请教 M051串口的问题
4935|5
 楼主| zhangyang86 发表于 2010-11-19 00:44 | 显示全部楼层 |阅读模式
运行新唐给的串口例程,有个地方有疑问;
发现 中断不停的发生,发生之后(u32IntStatus & DRVUART_THREINT)一直是为true的,
这是为什么???
谁知道,我大致看了一下串口的知识,没发现哪里有这样的说明!
按我的理解,当发送FIFO为空,也就是发送FIFO里面的数据消费之后这个中断发生,为什么会一直中断呢?
有谁能帮助讲解一下??
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
#include <stdio.h>
#include "Driver\DrvUART.h"
#include "Driver\DrvGPIO.h"
#include "Driver\DrvSYS.h"
#define RXBUFSIZE 1024
/* Global variables        */
volatile uint8_t comRbuf[RXBUFSIZE];
volatile uint16_t comRbytes = 0;        /* Available receiving bytes */
volatile uint16_t comRhead     = 0;
volatile uint16_t comRtail     = 0;
volatile int32_t g_bWait     = TRUE;
uint8_t u8SendData[12] ={0};
uint8_t u8RecData[RXBUFSIZE]  ={0};
int32_t w_pointer =0;
volatile int32_t r_pointer = 0;
int32_t IsRS485ISR_TX_PORT = FALSE;
int32_t IsRS485ISR_RX_PORT = FALSE;
/* Define functions prototype        */
void UART_INT_HANDLE(uint32_t u32IntStatus);
/* UART Callback function        */
     uint8_t bInChar[1]={0xFF};
            if(u32IntStatus & DRVUART_RDAINT)
        /* Get all the input characters */
        while(UART0->ISR.RDA_IF==1)
            /* Get the character from UART Buffer */
            DrvUART_Read(UART_PORT0,bInChar,1);
            if(bInChar[0] == '0')
                g_bWait = FALSE;
            /* Check if buffer full */
            if(comRbytes < RXBUFSIZE)
                /* Enqueue the character */
                comRbuf[comRtail] = bInChar[0];
                comRtail = (comRtail == (RXBUFSIZE-1)) ? 0 : (comRtail+1);
                comRbytes++;
    else if(u32IntStatus & DRVUART_THREINT)
        uint16_t tmp;
        tmp = comRtail;
        if(comRhead != tmp)
            bInChar[0] = comRbuf[comRhead];
            DrvUART_Write(UART_PORT0,bInChar,1);
            comRhead = (comRhead == (RXBUFSIZE-1)) ? 0 : (comRhead+1);
            comRbytes--;
/*  UART Function Test        */
void UART_FunctionTest()
    /* Enable Interrupt and install the call back function */
    DrvUART_EnableInt(UART_PORT0, (DRVUART_RLSINT | DRVUART_THREINT | DRVUART_RDAINT),UART_INT_HANDLE);
    while(g_bWait);
    /* Disable Interrupt */
    DrvUART_DisableInt(UART_PORT0,DRVUART_RLSINT | DRVUART_THREINT | DRVUART_RDAINT);
    g_bWait =TRUE;
/* UART Test Sample        */
/* Test Item        */
/* It sends the received data to HyperTerminal.                                                               */
int32_t main()
//    int8_t item;
    STR_UART_T sParam;
    /* SYSCLK =>12Mhz*/
    UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;
      /* Run 48Mhz */
    DrvSYS_Open(48000);
       /* Set UART Pin */
    DrvGPIO_InitFunction(E_FUNC_UART0);
    /* UART Setting */
    sParam.u32BaudRate         = 19200;
    sParam.u8cDataBits         = DRVUART_DATABITS_8;
    sParam.u8cStopBits         = DRVUART_STOPBITS_1;
    sParam.u8cParity         = DRVUART_PARITY_NONE;
    sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
    /* Set UART Configuration */
     if(DrvUART_Open(UART_PORT0,&sParam) != E_SUCCESS)
         return FALSE;
     DrvGPIO_Open(E_PORT3,E_PIN6,E_IO_OUTPUT)   ;
               DrvGPIO_ClrBit(E_PORT3,E_PIN6);
      DrvSYS_Delay(500000);
      DrvGPIO_SetBit(E_PORT3,E_PIN6);
    do
     UART_FunctionTest();
    }while(g_bWait);
hotpower 发表于 2010-11-19 09:35 | 显示全部楼层
有点乱,先把原厂例程看明白再自己做会好些。
 楼主| zhangyang86 发表于 2010-11-19 10:19 | 显示全部楼层
这个就是原厂的例程,我自己按照自己的意思写了个没问题,但是其实没有理解透!
他这个我测试了,不停在中断!
秋天落叶 发表于 2010-11-19 14:57 | 显示全部楼层
楼主确定这个是原厂的例程??
 楼主| zhangyang86 发表于 2010-11-21 23:57 | 显示全部楼层
基本没有改动,只是瘦身了!
andy_gao 发表于 2011-11-23 12:03 | 显示全部楼层
fifo空的时候就一直中断,我也遇到了
还在找愿意
