[射频器件] gpio模拟读写rc531问题
3304|4
 楼主| nanfansky 发表于 2010-9-11 23:11 | 显示全部楼层 |阅读模式
我想通过 写读 FifoData来验证rc531 操作是否成功
cpu用的是stm32 ,A0 A1 A2 是高 高 低 并口模式
那写寄存器时应该是 [写reg -> 写数据] 读寄存器是 [写reg -> 读数据]  是这样吗?
mcu接口的屏 一般写寄存器 AlE 信号是低 写Data ALE 信号是高
看上面的时序图,好像正好是反的,我按照lcd屏的时序去读写 也不行
哪位有现成的代码可以参考下吗
下面是我的代码
#define RF_CS       GPIO_Pin_9          //GPIOD
#define RF_RESET    GPIO_Pin_6          //GPIOD
#define RF_ALE       GPIO_Pin_10         //GPIOD
#define RF_WR       GPIO_Pin_7          //GPIOD
#define RF_RD       GPIO_Pin_8          //GPIOD
#define RF_CS_HIGH              GPIO_SetBits(GPIOD,RF_CS)
#define RF_CS_LOW               GPIO_ResetBits(GPIOD,RF_CS)
#define RF_RESET_HIGH           GPIO_SetBits(GPIOD,RF_RESET)
#define RF_RESET_LOW            GPIO_ResetBits(GPIOD,RF_RESET)
#define RF_ALE_HIGH             GPIO_SetBits(GPIOD,RF_ALE)
#define RF_ALE_LOW              GPIO_ResetBits(GPIOD,RF_ALE)
#define RF_WR_HIGH              GPIO_SetBits(GPIOD,RF_WR)
#define RF_WR_LOW               GPIO_ResetBits(GPIOD,RF_WR)
#define RF_RD_HIGH              GPIO_SetBits(GPIOD,RF_RD)
#define RF_RD_LOW               GPIO_ResetBits(GPIOD,RF_RD)
void rf_gpio_init(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD,ENABLE);
    /* 并口  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    RF_CS_HIGH;
    RF_RD_HIGH;
    RF_ALE_LOW;
void rf_write_cmd(u8 cmd)
    RF_RD_HIGH;
    RF_WR_HIGH;
    RF_CS_HIGH;
    GPIOC->CRL = 0x22222222;
    GPIOC->ODR = (u16)cmd;
    RF_ALE_HIGH;
    Delay(0x1f);
    RF_ALE_LOW;
    RF_RD_HIGH;
    RF_WR_HIGH;
    RF_CS_HIGH;
void rf_write_data(u8 data)
    RF_ALE_LOW;
    RF_WR_LOW;
    RF_RD_HIGH;
    RF_CS_LOW;
    //GPIOC->CRL = 0x22222222;        //2M 推挽输出
    GPIOC->CRL = 0x33333333;        //50M 推挽输出
    GPIOC->ODR = (u16)data;
    Delay(0x1f);
    RF_WR_HIGH;
    RF_CS_HIGH;
    RF_ALE_LOW;
    RF_RD_HIGH;
u8 rf_read_data()
    u8 data;
    RF_ALE_LOW;
    RF_WR_HIGH;
    RF_RD_LOW;
    RF_CS_LOW;
    //GPIOE->CRL = 0xcccccccc; //输入
    GPIOE->CRL = 0x44444444; //输入
    data = (u8)(GPIOE->IDR);
    RF_RD_HIGH;
    RF_WR_HIGH;
    RF_CS_HIGH;
    RF_ALE_LOW;
    return data;
void rf_init(void)
    u8 data;
    rf_gpio_init();
    RF_RESET_HIGH;
    Delay(0xaffff);
    RF_RESET_LOW;
    //RF_RESET_HIGH;
    rf_write_cmd(0x01);     //command
    data = rf_read_data();
    rf_write_cmd(0x02);     //fifiData
    rf_write_data(0xff);
    rf_write_cmd(0x02);
    rf_write_data(0xfe);
    rf_write_cmd(0x02);
 楼主| nanfansky 发表于 2010-9-11 23:12 | 显示全部楼层
怎么修改 都无法成功 郁闷
 楼主| nanfansky 发表于 2010-9-11 23:14 | 显示全部楼层
看图 在写reg地址的时候
为什么cs都不需要为低
 楼主| nanfansky 发表于 2010-9-12 20:49 | 显示全部楼层
重新焊块板子 飞线用spi也不成功
从网上搜的代码 有的发送page地址 有的不发送
到底是需要发送page地址还是不需要哦
郁闷
 楼主| nanfansky 发表于 2010-9-13 17:59 | 显示全部楼层
并口成功 spi还不行 慢慢调
