stm32 107以太网库的demo使用uip的问题,
7121|4
 楼主| xixihaha0 发表于 2010-10-11 17:02 | 显示全部楼层 |阅读模式
官方的以太网uip的demo是一个webserver,我将webserver等内容去掉,准备弄过网络与串口互转的设备,先贴一下代码,再说明问题:
uipMain.c中的uipMain函数
void uIPMain(void)
  u8_t i, arptimer;
  uip_eth_hdr *BUF = (uip_eth_hdr*)uip_buf;//uip_buf是一个1502大小的数组,用于全局来处理以太网帧
  u32 size;
  /* Initialize the uIP TCP/IP stack. */
  uip_init();
  arptimer = 0;
  tcp_server_init();//此处将httpd_init改成了我的一个初始化函数
  while(1)
      /* Let the tapdev network device driver read an entire IP packet
      into the uip_buf. If it must wait for more than 0.5 seconds, it
      will return with the return value 0. If so, we know that it is
      time to call upon the uip_periodic(). Otherwise, the tapdev has
      received an IP packet that is to be processed by uIP. */
      size = ETH_HandleRxPkt(uip_buf);//处理接收的包
      if (size > 0)
          uip_len = size;
      if(uip_len <= 0x0)//表明读取数据超时
          for(i = 0; i < UIP_CONNS; i++)//tcp部分
              uip_periodic(i);
              /* If the above function invocation resulted in data that
              should be sent out on the network, the global variable
              uip_len is set to a value > 0. */
              if(uip_len > 0)
                  uip_arp_out();
                  TransmitPacket();
          }/* end for */
#if UIP_UDP
          for(i = 0; i < UIP_UDP_CONNS; i++)//udp部分
              uip_udp_periodic(i);
              if(uip_len > 0)
                  uip_arp_out();
                  TransmitPacket();
          } /* end for */
#endif /* UIP_UDP */
          /* Call the ARP timer function every 10 seconds. */
          if(++arptimer == 20)
              uip_arp_timer();
              arptimer = 0;
      } /* end if(uip_len <= 0x0) */
      else
          if(BUF->type == htons(UIP_ETHTYPE_IP))//如果是IP包
              uip_arp_ipin();
              uip_input();
              if(uip_len > 0)
                  uip_arp_out();
                  TransmitPacket();
          else if(BUF->type == htons(UIP_ETHTYPE_ARP))//如果是ARP包
              uip_arp_arpin();
              if(uip_len > 0)
                  TransmitPacket();
      } /* end else */
tcp_server.c
  1. #include "uip.h"
  2. #include "tcp_server.h"
  3. #include <stdio.h>
  4. #define HOST_IDLE 0 //主机空闲,一直处于监听状态
  5. #define CLIENT_GET 1 //客户端连接上
  6. #define DATA_SEND 2
  7. struct tcp_server_state *tss;//tcp sever state
  8. void tcp_server_init(void)
  9. {
  10. uip_listen(HTONS(1000));
  11. }
  12. /* 注意uip如果做为tcp服务器端向客户端发送数据只有三种方法
  13. 1.在收到新数据时进行发送
  14. 2.在需要重发时进行发送
  15. 3.在收到对方收到数据的ack确认后,如果有数据可以进行发送 */
  16. void tcp_server_appcall(void)
  17. {
  18. tss = (struct tcp_server_state *)(uip_conn->appstate);
  19. if(uip_connected()) //客户端接入
  20. {
  21. printf("Tcp Clinet In \r\n");
  22. tss->state = CLIENT_GET;
  23. return;
  24. }
  25. if(uip_newdata()|| uip_rexmit()) //收到新的数据
  26. {
  27. switch(tss->state)
  28. {
  29. case CLIENT_GET:
  30. printf("Get The Clinet Data Num is %d\r\n",uip_datalen());
  31. if(!uip_poll())
  32. {
  33. uip_send("ok\n", 3);
  34. tss->state = DATA_SEND;
  35. }
  36. break;
  37. default:break;
  38. }
  39. }
  40. if(uip_acked() && tss->state == DATA_SEND)
  41. {
  42. tss->state = CLIENT_GET;
  43. printf("send has been ack\r\n");
  44. }
  45. if(uip_poll())
  46. {
  47. //复制数据到缓冲区
  48. return ;
  49. }
  50. if(uip_timedout())
  51. {
  52. printf("uip time out \r\n");
  53. }
  54. if(uip_aborted()) //是否客户端中断关闭
  55. {
  56. printf("The Client Is Aborted\r\n");
  57. tss->state = HOST_IDLE;
  58. }
  59. if(uip_closed()) //是否客户端中断关闭
  60. {
  61. printf("The Client Is Closed\r\n");
  62. tss->state = HOST_IDLE;
  63. }
  64. }
tcp_server.h
  1. #ifndef _SERVER_H
  2. #define _SERVER_H
  3. #include "uipopt.h"
  4. void tcp_server_init(void);
  5. void tcp_server_appcall(void);
  6. #ifndef UIP_APPCALL
  7. #define UIP_APPCALL tcp_server_appcall
  8. #endif
  9. struct tcp_server_state {
  10. u8_t state;
  11. };
  12. /* UIP_APPSTATE_SIZE: The size of the application-specific state
  13. stored in the uip_conn structure. */
  14. #ifndef UIP_APPSTATE_SIZE
  15. #define UIP_APPSTATE_SIZE (sizeof(struct tcp_server_state))
  16. #endif
  17. #endif
现在问题是,我服务器端进行连接后,在第三次握手时,始终检测不到客户端的 ack包,而一直在发送syn ack包(二次握手用的包)?wrieshark抓图如下:
其中服务器端uip的ip设置为 192.168.0.102,客户端我的pc机 的ip设置为 192.168.1.101,是不是stm移植的uip有bug?请各位指导一下
 楼主| xixihaha0 发表于 2010-10-11 20:51 | 显示全部楼层
高手不见了?赶紧自己顶一下,要不沉了
taomo 发表于 2011-3-1 20:57 | 显示全部楼层
顶啊,很好啊,其实我还是没有懂啊,只要我还很菜啊
fan_qh 发表于 2012-3-15 17:09 | 显示全部楼层
很好,定,能把工程分享一下就好了
zouzhuliu 发表于 2014-1-2 16:25 | 显示全部楼层
请问,你的size = ETH_HandleRxPkt(uip_buf)是取的DMA描述符列表吗
