize=4;BlockSize<=LENGTH;BlockSize<<=1) //再一层层计算
  for(j=0;j<LENGTH;j+=BlockSize)
   for(i=0;i<BlockSize/2;i++)
    #ifndef USE_TABLE
    c=(long)(1024*cos(2*PI*i/BlockSize));
    s=(long)(1024*sin(2*PI*i/BlockSize));
    #else
    OffSet0=LENGTH/BlockSize*i;
    c=COS_TABLE[OffSet0];
    s=SIN_TABLE[OffSet0];
    #endif
    OffSet1=i+j;
    OffSet2=OffSet1+BlockSize/2;
    tr=(OUT_TYPE)((c*pRe[OffSet2]+s*pIm[OffSet2])/1024);
    ti=(OUT_TYPE)((c*pIm[OffSet2]-s*pRe[OffSet2])/1024);
    #ifdef UNITARY  //如果要对结果归一化处理,则每次运算要除以2
    pRe[OffSet2]=(pRe[OffSet1]-tr)/2;
    pIm[OffSet2]=(pIm[OffSet1]-ti)/2;
    pRe[OffSet1]=(pRe[OffSet1]+tr)/2;
    pIm[OffSet1]=(pIm[OffSet1]+ti)/2;
    #else
    pRe[OffSet2]=(pRe[OffSet1]-tr);
    pIm[OffSet2]=(pIm[OffSet1]-ti);
    pRe[OffSet1]=(pRe[OffSet1]+tr);
    pIm[OffSet1]=(pIm[OffSet1]+ti);
    #endif
#ifdef UNITARY
pRe[0]/=2;
pIm[0]/=2;
#endif
IN_TYPE InBuffer[LENGTH];
OUT_TYPE Re[LENGTH];
OUT_TYPE Im[LENGTH];
unsigned char Peak[64];
unsigned char PeakTime[64];
#define HOLD_TIME 5
函数功能:对需要显示的峰值进行处理。
入口参数:x:横坐标;y:纵坐标值。
返    回:无。
备    注:无。
void ProcPeak(int x, int y)
if(PeakTime[x]>0)
   PeakTime[x]--;
else
if(Peak[x]>0)
  Peak[x]--;
if(y>Peak[x])
Peak[x] =y; //修改峰值
PeakTime[x] =HOLD_TIME; //保持
void FFT_Show(HDC hdc,int x0,int y0,int dy,COLORREF pk_color,COLORREF fr_color,COLORREF bk_color)
int i,x,y,j,p;
FillRectangle(hdc,x0,y0,64,dy,bk_color);
x=x0;
y=((dy)-(Re[0]*dy/LENGTH)/1024);
y=MAX(y0,MIN(y+y0,dy+y0-1));
VLine(hdc,x,y,dy+y0,fr_color);
ProcPeak(0,y0+dy-y);
for(i=1;i<64;i++)
  x++;
  y=sqrt(Re[i]*Re[i]+Im[i]*Im[i]);
  y/=10;
  y=sqrt(y);
  y=dy-y;
  ProcPeak(i,y0+dy-y);
for(i=0;i<64;i++)
   y=MAX(y0,MIN(dy-Peak[i]+y0,dy+y0-1));
   PutPixel(hdc,i+x0,y,pk_color);
#define IDC_ADC0 0x1000
#define IDC_ADC1 0x1001
#define IDC_ADC2 0x1002
#define IDC_ADC3 0x1003
#define IDC_TIMER 0x2000
HDC hdc_fft;
int adc_ch;
static RESULT WinProc(HWND hwnd,U32 msg,WPARAM wParam,LPARAM lParam)
int i,j;
HDC hdc;
RECT rc,m_rc[4];
switch(msg)
case MSG_CREATE:
GetClientRect(hwnd,&rc);
GetMatrixRectangle(m_rc,0,rc.dy-20,rc.dx,16,4,1,4,2);
CreateWindow("radiobutton",hwnd,m_rc[0].x,m_rc[0].y,m_rc[0].dx,m_rc[0].dy,0,IDC_ADC0,"ADC0");
CreateWindow("radiobutton",hwnd,m_rc[1].x,m_rc[1].y,m_rc[1].dx,m_rc[1].dy,0,IDC_ADC1,"ADC1");
CreateWindow("radiobutton",hwnd,m_rc[2].x,m_rc[2].y,m_rc[2].dx,m_rc[2].dy,0,IDC_ADC2,"ADC2");
CreateWindow("radiobutton",hwnd,m_rc[3].x,m_rc[3].y,m_rc[3].dx,m_rc[3].dy,0,IDC_ADC3,"ADC3");
SendMessage(GetWindowItem(hwnd,IDC_ADC0),MSG_SETVALUE,1,0);
FFT_Init();
adc_ch =0;
hdc_fft =CreateMemDC(64,48);
ClrScreen(hdc_fft,RGB(0,0,0));
SetTimer(hwnd,IDC_TIMER,100,0);
break;
case MSG_COMMAND:
U16 code,id;
code =HIWORD(wParam);
id =LOWORD(wParam);
switch(id)
case IDC_ADC0:
adc_ch=0;
break;
case IDC_ADC1:
adc_ch=1;
break;
case IDC_ADC2:
adc_ch=2;
break;
case IDC_ADC3:
adc_ch=3;
break;
break;
case MSG_TIMER:
InBuffer[i]=GetAddata(adc_ch);
for(j=1000;j>0;j--);
FFT_Input(InBuffer);
  FFT_Output(InBuffer,Re,Im);
  FFT_Show(hdc_fft,0,0,48,RGB(0,255,255),RGB(255,40,40),RGB(0,0,0));
  InvalidateRect(hwnd,0,0);
break;
case MSG_PAINT:
hdc =BeginPaint(hwnd);
if(hdc)
StretchBlt(hdc,0,0,rc.dx,rc.dy-24,hdc_fft,0,0,64,48,SRCCOPY);
EndPaint(hwnd,hdc);
break;
case MSG_CLOSE:
ReleaseDC(hdc_fft);
KillTimer(hwnd,IDC_TIMER);
DestroyWindow(hwnd);
break;
default:
return DefaultWindowProc(hwnd,msg,wParam,lParam);
int WinMain(HANDLE handle,void *argv)
HWND hwnd;
MSG msg;
WNDCLASS wcls;
wcls.Name =(char*)__Name;
wcls.Style =WS_CAPTION|WS_BORDER_DUAL;
wcls.ExStyle =0;
wcls.ExData =0;
wcls.hCursor =0;
wcls.BkColor =RGB(160,160,160);
wcls.Proc =WinProc;
hwnd =CreateMainWindow(&wcls, 20,30,240,160);
ShowWindow(hwnd,SW_SHOW);
while(GetMessage(&msg,hwnd))
TranslateMessage(&msg);
DispatchMessage(&msg);
xuhaikun 发表于 2011-3-13 20:55 | 显示全部楼层
大神啊,等我做毕设的时候一定要跟您好好学习一下,我要做的就是这个
baobao_wkl 发表于 2011-3-18 10:48 | 显示全部楼层
留个足迹:P
gaosunqiong 发表于 2014-3-10 13:52 | 显示全部楼层
源代码:
这里为什么将获得的数进行位倒置?我通过AD获得一系列的16bit数据,也要进行位处理吗?
