急救啊,数据结构帧的存储问题
2223|3
 楼主| 77muke 发表于 2010-9-21 13:04 | 显示全部楼层 |阅读模式
有这样的数据帧结构,
typedef struct
  * open file by logic file name;
  * if fname is valid, signature will be ignore;
  * if fname is NULL, signature will be used to open file;
char *fname;
xesap_file_signature_t signature;
  * buffer to hold read data and the buffer's size in bytes;
  * When read Still Image with header data, buffer MUST large enouth
  * to hold header data by once read call;
void *buf;
int buf_size;
  * current read position, 0~100, lib will update this value,
  * for application, this is read only;
int pos;
unsigned long long bytes_total,bytes_pos;
  * if(signature.type*XESAP_FILE_TYPE_STILL_IMAGE) then
  * simg_num: how many Still Image is opened;
  * simg_idx: which Still Image is reading, [0,simg_idx-1];
int simg_num,simg_idx;
enum XESAP_ERR error;
  * private data, valid when xesap_file_open() success, and must call
  * xesap_file_close_R() to release resource
void *priv;/*application MUST never touch this member*/
}xesap_file_R_t;
现在要求给每帧数据添加头信息,增加数据结构为
struct frame_flag  /* 每帧标记 */
    int byte_flag;
    enum XESAP_FRAME_TYPE frame_type;
    int frame_seq;
    struct timeval frame_time;
    void *date;
    int frame_date_len;
 楼主| 77muke 发表于 2010-9-21 13:05 | 显示全部楼层
请大家帮忙分析下,这样的存储设置,正确吗。
static void* __SM_channel_simulater(void* arg)
    int ret,efn=0,I_siz,P_siz,frame_len,flagment;
    int bitrate = (1<<20),IfI = 25, fnum = (1<<30);
    xesap_task_frame_t tf = {.ChaID=(int)arg};
    struct timeval tick_lastsec;
    struct frame_signature *fsig_p;
    const xesap_task_statistic_t *tstat_p;
    struct frame_flag *add_frame_flag;
    tf.data = malloc(bitrate);
    I_siz = bitrate/10;
    P_siz = (bitrate-I_siz)/24;
    gettimeofday(&tf.timestamp,NULL);
    gettimeofday(&tick_lastsec,NULL);
    bitrate = 0;
    int num=0;
    do{
        if((efn%IfI)==0)
            tf.frame_type = XESAP_FRAME_TYPE_I_FRAME;
            if(efn%2)
                frame_len = I_siz + (random()%(20<<10));
            else
                frame_len = I_siz - (random()%(20<<10));
        else
            tf.frame_type = XESAP_FRAME_TYPE_P_FRAME;
            if(efn%2)
                frame_len = P_siz + (random()%(10<<10));
            else
                frame_len = P_siz - (random()%(10<<10));
        if(tick_lastsec.tv_sec != tf.timestamp.tv_sec)
            tick_lastsec.tv_sec= tf.timestamp.tv_sec;
            bitrate = 0;
            tstat_p = xesap_task_get_statistic(tf.ChaID);
            if(tstat_p)
    /*printf("ChaID(%d):\ttotal(%d)\tflushed(%d/%d)\tdiscard(%d)\tshrink(%d)\tFB(%d/%d)\tMEM(%02d%%-%d/%d)\n", \
                        tf.ChaID,tstat_p->fn_total,tstat_p->fn_flush_success,tstat_p->fn_flush_fail, \
                        tstat_p->fn_discard,tstat_p->fn_shrink,tstat_p->fn_buf,tstat_p->fn_size, \
                        tstat_p->buf_len*100/tstat_p->buf_size,tstat_p->buf_len,tstat_p->buf_size);*/
    flagment = 0;
        do
            if(frame_len<16)
                frame_len=16;
            if(frame_len > (64<<10))
                tf.data_len = 64<<10;
            else
                tf.data_len = frame_len;
            if(flagment)
             * 此段为每帧标记头部分
            add_frame_flag = (struct frame_flag *)calloc(1,sizeof(struct frame_flag));
            add_frame_flag->date = malloc(tf.data_len);
            add_frame_flag->byte_flag = 0X20100921;
            add_frame_flag->frame_type = tf.frame_type;
            add_frame_flag->frame_seq = num++;
            add_frame_flag->frame_time.tv_sec = tf.timestamp.tv_sec;
            add_frame_flag->frame_date_len = tf.data_len;
            add_frame_flag->date = tf.data;
            tf.data = &add_frame_flag;
            flagment++;
            frame_len -= tf.data_len;
            fsig_p = (struct frame_signature*)tf.data;
            fsig_p->magiK = FSIG_MAGIK;
            fsig_p->frame_type = tf.frame_type;
            fsig_p->data_len = tf.data_len;
            fsig_p->tv_sec = tf.timestamp.tv_sec;
        /*printf("ChaID(%d): deliver flagment(%d) magiK(0x%08x) frame_type(%d) data_len(%d)\n", \
                tf.ChaID,flagment,fsig_p->magiK,fsig_p->frame_type,fsig_p->data_len);
        ret = xesap_task_deliver_stream_frame(&tf);
            if(ret!=0)
                if(tf.error==XESAP_ERR_NO_MEM)
                    printf("file write fail,XESAP_ERR_NO_MEM\n");
                else
                    printf("file write fail, errno=%d\n",tf.error);
                    break;
            bitrate += tf.data_len;
        }while(frame_len);
        efn++;
        usleep(40000);
    }while(efn<fnum);
    return NULL;
 楼主| 77muke 发表于 2010-9-21 13:06 | 显示全部楼层
代码是有点多,大家多多指点哪
